Author Topic: My $300 craigs list find  (Read 7719 times)
« on: April 25, 2010, 05:07:18 PM »
so, i have been in need of a truck for a while now. found this super mint 1990 chevy silverado with a rod knock for $300. body is almost 100% dent free it is 100% rust free and the interior gets a 9/10 for its age. boost will be happening soon and expect a build thread when it does happen
got the engine pulled today to make room for a 350 i have been holding on to for just such an occasion
Re: My $300 craigs list find
« Reply #1 on: April 25, 2010, 05:10:37 PM »
Wow, hell of a find.
« Reply #2 on: April 25, 2010, 05:13:17 PM »
booooooooooooooo 2wdr.  >:(
« Reply #3 on: April 25, 2010, 05:14:55 PM »
it ran really nice too other than the rod knock. the battery was done when i went to look at the truck and we had no way to jump it off. i figured it was well worth $300 even if it didnt run at all so i bought it. got it home and put a battery in it, fired up and ran great. took a prybar to all of the steering parts and everything seems tight too. i should be able to toss this 350 in and be on the road
i really have no need for 4wd. i am in flat as hell FL. the only off roading there is to do is plowing though the mud. 4wd is just something else to break. it has a bed and can tow a trailer, thats my needs
arsenio
« Reply #4 on: April 25, 2010, 06:13:45 PM »
How much for the distributor?
Will you miss me?
« Reply #5 on: April 25, 2010, 06:15:20 PM »
Nice find sir
« Reply #6 on: April 25, 2010, 06:23:01 PM »
i need the distributor for the 350 thats going in
ochoa
« Reply #7 on: April 25, 2010, 07:21:46 PM »
damd if those tires came with it they look worth the $300 themselves
« Reply #8 on: April 25, 2010, 07:30:28 PM »
The tires have about 50% tread left, but the sides are chewed up by rubbing behind the fenders. The guy I bought it from cut out whatever was rubbing so I guess they are fine now.
« Reply #9 on: April 25, 2010, 08:54:19 PM »
watercooled manifolds good for turbo, bakalah bakalah
« Reply #10 on: April 25, 2010, 08:57:05 PM »
is there something i am missing about the manifolds?
jay
« Reply #11 on: April 26, 2010, 09:13:02 AM »
i really need to dig up a picture of those...
I want you to die
« Reply #12 on: April 26, 2010, 11:50:09 AM »
I know boats have watercooled manifolds, is that what you are talking about?
« Reply #13 on: April 26, 2010, 02:08:50 PM »
old lulz
« Reply #14 on: April 26, 2010, 03:38:12 PM »
replace fuel pump ASAP.
« Reply #15 on: April 26, 2010, 05:09:37 PM »
And change fuel filters as often as you can (paper elements inside them clog with just a little moisture in the fuel) :?:
Also look at the wiring to the fuel pump you will see corroded connectors and it will give you headaches if not addressed. :yes:
Also if you have a metal side saddle fuel tank check for major rust from road salt/sand trapped between the cover and the tank and replace with new plastic one. :?:
You can use the larger injectors from a 454 TB for more fuel (2x 85lbs.)  ;D
Or switch to a multiport adapters setup from Edelbrock, TurboCity or other vendors out there and just switch PROMS in your stock ecu. :yes:
« Reply #16 on: April 26, 2010, 05:25:16 PM »
I am considering doing a multi-port swap. The wiring should be easy since all of the GM stuff is batch fire if I remember correctly.
Still trying to decide on how I'm going to run this 350 right off the bat. The ecu has a chip for a 305 right now and I'm just trying to get it running as cheap as possible and then upgrade later. I am considering trying to tune it if possible, but I might just try to find a 350 chip. So far my research says I just need an adaptor and I can use my ostrich to tune and then burn a chip.
« Reply #17 on: April 26, 2010, 05:30:44 PM »
Have you already checked Moates?
« Reply #18 on: April 26, 2010, 07:49:56 PM »
yesir. looks like all i need is this and some software
http://www.moates.net/product_info.php?cPath=64&products_id=36
