Pages: 1 ... 3 4 [5]   Go Down
Author Topic: B16a Dyno??? 12psi? 211hp!?  (Read 101432 times)
Re: B16a Dyno??? 12psi? 211hp!?
« Reply #120 on: March 22, 2010, 07:51:57 PM »
What the fuck are Cam Holders and Cams?  Because if they are what I am thinking, you haven't verified shit.
b20beast
« Reply #121 on: March 23, 2010, 08:47:36 AM »
there is a hole, which you can put a 5mm drill bit thru the cam holders and cams to verify they are 'UP'
« Reply #122 on: March 23, 2010, 08:49:20 AM »
Quit calling the CAM CAPS cam holders.
b20beast
« Reply #123 on: March 23, 2010, 08:50:34 AM »
cam caps go over cams, and cam holders over caps
« Reply #124 on: March 23, 2010, 09:02:45 AM »
Thought so.  Keep thinking about it, and good luck.
b20beast
« Reply #125 on: March 23, 2010, 09:17:25 AM »
next check for boost leaks...
I have a TiAL BOV, how do i check if that leaks!?
« Reply #126 on: March 23, 2010, 11:43:56 AM »
Pressurize the system.
TTC
« Reply #127 on: March 23, 2010, 03:33:32 PM »
What makes me sad is the 4age is like a lame gimped out version of the b16.  IIRC similar stroke, similar bore and without all the vtaks.
« Reply #128 on: March 23, 2010, 05:41:38 PM »
But there is that cool 20V head though.  Unless I am thinking of the wrong motor
TTC
« Reply #129 on: March 23, 2010, 06:19:59 PM »
No you're right.
« Reply #130 on: March 23, 2010, 06:24:26 PM »
then check for leaks
Pages: 1 ... 3 4 [5]   Go Up
