Author Topic: resistor box wires  (Read 18001 times)
resistor box wires
« on: March 31, 2010, 01:09:55 PM »
i got this resistor box out of an accord at the jy and it already had the connector snipped, im doing a mpfi swap.
i assume the red wire hooks to the wires that go back to the ecu, and you just use 'any' of the black wires to hook to the injectors?
there is 1 red and 6 black/identical wires
kgx
  • MR2fag
Re: resistor box wires
« Reply #1 on: March 31, 2010, 01:48:22 PM »
red wire goes to switched 12v. black goes to injector power supply
« Reply #2 on: March 31, 2010, 02:31:51 PM »
so the red wire goes back to the ecu, and any of the black wires goes to each injector?
« Reply #3 on: April 01, 2010, 02:21:11 AM »
anyone?
grand wizard?
« Reply #4 on: April 01, 2010, 02:51:41 AM »
Yes.
I have my power wire hooked directly to my key ignition power.
The other black wires go directly to each wire for the injector.
let me find my diagram
found this picture?.....
current background
grand wizard diagram
« Last Edit: April 01, 2010, 02:54:36 AM by Urban Indian »
« Reply #5 on: April 01, 2010, 03:43:40 AM »
Thumbs up to me :)
« Reply #6 on: April 01, 2010, 03:50:19 AM »
thank you good sir
bigwig
« Reply #7 on: April 01, 2010, 06:46:11 AM »
Why would a resistor box need a 12V source?  I can't think of a remotely good reason.
I hate resistor boxes.  Why anyone thought it was a good idea to run 4 signal lines in and then 1 out is beyond me.  I always used $1 inline resistors.  It was cheaper and easier to install.  Get a project box for $5.  Drill 4 holes through the resistor box.  Glue the resistors to the box.  Solder wires through resistor box.  Seal that up with glue/caulk/whatever.  Done and done.  $8 in parts and it always made more sense to me in the end.  Maybe I'm just retarded, but I always hated that 1 signal out line to go to 4 injectors.
« Reply #8 on: April 01, 2010, 08:17:28 AM »
Since the grounds are switched independently for each injector via the ECU, it does not matter.
Your individual resisters do the same exact fucking thing as a resister box with shittier packaging.
« Last Edit: April 01, 2010, 08:23:51 AM by snm95ls »
« Reply #9 on: April 01, 2010, 12:17:01 PM »
I really wished that Jordan took a better pic of JD when I did that poster
« Reply #10 on: April 01, 2010, 12:39:02 PM »
The resistor box works on the 12v side,   ecu grounds using the brown, red, blue, yellow injector wires.
« Reply #11 on: April 01, 2010, 12:47:58 PM »
I'm sure there will be more opportunities after the 5-15-10 rHMT PNW fluffy crew dyno meet. ;D
buk9tp
  • i know nuthin bout nuthin
« Reply #12 on: April 01, 2010, 02:17:04 PM »
They're not signal lines it's just a power source, dumbwig.  Events in DC electrical systems are actuated by grounding what is to be switched on, not by applying power to it.
bigwig
« Reply #13 on: April 01, 2010, 03:11:02 PM »
I'm well aware how injectors turn on and off.  I've also wired a few cars with resistor boxes.  By signal line, I meant the constant 12V source.  It still makes absolutely no sense to require another 12V switched source and ground wire for the resistor box.  "Oh, my car turned on, it's time to put those resistors on...."
I'll stick with my ghetto $8 method that functions exactly the same but make sense in my brain.
« Reply #14 on: April 01, 2010, 03:15:06 PM »
Apparently you don't grasp how most people wire in a resister box on a Honduh...
UI's diagram isn't 100% accurate, but you still get the drift.
The +12V to the injectors is switched via the MFR if memory serves me correctly.
bigwig
« Reply #15 on: April 01, 2010, 03:22:43 PM »
Yeah, they go to the dead end plug and wire it up.
I have a firm stance on working on 15 year old cars.  Don't start messing with the wiring unless you have to.  Thin OEM shit wire starts falling apart while you're wiring and you don't even know it.  So I go to the same dead end plug, but I cut the wires 8" from the plug and just wire them in.  One line in, one line out.  Very simple.  Impossible to fuck up.  Only 3' of wire to trace if something happens to break.
« Reply #16 on: April 01, 2010, 03:24:45 PM »
fuck, what are you guys arguing about?
is this how it should be?
« Reply #17 on: April 01, 2010, 04:13:16 PM »
Certain Japanese automakers, coughtoyotacough, didn't know how to run wires between the doors and the chassis properly a mere 10 years ago while my 20 year old pile of shit Honduh is wired correctly in that area.
I had to build a harness for my STD hatch because some fuckstick tried to do an MPFI conversion, and failed miserably.  Almost all of the wires I used were at least 17 years old.  No issues at all.
I can see your point though.
Yes.
Re: resistor box wires/tested the injectors and they are 12.5ohm
« Reply #18 on: April 01, 2010, 05:46:25 PM »
ok just for the fuck of it i decided to check the resistance across the injectors and its around 12.5, fuck so their already high impedence?
so i would just twist all the yellow/black wires together and send them back to the ecu?(12v switched)
« Last Edit: April 01, 2010, 05:59:30 PM by t_cel_t »
turbo4life
« Reply #19 on: April 16, 2010, 10:30:02 AM »
yellow black go to the main relay the grounds go back to the ecu.
so take all the 4 yellow black (+12V) wires and  twist together and run it to the red wire on the resistor box
<(looks like you have the one for an acura legend that is why is has 6 outputs)>
the run 4 of the black ones from resistor box back to injectors. and dont touch the other wires on the injectors they go straight back to the ecu.
End the fake food.
« Reply #20 on: April 17, 2010, 03:36:55 AM »
yeah i got this shitbox going, and yes the box was from an acura
« Reply #21 on: April 18, 2010, 12:35:59 AM »
For future reference & clairity: Injectors are constantly fed +12v switched on one side (yellow w/blk), via the main relay. The other side (multi-colored wires) run directly to the ecu, to the internal injector driver mosfets, which switch them to ground when they need to fire. It's kinda the opposite of how most electrical parts are fed, which is always grounded with a switch connected to +12v.
kgx
  • MR2fag
« Reply #22 on: April 18, 2010, 03:51:53 AM »
is anyone else embarrassed to see a 21 post thread on how to wire a goddamn resistor box?
« Reply #23 on: April 18, 2010, 07:19:22 PM »
In to say I posted.  :-X
Shit goes to hell without JD/???
arsenio
« Reply #24 on: April 19, 2010, 08:50:05 AM »
Jesus Christ, you Honda  tuner boys are fucking idiots.
If this is how you treat Hondas, no wonder you think rotories are voodoo garbage.
Will you miss me?
« Reply #25 on: April 19, 2010, 09:31:28 PM »
No we just don't want to win all the world speed/acceleration records. You know, like rotaries do.
« Reply #26 on: April 20, 2010, 12:32:34 AM »
I can't think of anything easier to install than an OEM Honda resistor box, Rass.  They are dreadfully simple to make plug in and out of the dead man's plug, so you can take it to other cars, in total 1/5th the wiring required for shitty hard-to-package and hard-to-remove inline resistors.  That being said I can't be too angry with you since you've never done it, only talked about it a bunch on the internet.
Especially when you gave the correct answer in the first reply, and then the fools doubted you?  I sure do feel embarrassed.
Locked, you flock of incompetent ninnies.
