Author Topic: Auto to 5spd  (Read 11077 times)
Auto to 5spd
« on: June 28, 2010, 06:56:47 PM »
Does anyone have the part number to the trans bracket that goes on the frame rail? I look and this is all I can find; http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry2=1995&catcgry3=3DR+SI&catcgry4=KA5MT&catcgry5=ENGINE+MOUNT+%281%29
Re: Auto to 5spd
« Reply #1 on: June 28, 2010, 07:17:56 PM »
You talking about #14 in that pic?
Re: Auto to 5spd
« Reply #2 on: June 28, 2010, 07:32:19 PM »
Nope the one that goes around #4, its tack weld to the frame. The Auto one points up, the 5spd one is straight.
Re: Auto to 5spd
« Reply #3 on: June 28, 2010, 07:35:38 PM »
I could probably pull it off my civic before I scrap it if you need it.
Re: Auto to 5spd
« Reply #4 on: June 28, 2010, 07:42:31 PM »
I may take you up on that offer, but if I remember right the bracket was like $15 from the dealer.
Re: Auto to 5spd
« Reply #5 on: June 28, 2010, 07:52:25 PM »
Damn that's cheap, might as well do that.
Re: Auto to 5spd
« Reply #8 on: July 04, 2010, 10:37:18 PM »
this conversion didn't cost me anything but a few mm on the cut off wheel and a few 6011 rods.  no special bracket needed.  i did drill the spot welds and take the entire bracket off to do the modifications, then weld it back on.  'measured' with the eyeball and installed just fine
Re: Auto to 5spd
« Reply #9 on: July 05, 2010, 11:12:17 AM »
Since it's going to be cut off anyways, I'd just do it flash's way. If you want it to be "perfect" you should get a 5spd shell.
