Pages: 1 2 3 [4] 5 6 ... 26   Go Down
Author Topic: cummins discussion thread.  (Read 346702 times)
Re: buks welding FAIL thread
« Reply #90 on: March 05, 2010, 02:41:34 PM »
How about we isolate if it is the machine, or the hand control first.
Buk, undo the hand amp control from the machine. Set it for like 10 amps, proceed to strike an arc. Then set it for 100amps and strike an arc, there should be an obvious difference. If there isn't then it is the machine. If it is, there maybe something wrong with the hand control.
Re: buks welding thread
« Reply #91 on: March 05, 2010, 02:45:27 PM »
It looks like to me in this pic you have it setup for stick welding mode.
« Reply #92 on: March 05, 2010, 06:53:47 PM »
also is the remote switch an on/off or a variable type switch?
jay
« Reply #93 on: March 05, 2010, 08:31:55 PM »
apparently both the foot pedal and remote switch are not working as variable switches
they are just on off switches and the machine doesnt change weather i set it to 0 amps or 100 amps..
local welding store wants 70 bucks just to look at my welder.. lawl
im gonna go try again right now after i unplug the hand control
I want you to die
jay
« Reply #94 on: March 05, 2010, 09:15:28 PM »
ok so the amp dial on the econotig isnt supposed to work.. that for stick welding mode..
tig welding mode you can only control the amperage through the foot pedal or hand control..
but neither of mine are working.. or atleast the foot pedal is permanetly set at a high amperage and when i connect the hand control it makes a tamer arc so im assuming lower amperage..
I want you to die
jay
« Reply #95 on: March 05, 2010, 09:39:15 PM »
I want you to die
jay
I want you to die
jay
« Reply #97 on: March 05, 2010, 10:21:06 PM »
yep the amp control on the welder is just for stick welding mode..
« Last Edit: March 05, 2010, 10:23:11 PM by jay »
I want you to die
« Reply #98 on: March 05, 2010, 10:24:51 PM »
I can't believe both the foot and hand controls are fucked. That seems strange.
jay
« Reply #99 on: March 05, 2010, 10:34:49 PM »
im guessing its the machine itself thats fucked...
this guy fixed his.. but i am in no way going to be able to do the same..
http://weldingweb.com/showthread.php?t=35789
operating manual says its ok to blow out/vaccum the inside of the welder for what im assuming is dust..
ill open it up and have a look inside in a few...
this shit blows
I want you to die
« Reply #100 on: March 05, 2010, 10:39:23 PM »
See if someone experienced can work it.
« Reply #101 on: March 05, 2010, 11:27:21 PM »
This.
jay
« Reply #102 on: March 05, 2010, 11:28:50 PM »
god DAMN
I want you to die
jay
« Reply #103 on: March 05, 2010, 11:36:37 PM »
can i hose this bitch off with electronic parts cleaner? or just regular brake parts cleaner?
I want you to die
« Reply #104 on: March 06, 2010, 12:22:57 AM »
How much will you take?
jay
« Reply #105 on: March 06, 2010, 12:49:42 AM »
im gonna clean it out first and see what happens lol
I want you to die
jay
« Reply #106 on: March 06, 2010, 01:02:44 AM »
make sure it's plugged in when you clean it
dude thats nothing
this guy fucking PRESSURE WASHES his welders and claims its a common practice.. lol
http://weldingweb.com/showthread.php?t=34066
which makes sense because cell phones work even after you drop them in water (as long as you wait till they are 100% dry before you turn them on)
I want you to die
jay
« Reply #107 on: March 06, 2010, 01:03:48 AM »
im def gonna use brake parts cleaner or maybe man up and use electronic parts cleaner.
we shall see
I want you to die
« Reply #108 on: March 06, 2010, 01:09:41 AM »
dude thats nothing
dropped my cell in the water and all that works is the keypad and texting.
Sweet, so you can still pick up teenage girls?
jay
« Reply #109 on: March 06, 2010, 01:20:03 AM »
dude thats nothing
they don't like old guys without a job that drives his mothers car
clearly you know nothing about teenage girls.
I want you to die
bigwig
« Reply #110 on: March 06, 2010, 01:39:39 AM »
If you clean that gear up with anything but ultra care, you're retarded.
Why don't you just sell the welder on Craigslist for the same amount as you got it.  You're an Arab so you can just claim you got in an auction and you want to turn and sell it because your cousin who owns a gas station didn't want it because it's not a MIG welder.  Then hunt Craigslist for a Syncrowave 180 or a Lincoln 185 or a huge old Syncrowave 250.
jay
« Reply #111 on: March 06, 2010, 01:46:09 AM »
what the fuck is ultra care
i cant knowingly rip anyone off.. too kind hearted.. booooo
i cant afford a god damn syncrowave lol otherwise i would have bought it in the first place
I want you to die
« Reply #112 on: March 06, 2010, 02:04:37 AM »
Does air-duster not work?
It's what I use on all my electronics...
jay
« Reply #113 on: March 06, 2010, 02:21:56 AM »
doubt it.. i blew pretty fucking hard and this shit isnt budging.... its caked on...
someone on the miller forum pointed out that im missing my d pin..
but i looked at the back of the connector..
as you can see all the wires go somewhere.. doesnt look like there are any loose wires...
the wire that runs down along the bottom of the welder connects to something on the other side
only thing out of place on the welder.. that i could see.. was this wire connector that didnt have a wire connected.. but who knows maybe thats how its supposed to be..
I want you to die
SgtB
« Reply #114 on: March 06, 2010, 06:45:33 PM »
IPA in a spray bottle at as high of a % as you can get. I clean everything electrical with it at work. I have to remove big clumps of hardened flour and powders from boards all the time. Just let it dry before you power it back up, and don't soak down any transformers or pots too much. A toothbrush works good too.
jay
« Reply #115 on: March 06, 2010, 06:56:07 PM »
apparently im missing a pin a ground pin...
http://www.millerwelds.com/resources/communities/mboard/showthread.php?t=20986
I want you to die
SgtB
« Reply #116 on: March 07, 2010, 01:55:52 PM »
Still needs a good cleaning. Dust is mildly conductive. Metal dust is very conductive.
TTC
« Reply #117 on: March 07, 2010, 02:04:21 PM »
Buk do u know wtf you're doing? You will get yourself killed fucking aroudn in there.
« Reply #118 on: March 07, 2010, 02:10:11 PM »
+1
Test the welder by offering to give your brother welding lessons.
jay
« Reply #119 on: March 07, 2010, 04:45:49 PM »
well the previous owner def isnt going to be any help
the retard ran me in circles and now he isnt answering
for me its worth taking him to small claims because im a broke ass nigger
damn it this shit blows
so i got a busted ass econotig
200 cuft bottle that was empty.. (used it as core to get a full bottle for 45 bucks)
welder cart
foot control
hand control
gas regulator with cables.. and shit
for 800 bucks
i paid a cunt hair under retail is what sucks
and the faggot was firm on the fucking price
I want you to die
Pages: 1 2 3 [4] 5 6 ... 26   Go Up
