Author Topic: arp torque spec (rod bolts)?  (Read 12539 times)
« on: April 10, 2010, 05:40:47 PM »
Well i have always heard you "should" stretch your rod bolts when using arp's. but is this 100% needed? Can i just torque them to spec and not worry about the stretch?
Also i have tried to look for the torque spec for these bolts but can't find them and i lost my packaging to look up the part numbers.
Please excuse my super noob post.
thanks
Re: arp torque spec (rod bolts)?
« Reply #1 on: April 10, 2010, 05:46:59 PM »
Stretch is the best way as that is how fasteners work.
Which engine?
« Reply #2 on: April 10, 2010, 05:49:34 PM »
It's ls rods in a d16.
« Reply #3 on: April 11, 2010, 12:54:25 PM »
bump
« Reply #4 on: April 11, 2010, 02:33:03 PM »
Stretch is what ARP recommends.  I was a cheap ass and didn't get the stretch gauge so I just torqued mine down to the Honda specs.
« Reply #5 on: April 11, 2010, 05:46:20 PM »
Anything i should worry about just torqueing them?
« Reply #6 on: April 11, 2010, 05:47:55 PM »
I havn't had any issues, but I am also not the smartest  O0.  I tightened mine down loosened them up and then torqued them a second time.  Everything is still holding together.
« Reply #7 on: April 11, 2010, 07:53:35 PM »
ARP shows 26 ft-lbs with their special lube.
0.005"-0.0055" stretch.
« Reply #8 on: April 11, 2010, 08:10:58 PM »
I've built a few engines with just the torque spec and no rod stretch gauge. You will be fine.
« Reply #9 on: April 11, 2010, 08:52:48 PM »
Thanks guys.
hatchboy
  • Bombs Over Baghdad
« Reply #10 on: April 13, 2010, 08:05:54 PM »
I just torqued on mine as well. No stretch gauge.
theidealone
« Reply #11 on: April 13, 2010, 09:56:55 PM »
Also torqued mine to Honda specs, loosened, re-torqued.
« Reply #12 on: April 13, 2010, 10:39:45 PM »
Different motor, but I torqued mine to ARP's spec of 45 ft*lbs lubed with engine oil. It worked fine so far.
skaterdudz02
« Reply #13 on: April 13, 2010, 10:45:15 PM »
I never had a problem torquing it down to the factory spec + 10 ft lbs.
« Reply #14 on: April 13, 2010, 10:50:30 PM »
I torqued them to 28ft lbs.
hatchboy
« Reply #15 on: April 13, 2010, 10:53:40 PM »
I torqued to 73.5 in. ft. in. lbs
« Reply #16 on: April 13, 2010, 11:47:31 PM »
I torque mine to 30ft-lbs w/ ARP lube. :yes:
civiceggturbo
« Reply #17 on: April 16, 2010, 02:34:45 PM »
i torqued them like 3 or 4 times to make sure they seated
