Author Topic: OK, searching owns me. I need a new bearing for my dizzy  (Read 13841 times)
« on: February 10, 2010, 10:55:23 AM »
I need a new distributer bearing for my b18b. Ive looked and cant find a part number anywhere. I want to just go down to my local napa and say here it is, give it to me. Let me know if you guys find a part number for me.
Re: OK, searching owns me. I need a new bearing for my dizzy
« Reply #1 on: February 10, 2010, 11:10:06 AM »
God you're a useless lazy fuck.  Acura distributor bearing is Koyo # 6001Z or Lordco # 0782401
« Reply #2 on: February 10, 2010, 11:25:16 AM »
Thanks nog. And yes, im a lazy fuck. I did search but all i came up with was ones for accords.
« Reply #3 on: February 10, 2010, 02:23:03 PM »
Since your in spoon feeding mode, what's the P# for a d-seires?
« Reply #4 on: February 10, 2010, 05:11:58 PM »
The replacement bearing part for Civics (88-91 JDM Civic SiR, USDM 88 and up), USMD Accords (90 and up), and USDM Legends (88-90) is a Nachi Bearing. The part number is 6001NSL.
« Reply #5 on: February 11, 2010, 04:26:13 AM »
what about the seals????
« Reply #6 on: February 11, 2010, 11:24:55 AM »
Void if seal is broken.
« Reply #8 on: February 11, 2010, 01:33:05 PM »
0782401 is the right part. Napa sells it for $6.39 the bearing size is 28mm OD 12mm ID, and 8mm thick. Its a koyo 6001rs bearing, but it is listed under a diff manfact. Its just a relabled koyo bearing. To bad i couldent get the tooth wheels off. They are pressed on and i just said fuck it after almost an hour of trying to nigger rig sometning to pull them off. They are not keyed on the shaft so im pretty sure that i would never be able to get them repressed back on in the same exact location and my car would run like shit, or not run at all. So i ordered a new dizzy from www.acuraoemparts.com for $100 shipped. I dont even realy want to fuck around with nigger rigging something an obd2 dizzy with a jumper and all that. I just want the right parts.
« Reply #9 on: February 11, 2010, 06:37:30 PM »
100 BUCKS FOR A NEW oem DIST? 99.9999999999999% sure you ordered the wrong thing. Even the cdm ones are more than that
« Reply #10 on: February 11, 2010, 07:09:49 PM »
Well it dosent come with a ignighter, coil, cap, or roter.
« Reply #11 on: February 11, 2010, 08:04:22 PM »
You have a link? still sounds oddly cheap
« Reply #12 on: February 11, 2010, 08:24:26 PM »
« Last Edit: February 11, 2010, 08:26:00 PM by ryan89crx »
« Reply #14 on: February 12, 2010, 01:01:42 AM »
fuckin cheap
« Reply #15 on: February 12, 2010, 01:18:51 AM »
Dealz!!
« Reply #16 on: February 12, 2010, 03:10:50 PM »
No coil, igniter, or heat sink, hopefully yours are still good
« Reply #17 on: February 12, 2010, 04:48:49 PM »
Mine work just fine. I just need a bearing. Most expensive bearing ive bought for this car =(
