Author Topic: frost plug on a 93 accord  (Read 11244 times)
Travis
« on: January 25, 2010, 09:12:28 PM »
i got offered to pick up a one of these fuckers for $1 USD/$300 CAD, but the frost plug leaks. Could I just jb weld the whole thing or would there be an issue since its an aluminum block?
Re: frost plug on a 93 accord
« Reply #1 on: January 25, 2010, 09:21:01 PM »
When I deleted my black box i put in a frost plug and JB'd it with no trouble.
Travis
« Reply #2 on: January 25, 2010, 10:29:37 PM »
well it sounds like its leaking a bit, so what if i just drain the coolant, and slop the fuck out of it? does jb weld stick to cold aluminum?
« Reply #3 on: January 25, 2010, 11:53:07 PM »
Try it...
« Reply #4 on: January 26, 2010, 12:05:50 AM »
Don't the plugs on an F series just screw in and seal with a crush washer?
« Last Edit: January 26, 2010, 01:55:32 AM by snm95ls »
« Reply #5 on: January 26, 2010, 12:07:52 AM »
90turboteg
  • Rebuildin turbos
« Reply #6 on: January 26, 2010, 12:36:09 AM »
Freeze plug? ya and i thought most hondas had screw in stlye freeze plugs... ive never seen a d b or h with a freeze plug in the block at my work.
so are you the same travis from ohmt?
« Reply #7 on: January 26, 2010, 02:59:07 AM »
Should just screw in with a crush washer, like stated b4. Replace washer and done.
« Reply #8 on: January 26, 2010, 05:41:10 AM »
Honda's don't have frost or freeze plugs.
Block drain plugs, yes.
If you leave water or a weak antifreeze mix and it gets cold, the water pump will crack, almost like a burst panel.
« Reply #9 on: January 26, 2010, 10:21:37 AM »
Frost/freeze plugs don't really exist.
Core plugs do exist though.  They sure do make it a lot easier to get the sand out of a sand cast block after casting.
 :P
