Author Topic: sbc blow through chevy short wide box update 4-3-12  (Read 97867 times)
Re: sbc blow through chevy short wide box update 7-2-10
« Reply #120 on: July 19, 2010, 12:00:52 AM »
Oh boy, what did Johnny delete?
« Reply #121 on: July 19, 2010, 08:11:03 PM »
I saw that last night and thought, "FUCK im to late" :noel:
« Reply #122 on: July 19, 2010, 08:15:16 PM »
I don't think he deleted anything, I think he failed at posting those pics, and had linked them through facebook.
« Reply #123 on: July 19, 2010, 08:21:08 PM »
Truth.
« Reply #124 on: July 19, 2010, 09:13:33 PM »
ringlands
« Reply #125 on: July 19, 2010, 09:54:01 PM »
opera mobile doesnt make it easy to get the facebook pic urls
« Reply #126 on: July 19, 2010, 10:34:47 PM »
Lots of classic Blissfaggot talking out of his ass.
Thanks for the lols.
« Reply #127 on: July 19, 2010, 11:55:20 PM »
Looks like you were up against one car.
Cadracer
« Reply #128 on: July 20, 2010, 02:23:57 AM »
Your fucking retarded if you think a btm is a good idea. Shows how much experience you have with anything remotely fast. First off anyone with forced induction experience will tell you what a pile the btm is. Please install one and tell us when that diaphragm breaks and takes out your super alloy sandcast junk sbc pistons. Or are you gonna blame the smoke on inferior valve seals like the rest of your cousins. If I have to explain to you why 0 degrees is a bad idea then it's not worth my time. Let me guess your using the factory advance springs still. You think having a spring counterweighted advance curve in a turbo car is a good idea? No wonder everything you do fails. In for blown ringland and cracked piston pictures.
Well time for me to chime in on the btm . Got it on 3 different motors and it has worked flawless. Have run a total of 18psi through it and never given me a problem. Runs daily 14 psi on it now and works great with timing at 14 base and with stock hei dist  triggering the btm box. no vacum advance just let the weights throw in the advance and i pull out 2 degrees max when im ripping on it. And yes this is a blow throw setup  with a wide band  and she never has an issue running lean unless the holley blue cant keep up due to restricted fuel line from the  stock tank  sending unit.
boosted 11.1 sbc in 12psi  melts pistons when you run out of fuel not because of the btm. That was before i got the wide band installed. Doesnt matter if i melt it down hell sbc  are cheap to build.
nos10racer
« Reply #129 on: July 21, 2010, 12:37:07 AM »
holley blues suck ass
79fairmont
« Reply #130 on: July 22, 2010, 06:17:26 PM »
Holley blue and 14 psi? What's your fp under boost with that set up?
Cadracer
« Reply #131 on: July 26, 2010, 10:16:25 PM »
between 45 and 48 psi  under boost. Got a fuel pump off a csi  injected mercedes and runs quieter than the blue also and produced more fuel pressure. Got a camera system fro my work with 5 cameras and so im gonna have video coverage of  all points of the truck while shes out and about. Got to do another marine motor install  and then i will have time to work on her to tweak on it some more. 20psi  boost ;D   wonder how far i can push the 305? :o
nos10racer
« Reply #132 on: July 26, 2010, 11:40:21 PM »
 :noel:   :yes:
thats awesome !! you still running the vortecs ?
Cadracer
« Reply #133 on: July 27, 2010, 12:47:28 AM »
Yes  i am  got a forged 11.1 sbc that i got some dart track 1 heads  with 2.08 an 1.6  valves and a solid roller cam looking for some boost love. All sitting on the engine stand waiting for its time. The caddy sits right beside it towering over it lol ;D 520 cubes decisions of what to install. the trans has the 3600 stall converter which works great for the small block but a lil big for the caddy im thinking 2500 stall  for it cuz it build lots of torque down low.After next week i will see what one i gonna put together to drop in. Working on the stand alone vortec fuel injection setup waiting on the guy to reprogram the pcm for my setup. Now that would rock  its sefi and vortec with boost.
May end up modifing my caddy intake with injectors  and wiring them in  see to many options  got delimas.  lol 8)
« Reply #134 on: July 27, 2010, 05:26:43 AM »
I can tell you from personal experience that a small block convertor will stall to about 2300 behind a 500 (actually 514) caddy.
Thow in the caddy, and boost that. Just do something about those god awful valve springs, or you'll blow em open. literally, they're that shitty.
  Give Jerry Potter a call (http://www.cadillacperformanceparts.com), he's done some sick shit with the caddy platform.  They are a GREAT bunch of guys, and I have done countless hours of personal work in their shop (buddies project car), free of charge, and even had help from them in a few places on the car. Advice from knowledgeable, older racers is irreplaceable. His son Richard is a genious as well, but had quite a scandal for a while concerning his "habit" and not turning out work. Stay away from him at all costs. He's fucked alot of people, some of who I know very well.
« Last Edit: July 27, 2010, 05:37:15 AM by keelay »
Cadracer
« Reply #135 on: July 27, 2010, 10:16:39 PM »
I got the valve system already taken care of. they hold up good to 6k but need to keep the damn rockers from falling off.
run it to 4500 then shift it  maked all the torque between 2600 and 4000 so when i grab next gear shes in the middle of the 550 ft lbs torque curve.  Had the setup together running na for awhile and now i am just addinq boost to it. 9.5 -1  with forged dish pistons and h beam rods  arp head bolts and arp main studs. Rear sump 8 qt oil pan with a set of sanderson headers and a one off dual quad aluminum high rise for dual 650 holleys end to end not side ways.  I will start a thread on the build.
68 TURBO truck up for sale 4500.00  any takers?
« Reply #136 on: July 29, 2010, 09:53:57 PM »
Talk to Johnny?
« Reply #137 on: August 25, 2010, 11:44:28 PM »
say goodbye to this engine its being retired and will be used on a different rig at some point in time
say hello to L98 + turbo/sc + 700r4.
i want to start driving the truck almost all the time because i like it a lot. gets shitty mileage how it is and i hate having to keep tuning it because of the 60 degree day and 110 degree the next day, hoping with 308ish gears 700r4 and the fuel injected motor it will be at least 20mpg if not more hopefully 25.
i am going to put a cam and my old heads on the L98 engine.
i want to make this a sweet cruiser and i failed with this lumpy ass huge cam NA motor + turbo it used a ton of gas and i am getting sick of the open dp and it running different from month to month and especially the low gears and 3 speed
Re: sbc blow through chevy short wide box update 8-25-10
« Reply #138 on: August 26, 2010, 12:18:24 AM »
Looks bad ass man! I want to see some rippers!
Cadracer
« Reply #139 on: October 09, 2010, 02:58:28 PM »
OK  guess i will be the only one with a turboed sbc.  Just an update the 305 now injestes 20 psi of boost and looks for more.
5.30 rt
2.12  60 ft
7.21  1/8th
79.9 mph
Gonna turn it up to 25psi here when weather permits.
« Reply #140 on: October 09, 2010, 04:12:50 PM »
5.30 rt
2.12  60 ft
7.21  1/8th
79.9 mph
L98 is a sbc! lol
Cadracer
« Reply #141 on: October 09, 2010, 05:55:40 PM »
taking the easy way out  gonna do fuel injection. Never had an issue with fuel concern on my tune from different weather.Maybe i got lucky and tweaked my carb just right.  aint l98 the gm code for the tbi ?
Did you ever dyno it or run it at the track? did it pull better than the mustang? 700r4 wont lie to long just lunched second gear on my trans time for the 400 with trans brake
« Reply #142 on: October 09, 2010, 06:29:41 PM »
l98 is the tpi.
i <3 fuel injection. if i was better at tuning carbs for blow through i might not care as much
when i was running around 10 psi it did pull pretty hard, i need to swap rear ends still... it does lay nice 2nd gear rolling rubber... locked rear end makes it go super squirrelly when it lets go
Re: sbc blow through chevy short wide box update 4-3-12
« Reply #143 on: April 03, 2012, 03:15:53 AM »
still runs, runs like a raped ape 10lbs.
broke flexplate about a month ago haven't replaced yet, weather has been horrible.
« Reply #144 on: April 03, 2012, 03:19:05 AM »
« Reply #145 on: April 03, 2012, 01:08:22 PM »
Bring that pile of shit to the dyno day princess  :O)
« Reply #146 on: April 03, 2012, 01:20:13 PM »
i also put straight 3" exhaust with the turn downs in the back like it was before. they are just 3" now with no muffler
Pages: 1 ... 3 4 [5]   Go Up
