Author Topic: PC build suggestions.  (Read 12218 times)
« on: January 10, 2010, 10:09:54 PM »
Looking to build a PC that will withstand the abuse of being in a hot ass shop.  Getting tired of using the slow pile of fuck on the alignment machine for internet access and streaming music.  I would like to toss it together as cheap as possible.  New or used parts makes no difference to me.
I am mainly looking for suggestions for an inexpensive processor that will handle a moderate load without melting down when it gets to 100 degrees in the shop.
WPPF
Re: PC build suggestions.
« Reply #1 on: January 10, 2010, 10:24:10 PM »
Unless you're gaming or doing something process intensive (encoding, 3d rendering, other fun shit)  just about any computer you build is going to be able to handle what you want to do with it.
« Reply #2 on: January 10, 2010, 10:34:25 PM »
I assume you mean hardware that is not 9+ years old, and did not originate from Dell.   :P
I have an old AMD XP3000 based system as my home desktop, but that fucker runs damn near 60 degrees C in ambient air that is about 75 degrees F with what I would call a moderate load.
I would assume that iTX setups consume very little power, and inherently run relatively cool.  This one caught my eye.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131396&cm_re=atom-_-13-131-396-_-Product
« Reply #3 on: January 10, 2010, 11:20:31 PM »
That would do it for you.
Just make some filters for the case air inlets to keep shop dust out of it, then keep a check on them for clogging.
« Reply #4 on: January 11, 2010, 03:35:51 AM »
JDSAP(JD SUCKS A PENIS)
« Reply #5 on: January 11, 2010, 07:24:37 AM »
386 for that nostalgic feeling  :mexi:
tekno
« Reply #6 on: January 11, 2010, 09:26:29 AM »
I suggest you buy my c2d with mobo and 2 gigs of ram for 100$ ;)
« Reply #7 on: January 11, 2010, 09:54:39 AM »
« Reply #8 on: January 11, 2010, 03:22:41 PM »
More info?
So cheap it makes a car stereo (instead of a carputer) look stupid.
By the time you factor in a touchscreen and a power supply, it is about even.  Factor in the ability to add navigation and it really does seem stupid to go with a car stereo.
« Reply #9 on: January 11, 2010, 03:35:41 PM »
Core2Duo (older Intel now) will turn you out. Most have a thermal max of 85C, which translates into fucking hotter than you'll ever get it. The stock cooler in a sealed case overclocked 50% won't even reach that. Any AMD version will not even overclock that high, and burn up before that. With a decent vid card, it will do anything you want it to, unless you're running dual screens and want full-speed CAD rendering while gaming in the other screen at 1920xfuckingwhatever resolution.
An Atom processor like JD linked to is the best price/performance for an internet/music box. I'm actually going to do that vs a stereo when I get a "grown up" car. With forced induction (fan-cooled :P) it won't overheat. They are designed to be used in dinky laptops with piss-poor fans, or none at all. That barebones combined with 2 extra 60mm fans would handle Equidor's heat.
« Reply #10 on: January 11, 2010, 03:37:57 PM »
The 7.8" Innovatek touchscreens are under $100 if you look around.
Most in-car LCDs need to have proper voltage regulation to prevent the LCD from dying quickly... needs to be run off a good regulated PS like the motherboard does, so you get to size that a little larger.
« Reply #11 on: January 11, 2010, 03:39:17 PM »
I fucking love the Core2 Duo in my T61.
Hey, bitchtits, JD didn't link to jack shit.
 :P
shogun
« Reply #12 on: January 11, 2010, 05:56:05 PM »
try the zotac ion, it does well with blueray and hd content, has a decent performance integrated graphics, and ive meassured mine consuming 45w even lower than my 60w laptop
has worked flawless for me
where i got the idea....
http://www.geek.com/articles/chips/weekend-project-building-a-tiny-cheap-silent-nettop-20091124/
« Reply #13 on: January 11, 2010, 06:07:09 PM »
 :P
FUCK YOU!!  I'm taking credit wherever I can get it.
« Reply #14 on: January 11, 2010, 06:11:26 PM »
c2d does take a bit of heat.  i3/i5/i7 are very stable too but not quite as cheap as a c2d system.
My 65nm Q6600 C2D is supposed to stay below 70C.  I've had it oc'ed from 2.4ghz to 3.6ghz for about a year and a half, frequently running at 68-70C at 100% load.
Still going.
Really any proc will be fine, but the lower the wattage, typically the better.
« Reply #15 on: January 11, 2010, 08:46:57 PM »
At full tilt at stock voltages with the stock cooler - yeah maybe it heats up. But as I said, it has a very high thermal max. You can run it at 80C 24/7 and if it breaks they will honor the warranty, mainly because they WILL throttle down at severe temps. Speaking of throttling, it will also run at a reduced speed whenever idle (if you want), and if you get a notebook chip & compatable motherboard, it will also reduce the voltage at idle. IIRC my T60's cpu drops to ~1 volt at idle, newer chips can even go below that.
What all that means is with a $40 cooler added, the stock clockspeed & voltage reduced (both retain warranty), you get something that creates 1/2 the heat of the stocker, but still burns a mini-chip like an Atom.
tekno
« Reply #16 on: January 11, 2010, 08:51:53 PM »
Um its a c2d 6320 on a gigabyte 965p-ds3 mobo with 2 gigs of ddr2 800 gskill ram it just got replaced by my i5-750 build its just sitting here. Thing runs pretty cool even on a stock heatsink. And theres always downclocking and undervolting thing never idled above 20-30* and at load never passed 60*
« Last Edit: January 11, 2010, 08:57:20 PM by tekno »
« Reply #17 on: January 12, 2010, 10:06:34 AM »
knew a guy who hooked it up in a kia sorento.  Probably one of the cleanest installs of a car PC ive ever seen.  Dudes Mr wizard, reads something one time and just knows it forwards backwards and inbetween.
http://www.sorentosite.com/forum/showthread.php?tid=2934
He took the stocker radio and tossed teh CD player and replaced it with a USB DVD burner.  Even solders the leads into it so when you hit eject on the radio it spits out the DVD.  fucking Sick
« Reply #18 on: January 12, 2010, 12:57:04 PM »
I just read that that is exactly what I want to do in '96 Previa. :yes:
Where can I find more info. on doing this.
« Reply #19 on: January 12, 2010, 02:13:34 PM »
the link i posted above is his setup but MP3Car.com will tell you anything and pretty much everything you need to know.
http://www.mp3car.com/
« Reply #20 on: January 12, 2010, 02:28:10 PM »
I see some possibilities for tuning with one these in my car and looking at real-time tuning data at the same time.
All in a nice small neat package. ;D
« Reply #21 on: January 12, 2010, 03:51:36 PM »
Theres a fella on that site whos got ione in an Audi i think and he pulls real time data logs or something like that i believe.
« Reply #22 on: January 12, 2010, 04:00:45 PM »
Yeah who can build a combo of ICE and EM in one system could make some serious cash. :yes:
« Reply #23 on: January 12, 2010, 04:43:45 PM »
well its Windows Built off TinyXP so really just install your engine software toonar stuff and drop an Icon in your interface.
half the interfaces you create you will have to edit, so you can drop script write your own stuff and its child's play.  mad Easy.
« Reply #24 on: January 14, 2010, 01:50:07 PM »
He used a Dell running Win95 in a Kia. Yeah. Maybe he shoulda put benz logos on insteada "KDM" badges.
« Reply #25 on: January 14, 2010, 02:31:48 PM »
win 95?  Its XP dude.
built his image using tinyXP.
His mirrors were cool.  key on and they folded out.  Key off and they folded in.  sorta cool.
« Last Edit: January 14, 2010, 02:33:39 PM by 97Econobox »
« Reply #26 on: January 14, 2010, 06:55:19 PM »
this guy had a pretty sweet setup.  Used the stock DIN slots where the stereo normally is and molded in a 7" touchscreen.  If I hadn't just bought a deck when I saw this, I'd probably have replicated it.
http://www.gen5alive.com/forums/showthread.php?t=7848&highlight=carputer
