Author Topic: BDVT curse on the Shuttle. *You Bastard*  (Read 22955 times)
« on: May 02, 2010, 11:35:13 PM »
Last year- 412hp, B16 tranny stock. Gave the differential meth mouth and it exited the case.
Today- 478hp, oem lsd GSR tranny. Grinding all over the place, finally popping out of 1st on the launch, grinds 3rd, and won't recognize reverse at all. Also now has a violent wobble under acceleration.
"Best" run of the day was 12.90@117, fighting that bitch to go into 4th gear. Another 3 passes, another tranny swap. I'm thinking of the trashed LS, B16, and now GSR trannys I own, something good could be created. Heat treated gears, carbon syncros, obx LSD should do it.  BDVT is fat.
Re: BDVT curse on the Shuttle. *You Bastard*
« Reply #1 on: May 02, 2010, 11:37:25 PM »
Yoseph Davids details: 2nd gear burnout, 25x8.7x13 slicks at 9psi, 7k launch dumps. No feathering.  :noel:
« Reply #2 on: May 02, 2010, 11:39:01 PM »
sucks.....   did all of this happen when you launched the car?
« Reply #3 on: May 02, 2010, 11:39:36 PM »
Ouch, glad I'm poor enough to stay D series
« Reply #4 on: May 02, 2010, 11:40:16 PM »
preload and feathering the cluch is key....
car looks great!
arsenio
« Reply #5 on: May 02, 2010, 11:42:31 PM »
480hp for a 12.90...
Hondas are FUCKING SWEET!
Will you miss me?
« Reply #6 on: May 02, 2010, 11:45:43 PM »
OEM LSD?  I'm surprised it didn't exit the case, those are junk.  Go for GSR gearing, or 92-93 LS gears with the later 4.40 FD.
Your Yoseph Davids facts left out 60', and 1/8th mile times.
« Reply #7 on: May 02, 2010, 11:50:56 PM »
OEM ITR LSD is ok'ish though right? mine will be forever on street tires...
« Reply #8 on: May 02, 2010, 11:54:49 PM »
300-350 whp, they are a lot better.  Just don't wheelhop and you'll be fine.
« Reply #9 on: May 03, 2010, 12:04:01 AM »
FAt with a P son. fat with a P
« Reply #10 on: May 03, 2010, 12:07:51 AM »
thats my power range  :-\ ill try not to wheelhop, i got traction bars.
« Reply #11 on: May 03, 2010, 12:40:35 AM »
I'm having trouble locating the timeslips from today.
My rear dicks ebrake cables are incorrect, so I currently don't have an ebrake. I do what I can on the preload though.
If I remember correctly, my best 60' today was 1.9(7?), and that seemed to be the best it hooked ever. (3 runs today with 7k launch, 3 last year and launch was set at 5k).
For the 1/8th time, I believe mid 8's at high 80's? mph.
Today would complete my only 6 passes in this car.
Transmissions on hand/condition:
B16, great gears/syncros. Meth mouthed diff.
94-01 LS, great gears/diff, smashed syncros
OEM LSD GSR, unsure what the problem is at this point.
« Reply #12 on: May 03, 2010, 12:52:52 AM »
Pat ???
Like Fat Pat?
 :P
2slow
« Reply #13 on: May 03, 2010, 01:13:30 AM »
no tires hop thats where it counts i got the urethane motor mounts beotch
« Reply #14 on: May 03, 2010, 01:15:15 AM »
lol
« Reply #15 on: May 03, 2010, 01:17:39 AM »
bone will chime in and say that he has never seen a honda syncro go bad.
« Reply #16 on: May 03, 2010, 01:26:15 AM »
They wear and get hammered when you smash a not so willing trans into gear, but the teeth getting fucked up and causing crinding no. Selector sleeves do that, OR the suncro being hammered on enough and the cone/ inside of the syncro not allowing the gear to slow down.
Suyncros CAN go bad, just 90 percent of the time its the sleeves getting rounded off
2slow
« Reply #17 on: May 03, 2010, 01:43:57 AM »
i believe his last statistic was 1 in a 1000 bad trannys had a fucked up syncro
« Reply #18 on: May 03, 2010, 02:00:51 AM »
ive proven that wrong in 16 trannys with about 6.
Just have pootie and the blowfish tell you how all the ec fags make 700+ run tens and never break them.....
« Reply #19 on: May 03, 2010, 02:56:41 AM »
Syncros can't go bad because bone says so
« Reply #20 on: May 03, 2010, 03:16:32 AM »
that LS diff will fit in the B16 ring gear... DO IT...
Tre West
  • Solid Gold Studio Assassin
« Reply #21 on: May 03, 2010, 03:17:35 AM »
I blew a tranny in Tijuana once........ hey, shut up mang,,,,,,, I was drunk. It looked like a chick!!!
« Reply #22 on: May 03, 2010, 04:02:58 AM »
OEM ITR LSD will hold 650+ whp if you never wheelhop.
The teeth on the ring gear won't be so happy.
mid 8's in the 1/8????
8.36 @ 84 mph for a stock SOHC on spray.
« Reply #23 on: May 03, 2010, 04:47:03 AM »
Its agreed, stevemode sucks at driving almost as much as BDVT. lulz  8)
« Reply #24 on: May 03, 2010, 06:59:45 AM »
I'm betting Stevemode is using OEM shitty sloppy rubber mounts.
« Reply #25 on: May 03, 2010, 07:52:39 AM »
NEC fags you mean, we strip them out every couple events.  The transmission needed to hold a 26" tire costs as much as the 650 whp car does.
« Reply #26 on: May 03, 2010, 09:31:10 AM »
With roofing eurathane? Yep.
"I got the eurathane motor mounts, beeyatch"
« Reply #27 on: May 03, 2010, 11:22:36 AM »
lulz!
« Reply #28 on: May 03, 2010, 12:21:14 PM »
I bet with some more track/seat time you can hit some mid 120mph's in the trap bummer about the brown tranny! Youz gots tration barz YO?
« Reply #29 on: May 03, 2010, 12:23:07 PM »
Seriously though, you could do WAY better, shouldnt have much trouble making a trans that will take the beating.  You need to cut some better 60's, WAYYYY better 60's  1.97 60 on a 26in slick?? are you even launching or just rolling off the line?
