Author Topic: shitty idle need advice  (Read 12960 times)
drivin96
« on: January 17, 2010, 01:41:48 AM »
so when its cold and warmin up its fine but once its warm it sucks it goes up and down between 1500-100 or 0 most recently.... i will press in the clutch and sometime the rpms will drop to low and turn off the car ... so far we've adjusted the throttle cable (adjustment screw on the gsr throttle body was dicked up) helped a lil gettin it to idle round 750rpms but it will still bounce
any ideas
Re: shitty idle need advice
« Reply #1 on: January 17, 2010, 02:23:41 AM »
bubble in your coolant will sometimes do this.
« Reply #2 on: January 17, 2010, 03:37:57 AM »
throttle body have the fitv valve on the bottom?
« Reply #3 on: January 17, 2010, 04:04:44 AM »
What I already told you in PMs.
« Reply #4 on: January 17, 2010, 10:50:22 AM »
That's what I was trying to remember.  When my car changed its own coolant a while back, it idled all fucked up because the FITV was seeing air, than coolant, then air.
lilpooh21186
« Reply #5 on: January 17, 2010, 02:57:09 PM »
Bleed that bitch
Ecu chipping
basmaps
drivin96
« Reply #6 on: January 18, 2010, 05:02:17 PM »
yes it does
drivin96
« Reply #7 on: January 18, 2010, 09:49:53 PM »
throttle stop screw is all dicked up.... does anyone have one for a gsr throttle body? junk yards round here suck and never have what i need
1slow91hf
« Reply #8 on: January 18, 2010, 09:52:12 PM »
if it idled fine before why in the fuck do you need a new TB
just bleed/top off your coolant.. issue fixed
/thread
drivin96
« Reply #9 on: January 18, 2010, 11:31:38 PM »
/thread
not the whole tb just the screw for the stopper ...and its never idleed fine its been like this for a while
drivin96
« Reply #10 on: January 19, 2010, 11:27:23 AM »
car also drops the idle when i add gas to the tank ...i'll drive it to the end of the gass station parkin lot and it will die as soon as i put the clutch in .. does this mean theres a prob with somethin in the gas line or could it just be somethin related to my prior problems?...
i didnt have allot of time today so i tightened the throttle cabl and now idle at like 1100 when i put the clutch in it drops to about 200 so it solves the prob for now but will the higher idle have a negitive effect on my car?
lilpooh21186
« Reply #11 on: January 19, 2010, 01:35:06 PM »
cp test it
Ecu chipping
basmaps
drivin96
« Reply #12 on: January 19, 2010, 01:36:51 PM »
got home a lil early and bled the coolant system ..... still havin the idle prob next step is fixin changin the fitv
can u fix the fitv or should i just get a new one ?
drivin96
« Reply #13 on: January 19, 2010, 01:37:46 PM »
cp test it
i'll give it a shot asap just dont have allot of time between school and work
drivin96
« Reply #14 on: January 19, 2010, 05:17:20 PM »
would a z6 fitv fit on a gsr tb ?
lilpooh21186
« Reply #15 on: January 19, 2010, 06:51:23 PM »
some things you have to try its eaiser then posting and waiting for answers.
Ecu chipping
basmaps
drivin96
« Reply #16 on: January 19, 2010, 07:54:38 PM »
True but i just dont got the time or money to waste it sucks . . .prob pullin the fitv apart tomorrow and seein if it salvageable if not gunna try my luck at the bone yard sat
« Reply #17 on: January 19, 2010, 10:22:15 PM »
z6 fitv is the same as b series
Open up the plate and tighten the valve/plunger inside the valve. If it is stuck good luck and try another fitv. Most are rusted through at this age
Throttle stop you mean the small 8mm bolt. I have a bunch of those. 5 bucks to cover my time and shipping its yours
drivin96
« Reply #18 on: January 20, 2010, 04:20:50 PM »
well didnt go to class today so i stayed home and pulled the fitv off took it apart put it back together and put it back on the car, then i bled the coolant system at first had foamy lookin bubbles then went clear after a min tightened that off ran the car for a few seemed fine , put in the clutch the rpms dropped from 1000 to 100 then started to bounce agin idk what the hell is goin on
then i opened up my catch can to see the line comin off of where the "black box" would be was full of the cum like goo? i wasnt able to pull the line off due to lack of time
here are some pics of the catch can , its made out of white pvc all the other colors is the shit it was talkin about there is also a good amount of moisture in there to
drivin96
« Reply #19 on: January 22, 2010, 11:28:03 AM »
what u guys think of my catch can in all of its cum like glory ? ...i'v been readin and found it could be do to moisture but im not loosin coolant and the only thing that is poss is i read the changin temps realy cold to warm can cause moisture in a motor cold this moisture be enough to create the white shitty oil in my catch?
Deleted User
« Reply #20 on: January 22, 2010, 11:50:33 AM »
the moisture is condensation it has nothing to do with coming from your motor, its normal to have whitish shit like that under the fill cap or in a catch can especially when the oil gets that cold on on winter days....if its on the dipstick thats a different issue, that could mean some sort of head gasket failure.
