Author Topic: Cheap Catch Can  (Read 14804 times)
Cheap Catch Can
« on: April 11, 2010, 07:16:03 PM »
Got my hands on a couple old oxygen bottles cheap (thanks noslo)  Made myself a quick catch can.  Cut the ends off, drill welded on -10 on one end for the drain, drilled out 1 1/4" hole for the breather on the other.  Then welded 2 -10s on the side near the top.  Cut a 1" diameter piece of tube the same length as the center section and welded it over the two -10s for a baffle.  Once that was done, weld the shit all back together.  Also took out about 8" in overall length.  Still more then big enough I think.  Just need to send it up to urban indian to get him to put a  :mexi: shine on it for me.  Also got the -10s welded on my valve cover a little while ago.  Just need to get a mount made up, move my battery and get this in the car.
Re: Cheap Catch Can
« Reply #1 on: April 11, 2010, 07:17:16 PM »
solid!
SgtB
Re: Cheap Catch Can
« Reply #2 on: April 11, 2010, 07:25:00 PM »
Pimp shit. O0
bigwig
Re: Cheap Catch Can
« Reply #3 on: April 11, 2010, 10:01:36 PM »
So this is what you needed all of that line for.
Re: Cheap Catch Can
« Reply #4 on: April 11, 2010, 10:04:37 PM »
Yes sir!
Re: Cheap Catch Can
« Reply #5 on: April 12, 2010, 12:22:25 AM »
Pimp!
Re: Cheap Catch Can
« Reply #6 on: April 12, 2010, 02:03:09 AM »
i  see wat u did thur
Re: Cheap Catch Can
« Reply #7 on: April 12, 2010, 02:10:11 AM »
that's one heavy bitch, but i dig the cheapness.
Re: Cheap Catch Can
« Reply #8 on: April 12, 2010, 02:22:36 AM »
So...  How much for one?  Don't need the -10 fittings though. I'm a cheapass that uses barb fittings?
Re: Cheap Catch Can
« Reply #9 on: April 12, 2010, 03:27:39 AM »
I could shine that
Re: Cheap Catch Can
« Reply #10 on: April 12, 2010, 05:07:59 AM »
Looks awsome except maybe the baffle. I'd have drilled some holes up it's length and stuffed that part with stainless steel wool, but that's assuming the goal is to capture & condense the vapors. Any reason you had to weld both ends of the tank? I'd probably just tack the baffel at the top and again as far in as I could reach. All I can guess is the stock threaded end had shit in it you couldn't use for the vent end.
Re: Cheap Catch Can
« Reply #11 on: April 12, 2010, 10:20:36 AM »
cut both ends off so I could tack both ends of the baffle and also I couldn't fit the bastard in my drill press with the ends on to drill them out.
TheMadScientist
  • I'm like Batman and Shit
Re: Cheap Catch Can
« Reply #12 on: April 12, 2010, 09:31:29 PM »
looks awesome! powder coat or polish it and and it'll look tits!
Re: Cheap Catch Can
« Reply #13 on: April 12, 2010, 09:41:16 PM »
Probably just going to paint it flat black.  I'm boring and dont need any of that bling bling shit.
Re: Cheap Catch Can
« Reply #14 on: April 12, 2010, 09:51:14 PM »
Nice work. I prefer using jb weld and an old Coleman propane tank+$2 fittings at my local plumbing store.
Re: Cheap Catch Can
« Reply #15 on: April 12, 2010, 09:54:26 PM »
That is pimp!!!
Re: Cheap Catch Can
« Reply #16 on: April 13, 2010, 12:31:07 AM »
I dig!
