Author Topic: 3" ac friendly cast manifold DP  (Read 35506 times)
speedjunky01
« on: August 24, 2010, 03:59:59 PM »
made her out of some scrap 3" i had
pie cuts
taced up
tight as fuck under the oil pan trying to clear the h brace too but wie will see how it works out
gonna add a flange where the pie cuts start so its easy to remove and so that i dont have to remove the AC compressor ro get the DP off, right now i have to since it fits sooooo tight
hope to have this shit in end of the week, talking to mike at LSD right now to get a fresh clutch disk
Re: 3" ac friendly cast manifold DP
« Reply #1 on: August 24, 2010, 04:06:05 PM »
I usually try to do at least two passes with duct tape.  Root and filler.  I find it holds much better usually.  Are you going to back tape those joints also?
speedjunky01
« Reply #2 on: August 24, 2010, 04:10:38 PM »
i tripple passed my intercooler pipe once and help 12ish psi just fine for a week but im going all out for this
fluxcore  :noel:
speedjunky01
« Reply #3 on: August 24, 2010, 08:53:06 PM »
dented above to allow for bolt clearance and washer and wrench gotta think of these things haha, the flange is SS and the fluxcore just ate it up! lol
weirtech
    • Weir Technologies Inc.
« Reply #4 on: August 24, 2010, 08:53:35 PM »
that is tight.  i'd think it'll still fry the ac compressor.
speedjunky01
« Reply #5 on: August 24, 2010, 08:58:19 PM »
yeah idk i plan or changing to a better manifold thats a bit easiet to work a 3" I plan on wrap and ill oval out the pipe some by throwing it in a vice and giving it a tad more room
the ac system need a lot of work to get working anyway, i broke the top part where it hooks up and i cant weld aluminum :( i was thinking of JBing it but dont think it will hold :( would really loooooove to get a smaller condenser and custom lines made up but nobody around can do it
DasPoop
« Reply #6 on: August 24, 2010, 09:00:13 PM »
thinking the same thing i would dent it all along the compressor for just enough room to wrap it
speedjunky01
« Reply #7 on: August 24, 2010, 09:02:26 PM »
in the works fellas thanks for the heads up  :yes:
like i said ill throw it in the vice
« Reply #8 on: August 25, 2010, 12:47:36 AM »
yep it looks super snug, maybe its just the pic?
« Reply #9 on: August 25, 2010, 01:21:24 AM »
I would wrap it and try and get a heat shield in therw too.
speedjunky01
« Reply #10 on: August 25, 2010, 07:49:01 AM »
I wish it s just the pic haha
Ratcity any ideas on a shield
speedjunky01
« Reply #11 on: August 25, 2010, 09:53:15 AM »
just picked this up
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270610712522
hit best offer, do 60 and they took it :D
if you dont think it works :D
Turbo Blankets REALLY WORK
« Reply #12 on: August 25, 2010, 10:30:21 AM »
Awesome
You said H-brace, are you talking about the the brace that you buy off of ebay or make like this:
http://cgi.ebay.com/ebaymotors/Red-H-Brace-Lower-Arm-Honda-Civic-92-93-94-95-96-97-99-/310243168941?pt=Motors_Car_Truck_Parts_Accessories
I had to bend mine up in the middle just to clear the 2.5'' exhaust I have on my car.
« Reply #13 on: August 25, 2010, 11:09:21 AM »
fuck. I had to go fix a hydraulic line at a customer's house. They were just as pissed that it blew as they were their DUCT TAPE and hose clamp fix would not contain the leak. :-X
If you want AC, give it some space. You aren't going to lose much power, as the quick 90* transition will do most of the killing. You'll want some room to wrap it with 1-2 layers of insulation. I have ceramic 1/16" under the 3/32" fiberglass on my DP, and it's possible to do a few highway pulls and touch it. I also have a wrapped downpipe almost touching my pan, and it ends up heating the oil too much on long drives. Not enough of an air gap.
As far as custom pipes, ask your local body shops. They should know of someone that can make them.
« Reply #14 on: August 25, 2010, 11:23:45 AM »
If it was me i would have done a 2.5" to 3" transition after the compressor. I too think the a/c will be very unhappy.
speedjunky01
« Reply #15 on: August 25, 2010, 12:07:32 PM »
really think the compressor will die that quick? anyone have a recomended gap DP to Comp?
also yup that H brace lol
« Reply #16 on: August 25, 2010, 12:17:18 PM »
Judging by the exhaust to heat shield under the car I'd say 1/8" to 1/4".
On my header I have it wrapped and a starter blanket up against my supercharger.
After a brisk set of runs my s/c feels a little above ambient in the area by the header.
speedjunky01
« Reply #17 on: August 25, 2010, 12:23:12 PM »
your all scaring my im gonna go outside and squish the pipe some more and try and get a bigger gap
DP will be wrapped and ill throw some reflective heat stuff on the compressor
Ghetto_D
« Reply #18 on: August 25, 2010, 01:34:56 PM »
dude youll be fine.  as long as the pipe doesnt touch the compressor and you dont have the car idling all the time, It wont fry.
My bros hatch had the DP really close to the compressor, It worked fine for 2 years, untill he went B-series.
speedjunky01
« Reply #19 on: August 25, 2010, 01:44:35 PM »
Thing is it pretty ouch does touch since I had to grind the bolts on the compressor down to even fit the dp haha
DasPoop
« Reply #20 on: August 25, 2010, 02:04:20 PM »
just dent the pipe and call it a day.
speedjunky01
« Reply #21 on: August 25, 2010, 02:21:02 PM »
vice+2x4
got about 1/4 of an inch now, gonna smooth the side of the compressor with a cutoff wheel and put reflective tape on it
flanges should be here tomorrow so i can weld them on and make the part going under the oilpan removable so if i need to swap a tranny or anything like that its just 3 bolts and no headache of getting the hard to reach bolts
« Reply #22 on: August 25, 2010, 02:42:14 PM »
That should work.  :yes:
speedjunky01
« Reply #23 on: August 25, 2010, 02:57:34 PM »
yeah i figure with some wrap it will be just fine im not sweating it
speedjunky01
« Reply #24 on: August 25, 2010, 06:15:55 PM »
re-did the WG dump tube
clears the ac lines way better
« Reply #25 on: August 25, 2010, 06:47:59 PM »
Looks pretty baller!
DasPoop
« Reply #26 on: August 25, 2010, 06:48:24 PM »
looks good are you gonna wrap the ac lines and the dump tube?
I am going to run ac but i am using a internal gated k03 so its got a super small footprint
speedjunky01
« Reply #27 on: August 25, 2010, 11:43:17 PM »
yup will all be wrapped, also picked up some thermo tape from home depot lol
blow torch tested and approved
as far as the k03 that thing is the size of a fucking testicle it will fit anywhere you put it the d even with AC will fit a k03 without ANY issues
« Reply #28 on: August 26, 2010, 09:25:29 AM »
You'll probably have to bypass the thermal thing on the compressor, since it will heat the actual case like a mofo. Once that thermal switch senses overheating of the compressor, it disables the clutch till it cools down.
speedjunky01
« Reply #29 on: August 26, 2010, 08:09:05 PM »
i think with the wrap and the reflective tape it will be ok, and if the pressure switch starts tripping ill just get some non-home depot reflective tape hahah
moar pics!!!! just about done just dump tube to the bottom of the car and done!
3bolt flange FTW
oilpan clearance
like this shot
come on 400 wheel!!!
