Author Topic: electrolysis cleaning?  (Read 12085 times)
walter
« on: April 23, 2010, 12:55:35 PM »
anybody tried this method for clean a engine head or an engine block?
Re: electrolysis cleaning?
« Reply #1 on: April 24, 2010, 03:10:48 PM »
Nope.  I've used diluted acid and had that work wonders.
« Reply #2 on: April 24, 2010, 04:01:44 PM »
Any particular variety?
HNO3 or HCl?
« Last Edit: April 24, 2010, 04:03:16 PM by snm95ls »
walter
« Reply #3 on: April 24, 2010, 10:43:33 PM »
where is the How-to?  :D
kgx
  • MR2fag
« Reply #4 on: April 25, 2010, 12:02:20 AM »
i used it on an exhaust manifold a few years back. works pretty well, but it's slow as shit.
for cleaning cylinder heads, i use aircraft remover. stuff annihilates anything carbon-based including, but not limited to: paint, oil, grease, skin, apples, ferrets, red licorice and the non-metallic parts of vacuum cleaners. won't hurt the metal though.
for oxidized aluminum, i use diluted lye to etch the surface/eat the oxidation. cast aluminum stuff usually turns a dark grey (called smutting). you can de-smut it with dilute hydrochloric (muriatic) acid or nitric acid (harder to find, but works better and doesn't harm the AL, where as HCl will attack Al as well).
i got turned onto the lye trick with Al when i started anodizing some of my brackets/custom parts. these are the porsche caliper brackets and 3SGE manifold throttle cable bracket i did a couple weeks ago:
this is the throttle bracket fresh out of the dye bath:
it's really not that hard, just need some sulfuric acid and a battery charger.
caged
« Reply #5 on: April 25, 2010, 03:24:15 AM »
Any more info on the DIY anodizing.
I use subaru upper engine cylinder cleaner on blocks and heads, a few cans and an hour and the shit comes up new. :noel:
« Reply #6 on: April 25, 2010, 04:32:28 AM »
Yeah post a DIY. I want a powder coating setup but currently have nowhere to put a secondary oven.
« Reply #7 on: April 25, 2010, 06:20:30 AM »
I've used muriatic (HCl), but undiluted it will eat the shit out of the aluminum and turn it grey/black.  It needs to be super weak.
walter
« Reply #9 on: April 27, 2010, 09:09:54 PM »
i found a very good grease remover, ill post about it by tomorrow! it costs like 18$  :?:
walter
« Reply #10 on: April 28, 2010, 07:29:29 PM »
done!
caged
« Reply #11 on: May 03, 2010, 06:48:08 AM »
what was it?
