Author Topic: My reverse gear is non-existant. WTF!  (Read 29074 times)
« on: April 08, 2009, 08:00:31 PM »
SO, I go to back out of a parking spot, reverse is being a PITA. nothing new, 1st to reverse.. still nothing. 2nd to reverse. still nothing.. roll the car forward, still nothing. Continued to try until I got out and pushed the car out of the parking space.
After about 30 minutes of trying to get it into gear at the house, i'm convinced there's something terribly wrong with my gear box. 1st-5th works great. smooth as butter.
Can anyone speculate as to what could be wrong here? I never got a grinding, just one day it's there, now it's gone. Can't find much via search anywhere. Bone?
Re: My reverse gear is non-existant. WTF!
« Reply #1 on: April 08, 2009, 08:06:32 PM »
Is it grinding or feel like it hits a brick wall. Brick wall suggests the gear selector is ate up and needs either massaging or replaced. Grinding same thing just the early notification that its goin bad.  Also could be your shift forks or actuated lever to engage the gear onto the gear shafts.
What trans?
« Last Edit: April 11, 2009, 11:33:57 PM by widebody93 »
« Reply #2 on: April 08, 2009, 08:14:39 PM »
you had it apart lately?  soudns like the reverse idler was installed upside down
« Reply #3 on: April 08, 2009, 08:25:42 PM »
IS THAT EVEN POSSIBLE and still have first gear.
« Reply #4 on: April 08, 2009, 08:37:21 PM »
eh, it never did grind into gear, that's what makes me think something came loose instead of wear and tear.
« Reply #5 on: April 08, 2009, 08:39:27 PM »
What trans?
Y21 I think.. B16 trans from 95 del sol vtec.
definitely feels like a brick wall. I've never dug into a transmission. I guess take the case off and check around the rod that attaches to the linkage for broken pieces?
stealthiskey
« Reply #6 on: April 08, 2009, 08:59:11 PM »
Someone prolly stole your reverse gear when you parked the car during the day.
« Reply #7 on: April 08, 2009, 10:52:35 PM »
bad synchro
« Reply #8 on: April 09, 2009, 12:07:10 AM »
bad synchro
You mean it broke in half and slid around to where the  selector wont allow it to travel up on the shaft. hmmm possibly
« Reply #9 on: April 09, 2009, 05:37:36 AM »
bad synchro
J, STFU.
« Reply #10 on: April 09, 2009, 09:41:53 AM »
does it go into reverse if engine is off?
nope.. i wish
« Reply #11 on: April 10, 2009, 12:07:40 AM »
happened to my old crx once.  i had a buddy let the car idle and hold the clutch in while i was in the back and forcing the tranny into rev. after that the tranny was good for another 2years untill i sold the car
« Reply #12 on: April 10, 2009, 12:29:40 AM »
bad synchro
J, STFU.
Lol I was being a ASS to you, you fool. Chill red. . I have never witnessed a bad syncros do this in reverse Bone. I am comfortable saying that the gear selector is fucked up and burred bad. The collar selector is the culprit in my opinion of what I have dealt with.
jlude90
« Reply #13 on: April 11, 2009, 02:17:43 AM »
sounds like it could be this
thats what its supposed to look like
thats how its supposed to operate(and what what going into 5th gear looks like)
this is what the other side looks like
and this is how it operates or...doesn't
some how 5th gear got rammed into the slider and bent the teeth over, preventing it from going into 5th. same symptoms as the transmission i pulled that hub/slider out of
« Reply #14 on: April 11, 2009, 02:50:37 AM »
failure to debur plus misalignment of the hub and slider.
Jeremy, when you call, leave a fucking message.
« Reply #15 on: April 11, 2009, 11:33:10 PM »
I suggest running a polishing stone on the end of a dremel for the V are and then a diamond file for the edges of the grooves  :noel:
And Charles I just called to see whats up, nothing really important this time around
And Jlude   nice pictures
« Last Edit: April 11, 2009, 11:36:14 PM by widebody93 »
« Reply #16 on: April 12, 2009, 06:10:33 PM »
the #9 selection is the 5-R synchro set. is that all I need?
« Reply #17 on: April 12, 2009, 08:04:31 PM »
might need 5th as well, #7
jlude90
« Reply #18 on: April 13, 2009, 01:29:41 AM »
my 5th gear was fine, all i did was get another transmission for cheap and take the 5/R hub and slider from it to use and now its like butter. but if i had the money to spare i'd have just bought a new one, the one i got showed signs of this, but nowhere near as sever, so i just flied the bad parts down and threw it in, i guess we'll see how it goes when i start driving
« Reply #19 on: April 13, 2009, 02:28:15 AM »
you failed english class right?
jlude90
« Reply #20 on: April 13, 2009, 02:35:53 AM »
Because i missed the E in severe, overuse commas, and underuse periods and capitalization?
yes
I figure with my proper use of grammar and generally clear and concise posts, I do not feel the need to spend the extra time on sentence structure. Since most the rest of the forums i visit i can barely understand what people are saying, I don't think I'm doing half bad.
« Reply #21 on: April 13, 2009, 04:17:52 AM »
Ignore Charles he is upset that I called it right and he is supposed to be the tranny guru  :-*
I still suggest a polishing stone on the old part to see if it will clean up and work to save you some cash
« Reply #22 on: April 13, 2009, 11:55:04 PM »
bone knows more about d trannies than you have forgotten about blue dashes
« Reply #23 on: April 14, 2009, 07:58:21 PM »
And I clearly know more about b series since I do about 10 a year on my first season doing them. SRSLY
FUCK OFF FAGGOT
« Reply #24 on: April 14, 2009, 08:44:37 PM »
ok
« Reply #25 on: April 14, 2009, 11:10:33 PM »
Something Jeremy doesn't have, a long list of happy customers.
How many have I messed up that required me to cover everything, just one.
Less than 1% error rate, I'm not perfect, but damn near.
« Reply #26 on: April 15, 2009, 01:53:43 AM »
thats still really good percentage Charles. But in my one year on Bs Im batting a 1000. Two Ds Batting a 1000 two h22s batting 500 because mine broke from power.
Either way. We build them. Make money. And good local reputation doing it.
« Reply #27 on: April 21, 2009, 11:10:09 AM »
I won the second round!
I tried putting it in the reverse position again, beat it again, pry'd it back and forth. Now I get reverse! took her out for some joy riding last night. makes the integra seem like riding a bicycle! haha
« Reply #28 on: April 21, 2009, 11:17:09 AM »
Where are the vids?  :noel:
