Author Topic: Low rpm high kpa bins, question about afrs  (Read 9033 times)
TTC
« on: July 27, 2010, 09:56:53 PM »
Today i was cruising around on the highway doing weird things with throttle and boost n shit and I go tto thinking.
For instance if im in 5th I can make about 11lbs of boost at 3000rpm which is in a pretty odd bin area on the map. What kind of AFRS should i be looking at? Still keep it at around 11:5? Or can you run a bit leaner at these areas?
Re: Low rpm high kpa bins, question about afrs
« Reply #1 on: July 27, 2010, 10:39:32 PM »
11 to 5 will turn you out
« Reply #2 on: July 28, 2010, 12:04:29 PM »
High load low rpm (that's low for a 4 cyl, anyway) I'd shoot for 11.5's for thermal safety.  Try dyno, det cans, or EGTs to trim up your timing.  Timing is key.
« Reply #3 on: July 28, 2010, 12:05:56 PM »
And, honestly, that's not a wierd part of th map.  You may take a single pull in a lower gear and not hit that spot, but if you change gears quickly it's possible that the boost stays up and the the rpms fall into that range - if you haven't tuned it she either goes lean or goes rich.  Best case is rich, and you just bog.
