General Category => General Discussion => Topic started by: clwtwizted on September 15, 2009, 09:55:59 PM
Title: D15B6. Problems(Its Dead!)
Post by: clwtwizted on September 15, 2009, 09:55:59 PM
I have a crx that has a boosted d15b6 hf motor. I also have a z6 waiting to drop in. problem is i cant seem to blow it up. i cruise in only first and second gear. i bounce off the rev a couple times  before i shift. I dont have a wastegate, but the motor is so weak it only spools up the turbo to 3-4 psi (ebay t3/t4). Im not going to just pull the motor out and junk it. thats no fun nor and im not draining the oil. no fun either. I just want it to blow up in all its shitty glorry. any tips.
Cliff notes I drive like an ass. motor wont die
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi66.photobucket.com%2Falbums%2Fh273%2FClwtwizted%2Fslut2.jpg&hash=ccecdb737a2d92cd4156da564a34d60d9a62d931)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi66.photobucket.com%2Falbums%2Fh273%2FClwtwizted%2FSlut10.jpg&hash=866b0aecdf54ee365024e87af21526d4178f8f24)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi66.photobucket.com%2Falbums%2Fh273%2FClwtwizted%2Fslut3.jpg&hash=7a7d3e0d42469b0e6092ba0e17086f5539be16da)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi66.photobucket.com%2Falbums%2Fh273%2FClwtwizted%2Fslut1.jpg&hash=efcbdad170167314382d0d1eeebcb19bc22eff2f)
Title: Re: D15B6. Problems(It wont die!)
Post by: ApexSilver06MR on September 15, 2009, 09:59:55 PM
blow it up on the dyno..
force the wastegate closed and pinch the fuel return all the way and drive it around....
Post by: clwtwizted on September 15, 2009, 10:05:17 PM
No wastegate. I have a block off plate. those were pictures are of before the set up was done because i thought the motor may do some thing. not wasting money on a dyno to see a 50 hp motor let loose if it even would
Post by: lilpooh21186 on September 15, 2009, 10:12:35 PM
advance dizzy poor some speedy dry in the vc and try to do a ripper if i can
Post by: clwtwizted on September 15, 2009, 10:14:12 PM
I like this i will deff give it a shot
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi66.photobucket.com%2Falbums%2Fh273%2FClwtwizted%2Fslut2-1.jpg&hash=6c0e28dde75ac9e99bdb9978ea06de8c74708a2c)
the complete motor shot
Pic of said bouncing off rev. 2nd gear
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi66.photobucket.com%2Falbums%2Fh273%2FClwtwizted%2Fslut1-1.jpg&hash=3d7503fa09ef017fb967bcba959ae9cc0d9a9967)
Post by: SloS13 on September 15, 2009, 10:16:53 PM
your wastegate is hooked up to your radiator, thats the problem
Post by: clwtwizted on September 15, 2009, 10:49:45 PM
wonga the wastegate is conected to the charge pipe. but still its not on there any more
Post by: chris on September 15, 2009, 11:09:51 PM
Light car on fire engine blow up
Post by: salesmonkey on September 15, 2009, 11:58:43 PM
max it out on a uphill road
Post by: Towdogg on September 16, 2009, 12:09:15 AM
Change the charge pipes to a pool hose.... :-\
Post by: 1slow91hf on September 16, 2009, 12:09:59 AM
2 gallons coleman latern fuel mixed with 91octane half tank
force wastegate closed
top speed run it through all the gears
post vids/carnage
Post by: That Guy on September 16, 2009, 12:21:08 AM
You sure your mani isnt cracked and leaking boost sauce, bad gasket ??? , even with my tired 340xxxkm motor was i able to spin to close to 30psi for a moment before everything shit the bed and rod parts and oil and coolant covered the hiway behind me :evil:
Post by: crttaz on September 16, 2009, 01:38:18 AM
poor little 8v motor :)
BTW, your doing it wrong.
THIS is how you blow up a HF motor......
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi107.photobucket.com%2Falbums%2Fm307%2Fbonespec%2FHonda%2FRR%2FHFboom.jpg&hash=25058d53a48f8db46cadddcf07308b17e596f78f)
#4 nitrous line straight into the throttle body.
Post by: CmR333 on September 16, 2009, 01:39:38 PM
AGREED
DO IT!
Post by: clwtwizted on September 16, 2009, 01:42:51 PM
Did you have an 8valve or 16valve. the ports are about the size of a 1/2 pipe.
Nitrous may be a good idea. just gotta find some one to let me use there bottle for 10 minutes or so.
Post by: Eggylshatch on September 16, 2009, 01:49:51 PM
5th gear wot pull til she blows.  Or borrow someone's smaller turbo so you can make manly boost to blow it the right way.
Post by: PhilStubbs on September 16, 2009, 01:58:47 PM
sounds like there is a problem as to why it wont boost rather than shitty engine.
Post by: brine04 on September 16, 2009, 04:43:51 PM
lol fuckin guy
Post by: Conceptz-X on September 16, 2009, 08:19:05 PM
throw a brick on the pedal, roast marshmallows on the exhaust.  sooner or later she will have enough
Post by: Joseph Davis on September 16, 2009, 08:28:56 PM
Just spray a 75 shot on top of the boost.  Ideally, it holds together for most of the bottlw while you titter like a school girl and race stock Mustangs.
It was a sad day when that video was lost to man.
Post by: t_cel_t on September 16, 2009, 09:08:00 PM
1. cut the intake mani down the middle of the runners so you leave the injectors still attached to the head
2. start motor
3. ????
4. profit
Post by: crttaz on September 16, 2009, 11:17:13 PM
Lost?????? I bet I still have it somewhere.
Post by: d-rail on September 17, 2009, 06:00:38 AM
Fix the exhaust leak or boost leak that you have that's making you run such low boost. Fix that and you'll scream till you go BOOM
Post by: 97Econobox on September 17, 2009, 09:28:31 AM
You should only blow the motor from too much power.  Dont pour shit in it or fuck up the motor.  Find your leak or whatever and then block off yoru wastegate.  RUn manly boost.
The NOS idea is win too.
Post by: Teg2boo on September 17, 2009, 10:18:55 AM
Check if the turbo shaft spin freely. Maybe the fucker is giving out.
Post by: Ghetto_D on September 17, 2009, 03:54:59 PM
drain the oil and coolant.
replace with gasoline
(call your life insurance agent and upgrade your coverage)
Enjoy.
Dont forget to take pictures.
Post by: clwtwizted on September 17, 2009, 04:27:28 PM
i advanced the timing all the way. Hits between 4-5 now. its an ebay t3/t4 with a shit motor. i have done a leak test with the charge pipe. no leaks. the exhaust has gaskets wit rvt on top. no carbon around any of the flanges. i did some 2nd gear drops on the highway going about 70. nice rattle noise but still fires up idles fine, just smokes alot more.
Post by: Joseph Davis on September 17, 2009, 05:11:08 PM
I have an F22B2 that won't die.  It developed a rocknock after losing a few quarts of oil driving home from a college visit last spring.  Parents said I couldn't buy a replacement motor (with MY money) since this one runs well
I don't know who's stupider, your parents or you for doing what they say.
Post by: Joseph Davis on September 17, 2009, 06:28:28 PM
Car is in their name, I kinda have to appease them a bit
If you have money buy your own car.
Post by: chris on September 17, 2009, 06:30:48 PM
Loosen up your t belt tensioner
Post by: BoostedSchemes on September 17, 2009, 09:08:57 PM
let me tune it
Post by: Joseph Davis on September 17, 2009, 09:45:16 PM
You bought it yet mommy still tells you what to do with it?
Post by: Ghetto_D on September 20, 2009, 01:18:31 AM
You should attach a long hose to the exhaust and WOT the bitch and blow all the leaves in your yard into a neat pile.
THen attach a large hose to the Throttle body, WOT the bitch again, and use it to suck up the leaves and turn it into crispy mulch.
Post by: keelay on September 20, 2009, 01:21:08 AM
I fucking love it!
Post by: Kain on September 20, 2009, 02:14:56 AM
piss in the gas tank.
Post by: fishinfool88 on September 20, 2009, 04:25:24 AM
Linseed oil into the gas tank, run it hard. Wait for seizure. :evil:
Post by: chris on September 20, 2009, 04:54:06 AM
ak at the car. Ok
Post by: Deleted User on September 20, 2009, 09:40:27 AM
fuckin take the rev limiter off and take it to fuckin 10k in wot in alll 5 gears  :yes:
Post by: Joseph Davis on September 20, 2009, 12:35:21 PM
I fucking love it!
Don't post again until you fix your avatar.
Post by: keelay on September 20, 2009, 02:02:47 PM
[/quote]
Mr. Davis, please enlighten me as to what is wrong with my avatar, or lack thereof
Post by: clwtwizted on September 20, 2009, 03:29:48 PM
So how would i take off the rev limit. this motor still lives
Post by: chris on September 20, 2009, 08:34:49 PM
some auto ecu's don't have rev limits.
really like what sir. Sir you seem to know everything sir. Thank You sir. We appreciate your knowledge sir. yes sir
Post by: Joseph Davis on September 20, 2009, 08:49:34 PM
[/quote]
Pink haired anime girl with huge jiggling titties.
Post by: keelay on September 20, 2009, 10:29:19 PM
[/quote]
ah, ok. i don't have that one anymore, that laptop died, but how about this one?
Post by: Joseph Davis on September 20, 2009, 10:31:34 PM
I'll settle.
Post by: keelay on September 20, 2009, 10:33:20 PM
found it. is Mr. Davis happy now?
Post by: 97Econobox on September 21, 2009, 10:23:25 AM
Advanced teh Timing, drop 2 mothballs in a 5 galon gas container and shake the shit out of it till no rattles, then pour that one an empty tank.
Block the wastegate off completely, set teh boost to like 18 psi and fly around town no lift shifts. If you cant blow it up your doing something wrong lol.
Post by: BoostedSchemes on September 21, 2009, 11:55:02 AM
im tellin ya let me tune it  :D
Post by: ironcrx on September 21, 2009, 01:07:16 PM
stick the end of the intake into a bag of sand and wot that bitch.
Post by: Eggylshatch on September 21, 2009, 10:42:38 PM
OK, if you haven't blown it up yet, you're a faggot.  If you're actually trying and it hasn't happened, you're a faggot.  If you haven't actually tried and you just posted this to sound sweet, you're a faggot.  It seems like you're faggot either way.  Redeem yourself by posting porn, and video/pictorial proof of engine-carnage.  Notice the "and," no longer will one or the other suffice, you must now post both to recover from faggot-hood.
And you'll probably end up regretting destroying your engine when your next one explodes because of your faggot-hood, and you'll come on here being a whiny bitch about how you can't drive your car anymore and you have to suck redneck dick to get rides to autozone to try to jb weld your block back together.
Good Day, Sir!
Post by: chris on September 21, 2009, 10:43:39 PM
This will make this goal easier
Pics of rod through block you have until friday or will be banned
Better now?
Post by: hatchbox90 on September 21, 2009, 10:58:40 PM
Better now?
  :yes:
Post by: hatchbox90 on September 24, 2009, 08:09:29 PM
bump
last day before banhammmer
Post by: brine04 on September 24, 2009, 08:36:32 PM
This guy is clearly a twatwaffle. I can blow up an NA D15 in about 30 seconds or 3 gears whichever happens first  :evil:
Post by: chris on September 24, 2009, 08:59:47 PM
who says fuck it ban early just for fun since we dont see pics of rods sticking half way through a head
Post by: Teg2boo on September 24, 2009, 10:48:02 PM
Maybe he is on the side of the road cause he blow it up and can't post here?
I doubt it, but we never know ;)
Post by: hatchbox90 on September 24, 2009, 11:09:37 PM
Last Active:   Today at 05:29:42 PM
i posted my bump post at 4:09, so he has seen the post after mine also
Post by: clwtwizted on September 25, 2009, 01:14:53 PM
Still havent blown it up yet.Been busy with other shit so heres some redemption porn.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg15.imageshack.us%2Fimg15%2F6590%2Fsweettits.jpg&hash=7a2af09d18b1676adf77192211fb34b2808223bb) (http://img15.imageshack.us/i/sweettits.jpg/)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg59.imageshack.us%2Fimg59%2F7803%2Flesbianporn.jpg&hash=40bed6cddbecb7bf430b913aadb41cb17c3b2202) (http://img59.imageshack.us/i/lesbianporn.jpg/)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg193.imageshack.us%2Fimg193%2F2310%2Fnicolegraves11.jpg&hash=a9490b13274425950181961443d7b79ec76e8c9a)[/URL]
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg87.imageshack.us%2Fimg87%2F7769%2Fnicolegraves15.jpg&hash=34f44c1393d0c00de7ccd04575e23966a9b2369e) (http://img87.imageshack.us/i/nicolegraves15.jpg/)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fimg87.imageshack.us%2Fimg87%2F1174%2F11jstu.jpg&hash=d0f43d85160180f71c13049fb8fdd90b929a36cb) (http://img87.imageshack.us/i/11jstu.jpg/)
Post by: chris on September 25, 2009, 01:31:00 PM
Im calling bullshit that the guy even owns a car! 3 day ban for claiming he cant blow up a d15b ;D
Post by: danz on September 27, 2009, 04:42:48 PM
no mercy for someone that posts a pussy this neat looking????  RUTHLESS
Post by: Towdogg on September 27, 2009, 11:05:04 PM
http://turbod16.com/viewtopic.php?f=6&t=47031&hilit= (http://turbod16.com/viewtopic.php?f=6&t=47031&hilit=)
Post by: Ntrain2k on September 27, 2009, 11:34:50 PM
That is one perfect pussy.
 :P :P
Post by: Teg2boo on September 28, 2009, 01:40:16 AM
haha
Post by: 97Econobox on September 28, 2009, 11:36:43 AM
Fuckign seriously its turbod and you cant blow it up without pouring shit in it?  i mean what teh fuck man.
RUN STUPID BOOST ITS A FUCKING HONDA AND ITS TURBOD IF YOU CANT BLOW IT UP CORRECTLY YOU FUCKING FAIL AT LIFE.
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb385%2Fcamaromusl%2FFailatlife.jpg&hash=770c18775ea7a2e36de1ce7d7e474e70745473af)
Post by: CmR333 on September 28, 2009, 02:00:01 PM
i expected this to be funny to watch...... you have failed.
Post by: clwtwizted on September 28, 2009, 04:52:37 PM
Well thans for the ban. I poured about a gallon of water in the oil. dropped some nuts and bolts and some sand down there too. No rods went but it ended with some bad knock and and it siezed the motor.
Loading some vids on youtube. ill post them when i get back home
Post by: j.h.christ on September 28, 2009, 04:57:43 PM
i.p. ban for cheating
Post by: clwtwizted on September 28, 2009, 05:04:02 PM
The motors fucked I posted porn what else is there?
Post by: 97Econobox on September 28, 2009, 05:42:40 PM
Seriously I can say i dont really want to see it.  i mean you literaly failed at failing dude.
Its got a turbo.  and you coudlnt blow it up.  I would think you will somehow fail and video taping it too so I dont care to subject myself to your brand of fail anymore.
Seriously.  why wouldnt you just crank that fucker up with no wastegate?????????
For christsakes Buk blew one up NA and you cant even do it boosted with out drainign the oil or putting water in it of course it will blow then, how is that fun at all?
Fucking Lame.
Post by: clwtwizted on September 28, 2009, 09:10:21 PM
motor (http://www.youtube.com/watch?v=WsViafS1MJw#normal)
done (http://www.youtube.com/watch?v=luM6Bu8I_TM#normal)
last (http://www.youtube.com/watch?v=Auki9rsrPm0#normal)
Title: Re: D15B6. Problems(Its Dead!)
Post by: j.h.christ on September 28, 2009, 09:14:31 PM
cut your hair you pile of fucking failure
Post by: Conceptz-X on September 28, 2009, 09:59:41 PM
fail at fail   I vote ban for not listening
Post by: clwtwizted on September 28, 2009, 10:23:45 PM
What did I not listen to? Some one tell me please? I posted up porn. I got banned, go unbanned blew up my motor, then get called a failure. What the fuck does it take to make you happy?
Post by: PhilStubbs on September 28, 2009, 10:28:15 PM
can i get my 47 seconds back. thats all i could watch. this thread fails worse than ohmt
Post by: Conceptz-X on September 28, 2009, 10:28:57 PM
you were given many valid suggestions on how to properly destroy the engine, and you take the easy road to failure.
Post by: PhilStubbs on September 28, 2009, 10:30:41 PM
it had an FMU on it, fully advance the distributor and run the piss out of it. its 3 damn bolts. not that hard
Post by: biscuit on September 28, 2009, 10:32:08 PM
You do realize that you just nuked your turbo too... :-\
Post by: PhilStubbs on September 28, 2009, 10:34:03 PM
it doesnt matter, he will never get it all working on a built engine. then he will probably just destroy that one with water and bolts when it doesnt work either
Post by: 97Econobox on September 28, 2009, 10:42:20 PM
Post by: Towdogg on September 28, 2009, 10:45:39 PM
And cut your hair
Post by: Conceptz-X on September 28, 2009, 10:47:07 PM
And cut your fucking hair
Post by: Deleted User on September 28, 2009, 11:23:13 PM
this guys a piece of shit, he should let me drive it i woulda blew it this motherfucker has no clue, why did u fuck it all over like that, u coulda kept that motor and everything, you prob fucked your turbo putting water in there....wow.... like i said early rev limiter take it off wot on highway end of story and advance your timing no way you wouldnt have failed but you failed at failing
And cut your mother fucking hair
Post by: Teg2boo on September 28, 2009, 11:25:28 PM
French man is disapointed  :-\
Post by: j.h.christ on September 29, 2009, 02:57:29 PM
Post by: Joseph Davis on September 29, 2009, 06:11:43 PM
Ouch, that's harsh.
Post by: Towdogg on September 29, 2009, 11:05:02 PM
Post by: CmR333 on September 30, 2009, 08:34:25 AM
YUP YOU FAIL AT FAILING! fucking sad, and cut your hair.
