Author Topic: Solid cel  (Read 13493 times)
fuse
Solid cel
« on: June 22, 2010, 08:40:26 PM »
I did a tune about a year and a half ago. It has been running fine then just farted out. I have a solid cel. I have no spark no fuel injector noid light blinking I don't even hear the pump priming.
Now I just started with the pump when I take the pump control wire to ground I hear the main relay clicking but don't hear the pump.
I am going to try a main relay first. But if it turns out to be a dead ecu what is the leading cause? Maybe I can just replace a capacitor or something?
Re: Solid cel
« Reply #1 on: June 22, 2010, 09:22:41 PM »
Often times solid CEL's still run engines in limp dick mode... mine did at least when I blew the IAT and PCS circuits.  I drove to a guy who had a P28 and back home in limp dick mode.  It sucked, but it started and ran no problemo.
fuse
Re: Solid cel
« Reply #2 on: June 22, 2010, 10:07:16 PM »
Its not even starting in limp mode (it took the chip out and it wouldn't start) usually that forces it in limp mode.
Im a bit lost on this one.
« Last Edit: June 22, 2010, 10:12:10 PM by fuse »
Re: Solid cel
« Reply #3 on: June 22, 2010, 10:43:05 PM »
That's how an ECU with J1 set and no chip behaves.
Reflow the socket and latch, if that doesn't fix it replace the latch, if that doesn't fix it throw it away and get another.
fuse
Re: Solid cel
« Reply #4 on: June 23, 2010, 10:30:09 PM »
Problem solved car broken into and ecu stolen along with speaker system. I hope it was a shit ecu. Time to start fresh.
Re: Solid cel
« Reply #5 on: June 23, 2010, 10:48:28 PM »
There's crime in Colorado?
Re: Solid cel
« Reply #6 on: June 24, 2010, 12:38:26 AM »
Lots of thugs at the ski resorts
Re: Solid cel
« Reply #7 on: June 24, 2010, 09:26:22 AM »
Goddamn ski bunnies bringing their car jacker bfs up the mountain.
fuse
Re: Solid cel
« Reply #8 on: June 24, 2010, 09:22:41 PM »
Ya 3 cars stolen I have worked on and several broken into honda are a target.
Re: Solid cel
« Reply #9 on: June 24, 2010, 10:12:53 PM »
Sir!  I suggest you move on to NisAnd because I'm an intellectual being, , then.  Those are so shitty no one wants to steal one.
Re: Solid cel
« Reply #10 on: June 25, 2010, 12:50:31 AM »
Get a DSM and it will break before they can get away.
Re: Solid cel
« Reply #11 on: June 25, 2010, 03:13:30 AM »
Find new friends and stop talking with the locals so much that you dont know. Unless you have a high crime area its people you know taking the shit.
Now if you were in California you would have about 5 million illegals who are suspects. Im guessing a couple tweakers you went to high school with.
theidealone
Re: Solid cel
« Reply #12 on: June 25, 2010, 06:08:29 PM »
We have a FUCK load of illegals here in Colorado, stealing everybody's shit. I wouldnt say its as bad as California, but its definitely sketch if you own a Honda. My wife hates me, because my 89 Civic HB stays in the garage, while her 07 Tiburon gets snowed on.
Re: Solid cel
« Reply #13 on: June 25, 2010, 09:02:58 PM »
Beatup 4thgen > Hyundai. Seriously guys, learn how to do wiring. Get a cheaper 2-way DEI alarm (avital/hornet) and wire that shit to all the goodies. Then get some tri-notch tamper resistant bolts to screw down the ecu with. Make them theives work their asses off at least.
My friend is building a 9:1cr ka24-t...for drag racing/fun. I joke with him all the time "so when will it be drivable?" Granted he's gone nuts with it, that is practically required given the base you start with though.
Re: Solid cel
« Reply #14 on: June 25, 2010, 09:13:17 PM »
Uh, I've fed stock KA24DE rods 400wtq.  There's nothing weak about those drivetrains.  The problem with them is third rate wiring and feces electronics.
fuse
Re: Solid cel
« Reply #15 on: June 25, 2010, 11:05:37 PM »
Ya I have that sister board soldered in now. I haven't moved the jumper yet. I trashed my laptop long story short got high on gas fumes left laptop on roof drove off....................... Now I need a new laptop.
I am having shitty luck lately. It was a 100$ pawn shop laptop on windows 98 but still :'( one day I will tune a nissan.
fuse
Re: Solid cel
« Reply #16 on: June 25, 2010, 11:08:11 PM »
It was in the center of town ya its a high crime rate. They hit 3 other cars in the same lot. Snagged mostly stereo stuff.
theidealone
Re: Solid cel
« Reply #17 on: June 25, 2010, 11:12:15 PM »
Yea, I would agree. But the 4th gen isnt that beat up, and its an SI. The mexicans around here must be crafty. Alarms, kill switches, pulling the ECU, etc, none of it seems to work. Ive heard of people going as far as sawzalling a large car sized hole in the garage door. I say fuck it, if you want it that bad, youre gonna get it. I have a battery kill switch, and my garage.
2slow
Re: Solid cel
« Reply #18 on: July 02, 2010, 06:32:42 AM »
I just put ford emblems on my hondas.
