Author Topic: Dyno Results, BW S362, Talon  (Read 9243 times)
ju-on
« on: April 03, 2009, 12:12:17 PM »
Went and got a tune at DB Performance in Rogers, MN last night.  Made some decent power.  Also keep in mind this is an AWD Dyno Dynamics (tend to read around 15% lower then a dyno jet).
I'm pretty happy with the results.  Should be able to break into the 10's with a capable driver (not sure if I'm a capable driver though).
Video:
4/2/09 Talon Dyno
« Last Edit: April 06, 2009, 07:32:11 PM by ju-on »
Brandon
1991 TSI AWD
Holdin down the North TC Burbs
Re: Dyno Results, BW S362, Talon
« Reply #1 on: April 03, 2009, 12:15:31 PM »
who cares
where is the vid negro?
nice pull either way
« Reply #2 on: April 03, 2009, 01:04:10 PM »
Did I read that right that 45psi of boost?
« Reply #3 on: April 03, 2009, 01:04:42 PM »
Sad, I was told S362 spools like a T3/T04E and it's obviously a little laggier.
ju-on
« Reply #4 on: April 03, 2009, 04:24:15 PM »
It was 35psi, tappering off to about 32 by 8k.
On the street I see about 15psi by appx 4600rpm, 30 by 5000rpm, and 35 by about 5200.
My old TO4E 50 trim I'd usually see 25psi by about 4500.  So it is a little bit laggier, but still have nearly 3000rpm where I can be in full boost, so I'm pretty happy with it.
Brandon
1991 TSI AWD
90dx
« Reply #5 on: April 04, 2009, 04:55:50 PM »
Nice that must be nasty on the street with the AWD :yes:
98redcavz24
  • NE Crew
« Reply #6 on: April 04, 2009, 05:28:48 PM »
Agreed, I wouldn't wanna run up on that 8) Sol-id power
ju-on
« Reply #7 on: April 06, 2009, 07:28:54 PM »
Thanks for the comments.  I've been trying to put up the video here for the past couple days but the site wouldn't load for me.
Anyhow, I added the quick little video we made, to the first post.  Enjoy!  And thanks again for the comments!
Brandon
1991 TSI AWD
« Reply #8 on: April 06, 2009, 07:34:02 PM »
If it lasts longer than a week, I can slash your tires and challenge you to a race with this shizzle.   :noel:
ju-on
« Reply #9 on: April 06, 2009, 07:36:58 PM »
Ha, aint that the truth.
So far she's hanging in there.  Definately need to line em up, and get me spankin you on tape  ;D
Brandon
1991 TSI AWD
« Reply #10 on: April 06, 2009, 08:28:35 PM »
You're AWD, so I get a 1319 foot head start.  O0
ju-on
« Reply #11 on: April 07, 2009, 01:34:09 PM »
Sounds fair enough. 8)
Brandon
1991 TSI AWD
« Reply #12 on: April 07, 2009, 03:29:54 PM »
Man that car would be fun, I love how smooth the dyno graph is. It must feel like the hand of god just picks you up and throws you down the road when you punch that bitch.
Now if you can get everything that is bolted to the motor to last, you will have a solid car.
MantisX
« Reply #13 on: April 07, 2009, 04:08:05 PM »
Id love to see a ripper of this thing. Did I read correctly that youre running a t04e at 30+ psi? I thought those turbos starting getting really inefficient that high in boost.
« Reply #14 on: April 07, 2009, 05:34:32 PM »
He is running a B.W. S362 . Thats why the title says bw362 talon.
MantisX
« Reply #15 on: April 07, 2009, 05:46:40 PM »
Oops, got tied up in the short convo about to4e/S362 spool time.  :somb:
skinnye
« Reply #16 on: April 07, 2009, 06:04:17 PM »
sweet man, didn't this car use to me multi colored back in the day?
ju-on
« Reply #17 on: April 07, 2009, 06:19:20 PM »
Yeah it's a Borg Warner S362.  Has Bullseye's Race comp cover, and a .70AR Exh Housing.  For comparisons sake to help put things into perspective, it is somewhat similar to a GT35 sized turbo (61mm comp wheel).  But the S362 has a 62mm comp wheel, has Extended Tip Technology which supposidely helps that comp wheel flow more air at higher boost then a similarly sized comp wheel without Extended Tips.  So it flows a bit more then a GT35, but is probably the closest Garrett comparison I  can think of.
So to answer the question about being inefficient at higher boost, my research showed the exact opposite.  The Extended Tip Technology is supposed to make these things shine at higher boost.  Supposed to allow them to flow more air, at higher boost levels then a similarly sized comp wheel without ETT.
Brandon
1991 TSI AWD
ju-on
« Reply #18 on: April 07, 2009, 06:20:34 PM »
Hell yeah.  She's come a ways since those days :)
Brandon
1991 TSI AWD
ju-on
« Reply #19 on: April 13, 2009, 10:26:32 PM »
Just to see it with my own eyes, I decided to head to the local shop (MAP) that has an AWD DynoJet, to see if the Dyno Dynamics really does read that much lower.
My results pretty much proved it spot on.  I saw a 16% difference.  Here's my sheet from the 3 quick pulls on the DynoJet.
Brandon
1991 TSI AWD
« Reply #20 on: April 13, 2009, 10:56:49 PM »
You're fuckin crazy, and it's good.
« Reply #21 on: April 13, 2009, 10:58:27 PM »
Man thats tits. Good job, for making it last longer than a week.
