What heat range you run?
1
- 7 (30.4%)
2
- 13 (56.5%)
3
- 3 (13%)
Total Members Voted: 21
Author Topic: How many steps colder do you run?  (Read 13454 times)
TTC
« on: January 11, 2010, 04:42:29 PM »
I discovered that on a local car forum people are running 2-3 steps colder and not making fuckloads of hp. I see on reason for this, perhaps I can be educated but in all honestly i've only ever run 1 step colder with no problems.
Re: How many steps colder do you run?
« Reply #1 on: January 11, 2010, 04:48:04 PM »
I run 8s.
On all but high boost noggle action im sure the 7s would be fine, and actually not load up as quick on the street in stop and go....
« Reply #2 on: January 11, 2010, 04:53:56 PM »
i have always ran bkr7e's also when boosted.
but how much power or w/e can you make and still get away with stock heat range plugs?
stock civic si (d16a6) plugs are 5's or 6's?
« Reply #3 on: January 11, 2010, 05:17:57 PM »
Depends on what brand plug.  NGKs are rated not only for their heat range, but the adjacent ones as well.  That's why they last so long and even domestic guys rock them.  Really good stuff.  Autolites aren't bad, either, I'm just not up on the numbering system like I am with NGK so meh.
If you run some crap, Densos for example (interesting how they make GREAT sensors but shitty sparkplugs), they die really quick if you don't use the correct heatrange.  If you do use the correct heatrange they last a lot longer - but then die quickly when compared to Autolite or NGK.
« Reply #4 on: January 11, 2010, 05:23:49 PM »
Stock Accord/Lude gayness are 6, hence i voted 2, but run the Non resistor 8s FUCK AN IRRIDUM for teh Resistor... (BUT CROME SURE DIDNT LIKE THE NR ones)
« Reply #5 on: January 11, 2010, 05:51:43 PM »
2 because bkr7e's are baller
been running the same set for 3 or 4 years now
« Reply #6 on: January 11, 2010, 05:54:40 PM »
Im running 2 step colder in my ls. And Im not even boosted. Fucker runs great. Been running the same plugs gaped down to .032 for 3000 miles (2 years)on the same shit.
lilpooh21186
« Reply #7 on: January 11, 2010, 06:19:56 PM »
i was taught only way to know your runing proper plug range is to tune it run the plug that looks best in your motor. if you have a 7 and have to gap 20 mabey and 8 at higher gap would suffice
Ecu chipping
basmaps
Rosario4124
  • HATE HATE HATE
« Reply #8 on: January 11, 2010, 07:52:55 PM »
most of the time if ur seriously  running a colder plug then u are usually running race gas or making some pretty decent power, i had a friend that ran 2 steps colder on c16 made 684whp tuned by jeff evans and evans only recomended 2 steps . The bkre73's should be enough when boosted.
« Reply #9 on: January 11, 2010, 08:08:47 PM »
I see no option for 0.
« Reply #10 on: January 11, 2010, 08:14:43 PM »
Never had an issues running non resistor plugs with crome. I've ran 4091's for 25k miles without any issues except noise interference to the radio signal.
theidealone
« Reply #11 on: January 11, 2010, 08:42:24 PM »
BKR7Es (4644 now). Stock was a 6 (BCPR6E-11s or something). I was going to go with an 8 (NR), but was told not to, because of interferences with Crome.
boosted 00 black si
« Reply #12 on: January 12, 2010, 09:45:21 AM »
i've been running 2's for over five years now love em
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
« Reply #13 on: January 12, 2010, 10:06:58 AM »
Only COP cars, poorly designed Hondata daughterboards, and fat men in boat anchors have issues with non-resistor plugs.
« Reply #14 on: January 12, 2010, 11:30:00 AM »
Different motors want different things.  I ran NGK 8 heat range plugs in my last GSX, small turbo LOTS of boost, and reading the heat band on the plug was spot on.  With 7's it would have funny random misfires in the midrange (even with more fuel added) and with the gap closed.  Not a stock 4g63 btw, head cut, cams, etc, etc.
« Reply #15 on: January 12, 2010, 12:47:09 PM »
Only COP cars, poorly designed Hondata daughterboards, and ENORMOUSLY FAT men in boat anchors have issues with non-resistor plugs.
N1 Andy
« Reply #16 on: January 12, 2010, 06:57:26 PM »
My bkr8es' only last a couple weeks on pump gas, my 325whp is not enough for 8's.  I switched to 7's and its been running great.  I've always heard don't switch to 8's until 500whp and up.
GFIgarage
