Author Topic: K Swap Honda FIT - Mini van  (Read 15927 times)
K-fit
« on: June 01, 2010, 07:02:09 PM »
Current list of parts that I can think of off the top of my head.
K20Z3 Engine and transmission
RSX shift linkage
stage 2 axles
Jackson racing custom swap header
Jackson racing Fit exhaust
Jackson racing supercharger
hondata Kpro
Hasport mounts, and adaptor harness
06 Si shift knob
06 Si pedals
racer coated valve cover
Advan RG2 with falken tires Rt 615
Fast brakes.com rear disc convertion
Fast brakes.com front brake upgrade
Progress auto street coilover s in front and street shock and springs in back
Progress auto Rear sway bar'
I am dealing with a little over heating, the engine gets up to 210 on the track and daily driving gets to 205 sometimes higher, so I put some hood risers in the back of the hood to lift it up and let some air escape, but I need to get a vented hood to help more. I also have 2 thin fans on the raidiator that help but I think I might need to get an aftermarket one to get the temps down. I m allready using 1 step cooler spark plugs, and on the dyno with air the car is fine. its the stop and go traffic that is the issuse.
some other misc stuff.
I went to Pacific Raceways to run the 1/4 mile.
It was very very long ass wait time to just Run one run. we got their around 11am, and didn't get to run street tire class until 1:30pm. by that time I was sunburn and extremely bored and just wanted to go home.
So I pull Around the water box and line up, watch the guy give me the signal to burn out, so I do a 2 or 3 sec burn out and go past the staging lights a little like 1/2 car.. embarrassed I put it into reverse and get to staging lights.
needless to say people were laughing at me in the stands.
So next to me a 2010 TSX with comp tech supercharger pushing 9 lbs boost.  I didn't pay it any attention just thought to my self Crap all i get is one run , lets get this over with so I can go home.
I have Never Done professional drag racing at all, I only know what i know from just street racing, and learning by watching the other cars go as well.  I have a new respect for the pro drivers because Drag racing is actually harder then i thought it was going to be.  Never underestimate the dam tree, and by all means learning the track / feelings of how sticky for grip it is are very hard for me with this car because 1 run.
Anyways, I launched at like 3k rpm and lit up 1st gear though redline - spinning wheels.
shifted into 2nd gear and roasted the tires a little more, untill they hooked around 6k rpm then finally snapped me into the back of seat like I was driving a new car. I said to my self wtf nice traction all of a sudden, so redlining 2nd, shiffted - then 3rd shiftted again, into 4th and then it was over.
I ran a 13.2 @ 108. New track / never dragged raced before with the k motor, and 17" Advans with good year fearce crap tires LOL..
I was in the right lane.
My friends say I could get into the 12s very easy with 1 actually doing a few passes to get a better hole shot, and not spining 1 and 2nd gears.  also if I had drag radials ?  I could shave alot of time as well.
I did not build this car for Drag - its a time attack / super lap battle car so I'm glad to see it did ok, but I dont think Im going to go back to the strip anytime soon.
My L15 Stock ran a 17.01 and with a swap ran 13.2 very possibly into the 12/s.
Video with music
Video without music
For the Red Necks
« Last Edit: June 01, 2010, 08:00:34 PM by K-fit »
Re: K Swap Honda FIT - Mini van
« Reply #1 on: June 01, 2010, 07:07:54 PM »
Nice, was this at the PNW fluffy Crew RHMT Dyno Day 5-15-10?
I like it but you need check out this thread for noob post before Wendsday happens. ;D
http://www.realhomemadeturbo.com/forum/index.php?topic=25.0
Just some friendly advice. ;D
Yeah I see you posted in the DynoDay photo thread with some PG-13 picts.
« Last Edit: June 01, 2010, 07:15:41 PM by 92CXyD »
« Reply #2 on: June 01, 2010, 07:08:05 PM »
did your boyfriend build the car or did you acually do it yourself? I like girlys who work on there own shit  :yes:
TheMadScientist
  • I'm like Batman and Shit
« Reply #3 on: June 01, 2010, 07:11:30 PM »
WTF is wrong with you! where the hell are the boobies! You must present boobies to be accepted here! You sir are Failing quickly post pronz immediatley to avoid Wednesday!
Edit: Even worse you posted semi-decent pics in your other posts and fail at this your most import post here. Wow, you sir are a failure and much is necessary to make up for the dissapointment you have brought. Now please will you and your POS minivan please leave and don't come back till it's full of pronz. Thank you.
« Last Edit: June 01, 2010, 07:14:17 PM by TheMadScientist »
TheMadScientist
« Reply #4 on: June 01, 2010, 07:20:24 PM »
WTF is that shit! This is not a site that gives a fuck what faggot ass car your magazine was in! Your ignorance saddens me and makes baby jesus cry. You sir should kill yourself!
Edit: Better  :-\ not great or earth shattering but better keep trying and you may succeed onne day
« Last Edit: June 01, 2010, 07:27:10 PM by TheMadScientist »
« Reply #5 on: June 01, 2010, 07:26:13 PM »
Car was pretty cool to see at the dyno day. Fucker sounded pretty cool too. To bad your belt was slipping when you were on the dyno. Oh well. 108 trap is moving pretty good. Not bad for that low of boost.
K-fit
« Reply #6 on: June 01, 2010, 07:35:46 PM »
No - I built the motor , was published in honda tuning
Hasport used the car to mock up the mounts for the swap - basically they did the install of the swap because I didn't have the Equipment to cnc the mounts, and make the harness nessasary for everything to work. but i installed the charger , suspension, and everything else and tuned it.
 ill start off small so you can comprehend what I have built, not to mention other race cars projects.
Ek rebuild complete from groud up
K20 build for Eg
pic of the engine K24 engine build im lookign for the supercharger pics
video of the NA MEGAVIDEO - I'm watchin' it
K24 supercharged Ep3 325 @ 8 psi
300 Hp @ 11 PSI
450hp @ 13psi RSX
all of witch I personally Built tuned and ran, I have alot of tunes under my belt all K series.
Super Dipper
  • Boost, Boobs, Beers
« Reply #7 on: June 01, 2010, 07:49:48 PM »
just an observation but:
A) no one will care to comprehend what you have done or built because you will not be impressing anyone. ppl on here wont give a shit, especially about a K Series
B) failing to meet the prescribed guidelines of a intro post, regardless of if you were at the dyno meet, does not give you automatic pass.
C) no one cares about k series or magazine ads here. You want praise, go over to Honda-tech.
Should you decide to rectify this slight oversights, all will be well.
If not, then im sure you will meet wednesday pretty soon.
take care.
Formly Quadtech...
Team 4 MotorSports
NaturalDecimal
« Reply #8 on: June 01, 2010, 07:51:25 PM »
Clean looking cars. I like the powerband on that dyno sheet, something akin to the batman/robin ride at six flags. And the porn is well done.
The magazine article is pointless though, delete it. The whips are nice and if someone gives a shit about them they will ask you to post more. Don't assume we care about K-series garbage, they are just for Chris and JD to fawn over together while sharing a bowl of ramen and a high life.
K-fit
« Reply #9 on: June 01, 2010, 07:56:31 PM »
Yeah I only added the article to let you guys see the install.
deleted that shit ~ for one i don't need praise...
Seems im the only K series guy around here is why I haven't posted anything
« Last Edit: June 01, 2010, 07:58:57 PM by K-fit »
« Reply #10 on: June 01, 2010, 07:59:43 PM »
Anymore of her or some big titty redheads? ;D
BangBusMaster
« Reply #11 on: June 01, 2010, 08:02:57 PM »
Are you the dude that had the electronic stethoscope?
K-fit
« Reply #12 on: June 01, 2010, 08:03:43 PM »
Yes sir -
K-fit
« Reply #13 on: June 01, 2010, 08:04:55 PM »
Yea, I made it out a fucking old folks hearing aid
oh one more pic i left out
BangBusMaster
« Reply #14 on: June 01, 2010, 08:07:15 PM »
Thanks for letting me use it. I liked it, but it seemed to have alot of extra engine noises. I'm sure placement may help.
« Reply #15 on: June 01, 2010, 09:21:49 PM »
I own some K series stuff:
http://www.realhomemadeturbo.com/forum/index.php?topic=9848.0
Just picked up this one too:
RSX Engine grenading from over rev
So yeah another K head slice thread is comming...
« Last Edit: June 01, 2010, 09:23:57 PM by Foowee »
« Reply #16 on: June 01, 2010, 09:55:48 PM »
I'VE SEEM MORE K SHIT IN THIS THREAD THAN CUMULATIVELY SO THIS FAR HERE.
So that gayness aside...  welcome man. Your car is cool and so were you.
This is Brian with the accord.... the red one
:o)
« Last Edit: June 02, 2010, 03:35:29 AM by bigdaddyvtec »
« Reply #17 on: June 01, 2010, 10:02:20 PM »
This is Spiker, the fat ass, sunburned, mothfucker with the accord.... the red one
:o)
« Reply #18 on: June 01, 2010, 10:04:49 PM »
Cool Fit and good job on the pronz
« Reply #19 on: June 01, 2010, 10:40:28 PM »
You have my undivided attention.  Is there anything you'd like to add to that?
« Reply #20 on: June 01, 2010, 10:49:33 PM »
You love those long horse face hoes dontcha yosephs? HEEEEHAWWWWW NEEIGGGHHHHHHHH horse fucker
« Reply #21 on: June 01, 2010, 10:52:58 PM »
All I see is TITS!
Super Dipper
« Reply #22 on: June 01, 2010, 10:53:17 PM »
Ive played a bunch with the K's. My loyalty resides with the D's and B's
I might finish this soon
http://www.realhomemadeturbo.com/forum/index.php?topic=479.0
good job on the updated post.
Welcome.  ;D
Formly Quadtech...
Team 4 MotorSports
notfastcrx
« Reply #23 on: June 02, 2010, 12:37:45 AM »
wow, who's this broad?
« Reply #24 on: June 02, 2010, 01:17:02 AM »
Is it just me, or do all huge tit girls whine about their boobs hurting (when you're playing rough)?
K-fit
« Reply #25 on: June 02, 2010, 01:23:32 AM »
kool man - good to see one else around here with a k .
Posted by: Super Dipper    Posted on: Today at 06:53:17 PM
Insert Quote
Quote from: K-fit on Today at 03:56:31 PM
Welcome.
that is one awesome project you have going.
notfastcrx    Posted on: Today at 08:37:45 PM
Insert Quote
Can't remember her name , ill post back once i find it.
Posted by: bigdaddyvtec    Posted on: Today at 05:55:48 PM
Insert Quote
So that gayness aside...  welcome mam. Your car is cool and so were you.
Hey man! thanks for the welcome!
TheMadScientist
« Reply #26 on: June 02, 2010, 11:31:19 PM »
Judging by the amount of boobies in your last few posts you're getting the idea you may prove to be a productive member of this site. Continue on with the good work
oh and:
FAKLAD
;D
flat_black
« Reply #27 on: June 03, 2010, 12:05:21 AM »
Not real sure why people hate on the K so much?? its spendy but people make more power, reliably than any other BDH series..
Anywho welcome, We met, (black 240)
« Reply #28 on: June 03, 2010, 12:17:43 AM »
Que JD K hate propaganda
« Reply #29 on: June 03, 2010, 12:44:29 AM »
HATE HATE HATE
