Author Topic: locked up brakes.  (Read 17760 times)
fysh
locked up brakes.
« on: April 05, 2009, 09:34:05 PM »
Ford Lightning:
Brembo Slotted Rotors
Hawk Ceramic Pads
Stock Calipers
Stock Master Cylinder
Without any warning front brakes locked up @ a stop light. Had the current brake set up for 2 weeks with NO issues. Now all of a sudden it chatters HARD and locks the front wheels down tight. Checked the lines and have no kinks. I'm assuming weak brake line internal walls or bad master cylinder. However, its odd that the brakes work perfect when driving in reverse, why is this?
Re: locked up brakes.
« Reply #1 on: April 05, 2009, 10:43:13 PM »
Some bolts are loose. Retorque everything. Should have used thread locker on all the bolts, bet you didn't. Does it one wheel or both?
« Reply #2 on: April 06, 2009, 04:04:58 AM »
check valve
caged
« Reply #3 on: April 06, 2009, 05:42:09 AM »
Check valves are for drum brakes and he said they are stock calipers. If it has locked both fronts it will be a master cyl fault. Possibly a blocked compensation port.
« Reply #4 on: April 06, 2009, 05:52:55 PM »
really?
So ALL power brakes don't have a check valve in the vacuum line from the intake manifold?????
Tap the brakes and sucks the pedal down.......trust me NOT FUN when it happens!
« Reply #5 on: April 06, 2009, 07:09:00 PM »
line lock FTW ;D
« Reply #6 on: April 06, 2009, 07:57:35 PM »
line lock FTW ;D
Whats up with that sig?
Change that shit to F.A.K.L.A.D.
You know you got that d-series love....
Zeniceguycrx
« Reply #7 on: April 06, 2009, 09:58:08 PM »
sounds like a master/booster problem
The 30psi king of rice
fysh
« Reply #8 on: April 06, 2009, 10:02:20 PM »
But, why do they work flawlessly when driving in reverse?
caged
« Reply #9 on: April 07, 2009, 01:21:19 AM »
really?
I ment check valve inside the master cyl which all drum brake cars have to keep pressure in the lines.
How can a broken vac check valve suck the pedal down??
Zeniceguycrx
« Reply #10 on: April 07, 2009, 12:35:09 PM »
rear drums?
if so try adjusting the back first
Hotrodlincoln
« Reply #11 on: April 07, 2009, 11:23:40 PM »
The brakes work in reverse because of the position of the calipers relitive to the hub,  somethings loose or installed incorectly
kill yourself piss face
