TURBOS SLUTS LIQOUR FLUXCORE AND RACEGAS
HATCHBOYS WIFES CUNT IS GOING TO BE A MILE WIDE BY THE TIME WE GET DONE WITH HER WHILST HES GONE
Fuck your mom
Whats this all Aboot???
FUCK CANADA
Urban Indians Cousin gets gang banged by the dirtiest of HMT nigs
BLANKET PARTY RICKY P AND BRING HIS ASS FOR A NW STOOD STOMPING BY THE CREATOR AND CLAN
Pages: 1 ... 14 15 [16] 17 18 ... 20   Go Down
Author Topic: YO SON!!!!! OFFICIAL NW RHMT DYNO DAY- Today!!!!! :O)  (Read 456807 times)
Re: 3 DAYS 'TILL: OFFICIAL NW DYNO DAY- May 30th - LETS DO THIS SHIT!!!
« Reply #450 on: May 28, 2009, 11:59:37 AM »
2 days left you worthless faggots....
PUlling the saenz as we speak and getting ready to stuff the H23 trans in this pile o mine..
I have to play records at Contour from 2-3:30 the night before, but plan on being there at around 10. Fuck Im going to be tired too, beeen a hectic couple of days....
Looking forward to seein you nigs!
Brian, I'll just pick that tranny up at the dyno meet. I'm leaving to Pullman right now.
you sound like a bunch of fucking faggots
this thing went from a block and head to in the car from sunday night to wednesday night running. Dont bitch about lack of sleep because I am living off 15-20 energy drinks and a total combined of 20 hours of sleep to have my car ready for this meet
pussies
pussies
Same with me but not running damn it.
Maybe I'll drag my HB on a car dolly up there and get some help. ;D
Deal super bean.
BoostForLife
pussies
What's wrong with the hatch?
possible bad starter which I will change out today.
The engine will not crank over I manage to flood the crankcase with fuel.
When I was having ECU problems (solid CEL) I was cranking the engine over without disabling the injectors.
I changed oil and disable the injectors cranked for a while and the starter got hot.
So I let the starter cool down and try to crank it over.
I here the starter engauging but engine will not crank.
I figured I just need to let the starter be completely cooled down.
So I tried to crank the engine this morning and still no engine movement.
I even had marvel mystery oil in the sparkplug hole to help lub the rings, but no dice.
When I get off work I'm going to see if my engine will crank with a different starter or roll start just get engine loosened up.
If I can the engine cranking over then I'll put HB on the car dolly and bring it up with my Previa.
BoostForLife
You should probably bring it up here. After severely flooding the motor, always change oil.
It does sound like you have a starter problem.
Also, check every fuse under the hood and under the steering wheel.
Yeah I already changed the oil and I'll have the starter changed this afternoon I may even loosen up the cam caps to see if the cam did not gale the cam saddles a little that could be part of the problem if I'm not getting enough oil in there.
Eventhough I did use a lot of assembelly lub when putting the head back together. ;D
I'll double check my fuses but I do not think any of them are blown.
BTW when I read anything you post I here it in my head in Mr. Beans voice.  ;D
Damn voices LOL
OKAY FAGGOTS
Ill be there between 10 and 11.
See yall there
After a LATE night of rocking the Contour afterhours....
Straightcuts are out. Broke one tooth on the counter gear/// 250 bux, wont have the gaear till june 8th.
SOooo... In goes my 40 dollar H23 backup slut... Looks like its going to have a grind going into third... I do have a better slider i just picked up this morning, but dont feel like putting it in.
Fuck it.
Ill be there in the slut on Racegas.  hahaah
OK GUYS:
Ill be down at the shop about 10-11. We need to get as list of people together who expect only to make pulls, and they need to go first.
 Those wanting to tune will need to go last, Levi should probably be thye LAST one. Tommy will stay late, but Id like to definately be wrapped up cleaned up and out by 7PM. figure 20-30 for 3 puills or so. Those tuning can pay a bit more, but we need to have an idea how many peeps actually want to do pulls, and who wants to tune....
There is Sunoco 110 race fuel available 2 blocks away frtom the spot for 9.80 a gallon... after tax it comes to 53 for 5 gallons...
They have higher octane but i dont know how much it is, nor why youd need it
Shop closes at 1 PM though.
« Last Edit: May 28, 2009, 07:48:32 PM by bigdaddyvtec »
I will be there right around 10:00
I only want 2 pulls, maybe 4...lol
Not much tuning to do for me, maybe just a little timing here or there.
Everyone needs to make sure they bring some extra spark plugs!!!
chevy
i talked to dave today..  ;) ill be one of the ones needing tuning but ill be there at about 10ish  :yes:
Rumor has it that the Indian forgot his passport, keep your fingers crossed that US Customs let him across, as June 1st it becomes mandatory to have a passport to cross the boarder.
pistol
JESUS
its either him or rachel. ever trip they make one of them forgets that shit
BoostForLife
He should cross it Friday night then, im pretty sure they will let him back into canada no problem
His passport will be here 10 am tomorrow morning its all cool.
Apparently some deuchebag named Josh didn't finish his race transmission so hopefully he doesn't puke gears on the dyno.
Shop closes at 1PM?  Hopefully that'll be enough time.
thats the place for Race gas
BoostForLife
1 day left bitches,
Im gonna adjust the valves on the ZC tomorrow and see what it puts down. BTW: It's stock on a PM6 ecu, FTL.
Cadracer
 :o Well i will need 3 pulls on the fordillac this time it wont be chocking out at 2800rpms like last time making full rpm 4500.
also want 2 pills on the diesel truck to see what it does on 25psi and then crank it up to 35psi or what ever the super 70 ss autochrome turbo can produce.
third i will need 2 pulls on my buddies 67 camaro with my cutom built 427 dual quad aliminum head motor pro streeter.
And save the best for last the turbo truck with the 305 built for 20psi boost. Just got the vortec heads on tonight and there setup for the .550 lift 305 duration cam  and the t4 turbo. This is where i will need 3 pulls to do some tuning on the added fuel system i got on it. Hope that bosh fuel pump holds up.Works great on the volvos.
Ok im off to bed  see you all laters. :somb:
Race tranny??? All it is is a heat treated set... Its not a Straightcut dogbox or some shit like that... Cmon, you know better than that sir.
You should be better informed before you go talking shit.... as it needs bearings and they cant be gotten in time. I took the tranny to him less than a week ago, as Ive been  pretty fucking occupied too...  Including taking care of aquiring the head thats on that pile of shit AND SHIPPING it to you as well as getting him tires (that will be here tomorrow) as well as getting a bunch of shit for other people squared away too......... Levi KNEW the tranny might not be done in time last time I talked to him...  Its not "news"
 So its part my fault as well...  Trying to get shit done for nogs as well as getting your own shit done and dealing with life is just how it goes... Appearantly you didnt know that fucking thing sat in my garage for the past 4 months or so... Waiting for part The diff showed up about 3-4 weeks ago, and the syncros more recently than that.
CLIFF NOTES: you dont know what the fuck youre talking about.
By the way...  Why do they casll you "shady dave"   :-*
See you Saturday.
« Last Edit: May 29, 2009, 06:33:27 AM by bigdaddyvtec »
ZING!!!
BangBusMaster
Word on the street is that Justin is bringing a BBQ. Feel free to bring stuff to cook up, snacks, drinks, whatever.  I will be bring my nerd pack and extra spark plugs, NGK 7's and 8's.
Lets fucking do this...snoochie boochies.
Niggle Noggle NOOCHIES   :noel:
hatchboy
  • Bombs Over Baghdad
I think i am more excited sitting in iraq infront of my laptop, than most of you fucks that actually get to go!
PLZ take some video so i have fap material,and i don't want the cars, i want tubby's truffle shuffle.
See you Saturday.
Dude, fucking chill, its all shit talk, I could give a flying fuck who the guy is, I know just as good as anyone that Levi's shit is disorganized and all over the place. And obviously his tranny isn't an actual race tranny, just laugh man, it was more meant to be funny.
And they call me Sketchy Dave because I used to be really sketch, living in ditches and shit.
Re: OFFICIAL NW RHMT DYNO DAY- TOMORROW :O) UPDATED!!!! PLZ READ
« Reply #478 on: May 29, 2009, 02:21:43 PM »
That nigger Justin knows how to grill too. I'll try to bring some dogs and buns. Who's bringing condiments?
« Reply #479 on: May 29, 2009, 02:58:29 PM »
Ill brimg some shit... Jusdt got the slut back on the grounds... Took the tranny I just got BACK apart, put a new 3-45 slider in it and  the shorter M2F4 5th gear in it... so it
M2S4 92-96 Prelude Si (H23A1)    3.307 1.857 1.320 1.034 0.812 ?? 4.266
M2F4 92-96 Prelude VTEC            3.307 1.950 1.360 1.071 0.870 ?? 4.266
Mine:
3.307 1.857 1.320 1.034 0.870 with 4.266  FD
Its now MINT inside with the new slider i just put in... Going to get some syncromesh for it now and fire it up
Any bets on the tranny death pool??? New saenz second will be here in a couple weeks... Im only running the noggle buttoin on the dyno... Hopefully it lives for a couple of weeks on pump gas.  Need to teach it the gears again for boost by gear in ectune though
Pages: 1 ... 14 15 [16] 17 18 ... 20   Go Up
