Pages: [1] 2 3   Go Down
Author Topic: Pretend to be JD/become the next Fred for 4.30$  (Read 32040 times)
Re: Pretend to be JD/become the next Fred for 4.30$
« Reply #1 on: July 04, 2010, 04:33:48 PM »
99% of the site has no idea what that is.
« Reply #2 on: July 04, 2010, 04:37:36 PM »
They are not alone  :?:
imburne
    • TurboByHOLSET
« Reply #3 on: July 04, 2010, 04:46:15 PM »
MSP430 LaunchPad (MSP-EXP430G2) unboxing
I was watching the video when I noticed youtube put the worldcup music on every video ;) Click the soccer ball. Maybe old news so eat shit if it is.
« Reply #4 on: July 04, 2010, 04:57:40 PM »
looks cool but i dont have any idea what i would use it for or how to use it?
« Reply #5 on: July 04, 2010, 05:05:35 PM »
+1
« Reply #6 on: July 04, 2010, 05:08:07 PM »
I was expecting something involving hot pockets when I saw the thread title  :P
darkelvis
  • RHMT King of Rice
« Reply #7 on: July 04, 2010, 06:54:52 PM »
+1
Really guys??? Everyone knows thats one of those computer thingies that you add other computer thingies on to so you can do things with it.  fuckin idiots
« Reply #8 on: July 04, 2010, 07:07:09 PM »
i'm thinking i could use it to monitor boost levels in my efi 4.0L jeep and adjust MAP sensor voltage accordingly to 'fix' a/r levels.
mrgreengenes
« Reply #9 on: July 05, 2010, 12:54:16 AM »
« Reply #10 on: July 05, 2010, 01:03:29 AM »
Damn, how can they sell that for 4.30$ ?
The board itself worth more than that...
« Reply #11 on: July 05, 2010, 10:56:56 AM »
i think peripherals is the word i'm looking for
SgtB
« Reply #12 on: July 05, 2010, 11:19:52 AM »
seems pretty neat. I think they are on back order though.
It's a microcontroller development board. It can do about anything you can think of electronically. It takes inputs, whether it's a sensor, switch, analogue voltage, etc, and creates outputs. Those too can be many types of outputs, relays, led's, wireless modules, solenoids...anything with the right voltage and speed. The neat part is that you can write code to change its behavior very easily. This one is super cheap having a development board hooked to it. Usually a lower end chip costs this by itself.
« Reply #13 on: July 05, 2010, 01:04:18 PM »
+1
The processor is slightly limited by todays standards, but for a LOT of simple applications it's goddamn perfect.
SgtB
« Reply #14 on: July 05, 2010, 01:10:22 PM »
It's like the 08M PICAXE. It's so cheap and who gives a shit if it's slower than the newest uC. I don't always need speed or complexity for simpler logic circuits.
« Reply #15 on: July 05, 2010, 01:19:27 PM »
could this be used to make a honda coil on plug get signal from ecu fire proper coil at the right time kinda thingy?
« Reply #16 on: July 05, 2010, 01:21:43 PM »
While we're on the subject, what's a good resource/ebook on pics for noobs?  There's a few things I'd like to do, and am not intimidated by the programming, but have no fucking clue on what pic I should use and how I use it :/
« Reply #17 on: July 05, 2010, 01:26:47 PM »
TEN INPUT/OUTPUT SIR.  TEN.
« Reply #18 on: July 05, 2010, 01:43:11 PM »
cool or I could just let a certain someone finish his and let me test them.
« Reply #19 on: July 05, 2010, 02:26:26 PM »
Three inputs, two to four outputs, depending on individual or wasted spark architechture.  As so:
Either combination of the following, used to determine engine position and therefore which cylinder/ignition output channel:
- IC10 pins 2 and 6 (CKP and CYP, best)
- IC10 pins 4 and 6 (TDC and CYP, probably just as good given the same premise as Blundell's FAR more complicated unit)
Take the IGO:
- Q38 pin 2
And MUX it out one of your 2-4 ignition channels.  Remember to use an ignitor.  And fuck your mother.
« Reply #20 on: July 05, 2010, 02:41:39 PM »
i got one, along with a bunch of free sample cpu's from them... it went to my pa address so I will have to pick it up. um, yeah.
« Reply #21 on: July 05, 2010, 02:44:15 PM »
Well, fuck your mother, too.
SgtB
« Reply #22 on: July 05, 2010, 04:20:25 PM »
Arduino is good and so is picaxe for learning. Go to the picaxe website and you can download the editor and a three section manual that teaches you everything. It The third section is even a set of examples for each type of circuit you may want to build.  It does run BASIC which turns most people's noses up at it, but for learning uC's I find it good because it lets you learn the electronics quicker. The smaller setups are ~$10 with the board. They even have a starter pack that comes with everything to get you started.
Official site: http://www.rev-ed.co.uk/picaxe/
Starter pack @ Sparkfun: http://www.sparkfun.com/commerce/product_info.php?products_id=8323
Once you learn the basics, changing platforms is a matter of learning the IDE and the uC's quirks. Once you get into you'll be surprised how easy most things are to build.
« Reply #23 on: July 05, 2010, 04:25:06 PM »
Most of the lower end tools on the market are perfect for the lower end micros.  I waster money buying a "newer" 20Mhz analog scope for $100 to the door, I've seen Hitachi V-212 like I trained on frist year of school go for $35 shipped on eBay and they have a better and easier to read graticule.  Also, the entry level/USN logic analyzer market is currently off the fucking hook - for $100-250 you can get 8-16 channel up to 100Mhz badness with built in protocol analyzers (RS-232, RS-485, CAN, I2C, etc).
« Reply #24 on: July 05, 2010, 06:21:07 PM »
Cool thanks.  Have seen arduino used for a ton of little projects.  Haven't heard of picaxe but I'll look into that too.
« Reply #25 on: July 07, 2010, 07:49:06 PM »
Bump
« Reply #26 on: July 07, 2010, 08:00:40 PM »
anyone who doesnt toss in the cost of a big mac for the opportunity to enbiggen they noggin is a foo
« Reply #27 on: July 07, 2010, 08:59:25 PM »
ordered
hopefully my ADD doesnt let this become a $4.50 paperweight
« Reply #28 on: July 07, 2010, 10:35:51 PM »
If I knew how to build anything electronic and program it, I would order one. But as I am barely more than a redneck engine builder, I don't see how I could justify buying one.
« Reply #29 on: July 07, 2010, 10:39:00 PM »
I got one on backorder... we'll see.  I have some ideas for this kind of thing.  I briefly fooled around with an FPGA with 30 or so in/outs and Java Optimized Processor.  Definitely super powerful shit in the hands of someone possessing the proper knowledgabilities.
Pages: [1] 2 3   Go Up
