Author Topic: got a car dumped off to me to fix, not having any luck, need you nogs to help  (Read 13007 times)
Super Dipper
  • Boost, Boobs, Beers
98 GSR
stock block
CP 9:1's
Eagle rods
ARP head studs
Stock intake manifold/TB
GSR cams
Greddy turbo kit
Hondata S300
550 RC injectors
Stock fuel rail
B&M hacked FPR/Gauge combo
2.5" DP
AEM 3.5 bar map sensor
AEM wideband
The car was tuned back in november and it made 294 at 9 psi. It was a solid tune, car pulled great no issues what so over.
Apparently previous to this, the guy who put the turbo kit on the car made 187 on the same setup and corked 2 pistons in the process of tuning the car....
fast forward to now and the owner of the car brought it to me and he says that its not running right and the AFRs are always showing lean.
he got the motor redone, but can figure out why its still running lean.
when i say lean, i mean sitting at idle the car stumbles and farts around the mid 17:1 - 18 or flatline lean, under part throttle cruise it hovers around 15.5-16.0 and in boost its running around 13.3-13.8
Now when the owner had the car tuned back in nov, i was there for the dyno session and i drove this car with the same setup and it was running quite differently. it idled around 13.3-14.5, part throttle cruise around the mid 14's and it was 12.2-12.5 in boost. very steady,stable tune. now its gone to hell.
I start digging into it and suspected a faulty wideband. AEM doesnt have the best track record so i toss a replacement sensor in, still shows the same wonky readings.
its got a walbro 255 in it and ive had issues with some not having enough voltage so i wire up a relay, and i get a small change at idle but its still lean as fuck throughout the rest of the map.
I decide to swap out the walbro and S300 with a spare set i have lying around, no change. Im down to either faulty injectors or a reg thats taken a shit, but havent had a chance to swap those out for stock to see wtf is going on. We have fucked around with the inital tune on the ecu to see if we get any varience and no registered change is visable on the wideband.
So im at a loss as to wtf is going on. never ran into a stubborn POS that wont cooperate even after swapping stuff out.
Need ur help boys to get this car off my fucking driveway so i can get the mini and AWD CRX done and out of my hair.
Formly Quadtech...
Team 4 MotorSports
step 1 throw on oem used b series fpr
Fuel filter been changed yet?
Clean Injectors?
Is it burning oil?
If it burns oil it will affect the AFRs.
Is the vacuum line to the fuel pressure regulator in good shape?
Is the IM mount bolts tight?
Is the TB gasket leaking air behind the throttle plate?
Is the brake booster vacuum line good shape?
Is the charcoal canister purge staying energized all the time?
If I have any more ideas I'll post more. ;D
mabey air temp comp needs to be ajusted?
That'd the first thing I would have tried before swapping parts. And then like Chris said switch out the fpr for a stock unit. and of coarse you checked for exhuast leaks.
If you have a constant misfire, it will read hella lean... Just sayin O0
It could be the fuel pump konking out. Stick a remote gauge on it and see what it reads. Just make sure to use an electronic gauge.
Super Dipper
you guys kick ass, i know i can count on you nogs when the dipper runs out of ideas, lol.
Chris: ill swap that out and see if i get any change.
HiProfile: dont have a constant misfire, there is a gauge coming right off the rail reading 50psi base pressure
DMC and Lilpooh: yup checked for exhaust leaks, nothing visable at the turbo to DP or DP to exhaust. the IAT and air temp comp thought was totally bypassed by me. completely forgot about that. ill pop the IAT out and make sure its not gummed up and giving any sort of faulty readings back to the ecu.
92CXyD:
fuel filter has been replaced along with the fuel lines right from the firewall hardline. -6 full flow out of the steel line to a russell -6 full flow fuel filter to the rail. all new.
injectors look clean. they have been in the car since the initial turbo kit was installed and they have now seen 2 blowups im assuming but i didnt see any shit or debris in them, so i cant say for certain if they are clean or dirty. the nozzles looked to be clean and there was no shit in the inlets to the injectors when i did take a quick peak at them.
The motor is new. he had it put in by a local tuner before bringing it to me. its not burning or huffing oil/smoke
i replaced the vac line to the fpr bc it wasnt in good shape.
IM bolts are tight
TB gasket is new(er)
brake booster line is mint
no idea about the charcoal canister. you got me there. lol
Formly Quadtech...
Team 4 MotorSports
You had to ask?
FYI, a fresh engine is going to run completely different.
AFR showing lean, but what do the plugs look like sir?
check the fuel line from the rail to the fuel filter, I used some missmached shit and had good fuel pressure at the filter and blocked off the flow to the rail. Wrong crush washers/wrong hose/rail combo = fucked.
TheMadScientist
  • I'm like Batman and Shit
You had to ask?
[/quote]
Fix that and get a retune. Problem solved.
Super Dipper
swapped the reg. issue was still present.
pulled out the injectors, swapped with a known good set and bam! cars runs mint.
thx for all the help nogs.  O0
Formly Quadtech...
Team 4 MotorSports
