Author Topic: eBay gaskets/seals  (Read 13061 times)
eBay gaskets/seals
« on: April 10, 2010, 12:52:57 AM »
Any of you used the eBay gaskets/seals? I figured they are probably just as good as the ones Vato Zone sells but unfortunately they don't have the ones I need. The OEM valve cover gasket is $16, or I can have the valve cover gasket/spark plug seals/top end grommets for the same price. Not sure how fitment or durability is though.
http://cgi.ebay.com/ebaymotors/92-93-1-7L-Acura-Integra-GSR-VTEC-Valve-Cover-Gasket_W0QQcmdZViewItemQQhashZitem3ca65bc669QQitemZ260489070185QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/94-01-Acura-Integra-GSR-1-8L-B18C1-Valve-Cover-Gasket_W0QQcmdZViewItemQQhashZitem3ca919fb45QQitemZ260535089989QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Re: eBay gaskets/seals
« Reply #1 on: April 10, 2010, 12:56:53 AM »
Pretty simple shit, not sure how they could fuck it up.  I think I paid $30ish for all of that at the auto store.
« Reply #2 on: April 10, 2010, 01:00:36 AM »
They actually had the ones for the valve cover gasket? Every one I have replaced I always went through Honda because they didn't carry them at the retail stores.
« Reply #3 on: April 10, 2010, 01:15:29 AM »
oem ftw!
« Reply #4 on: April 10, 2010, 01:31:15 AM »
Yes, the one on my build was around $30, I think I got it from advance auto, just search valve cover and they'll have a gasket or seal kit with all the grommets, the vc gasket, and the spark plug gaskets.
« Reply #5 on: April 10, 2010, 01:37:10 AM »
Yeah I looked and they did have it. I was thinking the vtec solenoid gasket not valve cover gasket. I'm pretty sure the cam seal is leaking on mine so I'm going to just replace the vtec solenoid gasket, cam seal, valve cover gasket, spark plug gaskets when I redo the valve cover.
« Reply #6 on: April 10, 2010, 01:53:16 AM »
i just bought a d series gasket set and it had everything, the spark plug hole grommets, vc gasket, the little rubber/metal for vc nuts.
like 32 shipped off ebay
« Reply #7 on: April 10, 2010, 02:10:05 AM »
Yeah the one I posted comes with all that and the cam seal. I just don't know how those ching chong meows measurements hold up.
« Reply #8 on: April 10, 2010, 02:47:36 AM »
There's quite a few ways OEM seals/gaskets differ from the cheaper ones. They don't have the same standards of quality when making the product. They're also made of lesser quality materials. OEM gaskets last 100k+ miles sometimes even 200k, I've yet to see any ebay gasket do that.
I use ebay gaskets, but OEM seals. I've found in many instances that the non OEM seals(or at least the cheaper ones) tend to not be the correct size. A prime example are the cam seals. The cheap ones are 1mm too small in OD. Enough of a difference for the seal to spin in place or a leak to happen with the slightest hint of blow by.
« Reply #9 on: April 10, 2010, 11:28:41 AM »
People will price out OEM shit at the stealership, but then wonder about ebay shit. Most parts counter guys set a huge markup on sub-$100 stuff. Price out OEM stuff at an online dealership like hondapartsdeals.com and you'll be much happier. I think that specific site also has $10 off of free shipping with some hater-tech,com code.
The one thing I'd suggest you do get is the OEM cam seal, specifically the newer p72/gsr version. That is if you don't get an LS head for free that has an STR seal in it like I did. ;)
« Reply #10 on: April 10, 2010, 11:30:54 AM »
I used a set of seals from ebay on my ZC and the bottom of my car looks like the exxon valdez wrecked.  OEM or nothing.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #11 on: April 10, 2010, 01:13:14 PM »
Erastic gasket set and ultra grey worked tits.
cost around 45 shipped for bottom and top end.
Only gasket I dont use is the head gasket and intake mani gasket.
Haters
« Reply #12 on: April 10, 2010, 01:41:30 PM »
They work great. I used them on 2 motor without problem.
« Reply #13 on: April 10, 2010, 03:18:50 PM »
I used a bunch of ebay kits, always had good luck with them.
« Reply #14 on: April 10, 2010, 04:21:44 PM »
I buy cheap gaskets and cover them in RTV.
ifly87
« Reply #15 on: April 10, 2010, 05:03:25 PM »
+1 used all ebay gaskets on my z6 build, ended up replacing the headgasket and started buying felpro's, but blew them too :P. Other than that the only gasket i've had leak was teh VC gasket, but a catchcan remedied that.
Lol...Fags
« Reply #16 on: April 11, 2010, 06:24:47 AM »
Eh I'll probably opt for the Felpro crap. I have used it before and it's only a couple bucks more than the eBay crap. Too bad they don't make the Vtec solenoid gasket, $25+ for that tiny seal is ridiculous. I don't know if mine is leaking or not, seeing as how it's right on the outside and takes 2 min to change I'll probably wait on that one unless I find out it's leaking  Jew
« Reply #17 on: April 11, 2010, 01:47:03 PM »
I'd personally use ebay before the felpro seals.
« Reply #18 on: April 11, 2010, 04:56:20 PM »
Why is that?
civiceggturbo
« Reply #19 on: April 11, 2010, 06:21:19 PM »
I bought a felpro oil pan gaket once, for whatever reason it was not the same material as oem and did not hold up. It leaked within a month and I have used ebay gaskets ever since.
« Reply #20 on: April 11, 2010, 06:26:14 PM »
I've used the eBay gasket kits on a few motors. For the most part, they work just fine. I wouldn't use the HG though
« Reply #21 on: April 11, 2010, 07:24:35 PM »
I bought an ebay gasket set for the miata. oil pan gasket was wrong, oil pump gasket was wrong, head gasket was too thick/probably not working properly, several other gaskets it came with were wrong too. I'll never buy another ebay gasket set.
« Reply #22 on: April 11, 2010, 09:11:09 PM »
I have used eBay gasket sets on a d16 and a b18. Everything worked perfectly
« Reply #23 on: April 11, 2010, 11:36:29 PM »
the Headgaskets are good the VC gasket and seals blow
turbo4life
« Reply #24 on: April 12, 2010, 06:05:04 PM »
i always use ebay shit 90% of the time. had good luck with them.  ill use a ebay headgasket for honda over any felpro crap just because the price is better and ebay shit from erastic gaskets is the same or better.  sometimes vatozone  if i need it the same day. felpro is know for being crappy.!
End the fake food.
« Reply #25 on: April 12, 2010, 06:17:20 PM »
headgaskets with copper spray are great
buk9tp
  • i know nuthin bout nuthin
« Reply #26 on: April 12, 2010, 08:03:38 PM »
Fuck you, Jay.
hatchboy
  • Bombs Over Baghdad
« Reply #27 on: April 12, 2010, 08:10:22 PM »
FUCK you buk and jay
« Reply #28 on: April 12, 2010, 09:44:26 PM »
RAWR STILL LOVES THE DICK!
hatchboy
« Reply #29 on: April 12, 2010, 09:48:39 PM »
