Author Topic: what headgasket??  (Read 10467 times)
jarebear667
what headgasket??
« on: January 27, 2010, 02:37:32 PM »
doing a g23
do you want to use an h22 headgasket?
or an F23 headgasket?
midwest HMT!
bouncinofftherevlimiter
Re: what headgasket??
« Reply #1 on: January 27, 2010, 04:05:05 PM »
depends on what bore you are using mine is 85mm, so i used the f22, 86mm go f23, 87mm go h22
No longer own a turbo car...
HX35 18lb 486hp/391tq
« Reply #2 on: January 27, 2010, 04:10:08 PM »
This man speaks truf.
« Reply #3 on: January 27, 2010, 04:11:11 PM »
jarebear667
« Reply #4 on: January 27, 2010, 05:10:16 PM »
excellent, well right now i have the problem of the piston sticking out the bore just a cunt. i have a je 10.5 87 mm piston. BUT we turned the dome off and then just a little more I'm guessing 10.1 now.but again its not becuz of the piston height on it. i threw the head on with some solder on the piston and turned it and it squished the solder a little. thats with no headgasket. im tepted to put it together but i dont want to run into an issue with it. and i can always have the combustion chamber machined (countersink) for the piston but im not game for that either. might throw a .045/.051" head gasket on it.. hmmmm  your opinions??
midwest HMT!
« Reply #5 on: January 27, 2010, 07:11:38 PM »
exactly how much is a "cunt?"
when you say it smashed the solder, how thick was the piece after it was "smashed?"
your best bet is to put it together with a stock head gasket, if you have one laying around, and clay check its clearances. a ".045/.051" would prolly be about perfect if its like what the domestics use for tolerances.
i know in the domestic world i come from you are looking for .040, the last SBC i built was .038 IIRC, and it actually left i slight little "ring" in the head where the piston contacted it, it wasnt actually dented, just a little shiny. the machinist kept saying how "perfect" it was.
what are your plans with this motor?
« Reply #6 on: January 28, 2010, 06:46:08 AM »
Measure the thickness of the solder, and piston to wall clearance.  We can't tell you shit otherwise.
jarebear667
« Reply #7 on: January 28, 2010, 04:27:10 PM »
yea i've done that
bolted the head on with the gasket and it was like .050ish. they recommend like .030 i read some place. on the honda
midwest HMT!
« Reply #8 on: January 28, 2010, 10:12:25 PM »
You're getting ahead of yourself, that is not your true quench clearance.  What piston to wall?
jarebear667
« Reply #9 on: January 29, 2010, 12:10:49 PM »
no idea just got it back from the shop the other day. im thinking it should be alright. fuck if i know.  and when your like we cant tell you otherwise. if you could elaborate on what you mean by how the piston to wall clearance would effect it would be cool becuz i dont understand why that matters, and it doesnt matter the heads on haha turned it over no binding or stopping or noises.
midwest HMT!
« Reply #10 on: January 29, 2010, 12:25:53 PM »
The piston rocks in the sloppy bore and reduces your actual quench clearance.
ochoa
« Reply #11 on: January 29, 2010, 02:44:51 PM »
wheaties box and mr. gasket copper spray  :mexi:
jarebear667
« Reply #12 on: January 29, 2010, 04:41:38 PM »
maybe on the intake not on the head and well idk thanks for the explaination lets hope i dont ahve problems.
midwest HMT!
« Reply #13 on: January 29, 2010, 07:34:12 PM »
Sir, I'm going to tell you this now - if you don't know your own piston to wall clearance then there's a problem, and the motor you're assembling might not hold together.  You really need a good machinist AND you need to be the expert on your engine if they are not.  This is how domestic machinists fuck up import engines - they go off of what they know and do a damn fine job of that, but it's not what the engine needs.
bb4caleb
« Reply #14 on: January 30, 2010, 03:20:05 PM »
he took it to a machine shop to get the bottom end assembled. the machine shop is actually pretty good with imports and im guessing they set the ptw at je specs. i havent personally talked to him for awhile but im sure its on the tighter end of that bc he didnt plan on alot of boost so prolly .003"- .004" jerry?
jarebear667
« Reply #15 on: January 30, 2010, 04:00:59 PM »
idk they just do what the manufacturer reccomends i'd have to ask. but i've been busy redoing brake lines on spic boys pony car.
dont worry jd im a pile of fail haha
midwest HMT!
