Author Topic: Max boost on 440cc  (Read 9065 times)
Max boost on 440cc
« on: April 08, 2009, 12:37:37 AM »
I have a 75mm Vitara D16Z6 with .57 trim and 440cc injectors...
What is the max amount of boost I can run on the injectors before they dry up...   :evil:
Re: Max boost on 440cc
« Reply #1 on: April 08, 2009, 12:39:21 AM »
29.1189
« Reply #2 on: April 08, 2009, 12:39:57 AM »
« Reply #3 on: April 08, 2009, 12:40:45 AM »
« Reply #4 on: April 08, 2009, 12:42:49 AM »
haha, 450cc injectors should max out around 300 hp at stock fuel pressure.
I'm thinking they might support more with a decent FPR, but I'd recommend upgrading the injectors instead. Delphis are cheap
« Reply #5 on: April 08, 2009, 12:55:21 AM »
29.1189
So the post whoring begins!   Get a job!  :somb:
« Reply #6 on: April 08, 2009, 01:14:39 AM »
boost is irrevelant.  it is all about the power.  What fuel pump?? What base fuel pressure??  what cams?? any port work?? Theres alot of variables involved,
taking a random guess(assuming you have a stock head/cams and a 255) you should be able to get at least 17-18lbs out of them.
« Reply #7 on: April 08, 2009, 01:41:03 AM »
Fuel pressure makes a huge difference. I have made 190 whp on b16a's all motor with stock injectors. Fpr was cranked up as high as it would go classic b&m fpr.
« Reply #8 on: April 08, 2009, 01:46:30 AM »
I do have the Classic B+M FPR but switched it out for the bigger outlet B-series FPR.
Stock fuel pump...
« Reply #9 on: April 08, 2009, 02:01:08 AM »
chuck i may have a 255 for you i have to raid the shed to find it though
rsmith2786
« Reply #10 on: April 08, 2009, 02:05:05 AM »
(34.8MJ/L)*(1L/1000cc)*(440cc/min)*(min/60s)=.2552MW=340HP
Assume approx thermal efficiency of 40% and you get 136HP.
Clearly too low.  Where is my error?  440cc/min at base fuel pressure?  Some of my conversions could be wrong too.  It's late.
jhonda
  • BOATS-n-HOES
« Reply #11 on: April 08, 2009, 05:10:35 PM »
im running 440cc on my b20 vtec turbo and putting down 342hp with them and a walbro 255 fuel pump tuned on crome (but yea their probably about maxed out) :yes: :o
« Reply #12 on: April 08, 2009, 05:18:05 PM »
'bout yay much.
MantisX
« Reply #13 on: April 08, 2009, 05:18:53 PM »
Did you increase the pressue any with a regulator or is it stock pressure?
jhonda
  • BOATS-n-HOES
« Reply #14 on: April 08, 2009, 05:29:25 PM »
im not sure but i think the pressure is around 60 or something (i had the car tuned by slowmotion-motorsports here in ohio) after i got it all turboed up... i was expecting somewhere around 250whp on 9psi NOT 350whp... but its still going strong no smoke and no problems. next time i pop the hood i'll look at what the pressure is at i cant remember
Colin
« Reply #15 on: April 08, 2009, 05:54:41 PM »
Thermal, yes, but typical engine efficiency is about 20%. Multiply that by 4 injectors and you get about 272HP.
It's pretty typical that these things are good til about 300hp, depending on fuel pressure.
rsmith2786
« Reply #16 on: April 08, 2009, 07:42:59 PM »
Damn.  4 injectors. :D
