Author Topic: Bandsaw blades  (Read 29959 times)
Bandsaw blades
« on: February 09, 2010, 03:17:44 PM »
I have been ordering blades from grizzly and they have been ok.  What do you guys use?  Is there something better out there?  I have been running 64 1/2 14-18 raker for stainless and mild steel.  Just ordered up a raker 14 tpi and a raker 18 tpi non variable to see if they are any different but just grizzly blades.  The last one I had just didn't seem to last that long.
Re: Bandsaw blades
« Reply #1 on: February 09, 2010, 03:21:39 PM »
Cutting stainless is a bitch on blades. I would make sure you're not running the blade too fast. Too much heat will anneal the blade and then it goes to shit.
weirtech
    • Weir Technologies Inc.
Re: Bandsaw blades
« Reply #2 on: February 09, 2010, 04:12:47 PM »
cut with some coolant.  also break your blade in on something softer like mild or aluminum for a couple laps.
i get my blades made locally.
Re: Bandsaw blades
« Reply #3 on: February 09, 2010, 04:29:07 PM »
I will have to try breaking them in.  I run the saw on the slowest setting I can for stainless.  Blade doesnt get hot or really even warm while cutting.  I have played with shooting a little wd on the blade but have not done a full cooling setup yet.  I really need to mock something up.
Re: Bandsaw blades
« Reply #4 on: February 09, 2010, 04:54:54 PM »
I use just about any brand Grainger is carrying at the time. Morse, Starret, whatever. I always use the 14-18 variable raker and I have had good luck with them. Run them medium speed and keep the saw tensioned on the spring to not over heat them.
Re: Bandsaw blades
« Reply #5 on: February 09, 2010, 05:07:58 PM »
what are the grainger blades running you price wise?  they are about $25 from grizzly.
Re: Bandsaw blades
« Reply #6 on: February 09, 2010, 05:16:22 PM »
About the same. The last I bought was $23 I believe.
Re: Bandsaw blades
« Reply #7 on: February 09, 2010, 05:18:24 PM »
Just got an updated price of $28.xx  Matrix II bi metal with cobalt.
Re: Bandsaw blades
« Reply #8 on: February 09, 2010, 05:18:26 PM »
cool.  I am getting tired of these grizzly blades.  The last one I bought was bent at the weld and would lift up everytime that part came across the cut.  Blade didn't last long.  I should have complained before I broke it but I procrastinated.
Re: Bandsaw blades
« Reply #9 on: February 09, 2010, 05:25:33 PM »
We have all had our share of those. Corey had a bunch of defective blades.
Re: Bandsaw blades
« Reply #10 on: February 09, 2010, 06:29:15 PM »
I buy blades from acme tool crib in my town, there resonable on price around 25-30 and last a long time. there made in house so you can get them in any length ya need.
Re: Bandsaw blades
« Reply #11 on: February 09, 2010, 06:37:01 PM »
i buy mine at menards  (morse) or any other local place. there always like $8  for a 64 1/4" 14tpi  but my 1950 ?menards bandsaw which looks just like the one they sell at HF fucks blades up like nothin cause its so sloppy
« Last Edit: February 09, 2010, 06:46:44 PM by 7808 »
Re: Bandsaw blades
« Reply #12 on: February 10, 2010, 01:15:50 AM »
you guys might not believe me but ive been using the harbor frieght brand (central machinery i think?) bimetals that are 16.99 in store for the last year.
i shit you not they are the best blades i have used thus far. they last longer then starrett or lenox and cut just as well.
dont believe me? try it.
ive had 1 blade break on me right away, and harbor frieght asked no questions just told me to grab another one. the last blade i just changed was on for so long it was missing half the teeth and it was still cutting like a champ.
Toysrme
Re: Bandsaw blades
« Reply #13 on: February 10, 2010, 03:14:33 PM »
Buy a spool, weld them together. grind the weld down & hit it with a torch so itll be flexible
Re: Bandsaw blades
« Reply #14 on: February 10, 2010, 07:23:30 PM »
HF blades go to shit quick for me, home depot blades for $16 last me quite a while though. at least 3x as long as the HF
Re: Bandsaw blades
« Reply #15 on: February 10, 2010, 11:07:44 PM »
are you using the bimetal ones in the blue and yellow package?
the homodepot ones are fuckin trash they are not bimetal.
Re: Bandsaw blades
« Reply #16 on: February 10, 2010, 11:10:39 PM »
I always buy bi-metal no matter where I get it even home depot.
Re: Bandsaw blades
« Reply #17 on: February 10, 2010, 11:12:10 PM »
ive never seen a bimetal blade at HD. would be nice if they had them so i could grab one in a pinch cause theres a HD down the street from my shop.
Re: Bandsaw blades
« Reply #18 on: February 11, 2010, 07:52:30 AM »
i am about due for a new blade. i will post a pic of the packaging. maybe its a regional thing, im in FL.
i am really considering getting one of those blade welders at HF and making my own from now on. seems like it would be a lot cheaper
Re: Bandsaw blades
« Reply #19 on: February 12, 2010, 08:36:26 PM »
Wikus bandsaw blades are top notch. Lennox has gone down with the quality big time in the last year, we used to use a lot of them.
Re: Bandsaw blades
« Reply #20 on: February 12, 2010, 10:12:30 PM »
Here is what I get from homedepot. I usually use 18tpi not 14, but that was a quick search
jay
Re: Bandsaw blades
« Reply #21 on: February 13, 2010, 01:58:11 AM »
what band saw do you guys own?
I want you to die
Re: Bandsaw blades
« Reply #22 on: February 13, 2010, 08:19:46 AM »
HF
jay
Re: Bandsaw blades
« Reply #23 on: February 13, 2010, 12:21:16 PM »
HF
have you had anything break on it or had to replace any parts?
is it true they have a 90 day no hassle replacement warranty
I want you to die
Re: Bandsaw blades
« Reply #24 on: February 13, 2010, 01:52:20 PM »
i dont know about the warranty. i have have mine for 6-7 years without a single issue. thinking about buying another to make a stand up bandsaw. i hate converting mine back and forth and real stand up units cost too much
Re: Bandsaw blades
« Reply #25 on: February 14, 2010, 12:46:41 AM »
I use mine more as a vertical bandsaw lately, and it is annoying to raise it up. I wish they made a mid sized vertical. All i see are small wood bandsaws then the large metal saws, nothing in between.
jay
Re: Bandsaw blades
« Reply #26 on: February 14, 2010, 02:03:02 AM »
sorry stupid question
when do you cut with it in the vertical position and when do you cut in the horizontal position?
vertical = slide what your cutting through the blade?
horizontal = drop down the blade onto what your cutting like a chop saw?
i feel stupid...
I want you to die
Re: Bandsaw blades
« Reply #27 on: February 14, 2010, 02:04:55 AM »
Home depot sells a nice upright wood saw for $100 or so I am considering getting and changing the gearing for wood. I had one for a short time and considered doing it, but I returned it cause I needed something else at the time.
Yea Buk, that's pretty much it.
jay
Re: Bandsaw blades
« Reply #28 on: February 17, 2010, 06:16:16 PM »
k so im off to harbor freight to pick up a band saw and the blue flame welding helmet lol
I want you to die
Re: Bandsaw blades
« Reply #29 on: February 17, 2010, 06:20:19 PM »
Buk buy a bi-metal for that saw while you are there. The one it comes with is a piece of shit.
