Author Topic: Replace OEM Cluster with TunerView RD-1. Cable VSS ?s  (Read 16085 times)
theidealone
« on: September 01, 2010, 07:14:01 PM »
Ok, So I tried posting this on HRTuning, but I dont think JR really knows what Im talking about.
So anyways, for those of you that havent seen the TunerView RD-1, heres a link:
http://www.hrtuning.com/catalog/product_info.php?products_id=91
I was thinking that I want to replace the cluster with this, as Ive seen one or two people (that have the prototypes) do so, like it was a Race Pak or Motec set up. Pretty damn cool. But those people have electrical VSS, and I have a cable.
So what seems like a good route? I was thinking, I could swap to an electric VSS, and instead of wiring it to the cluster, I would just have to wire it to the ECU, since TunerView gets its info from the ECU. Right?
Or, I was thinking, I could keep the odometer and everything, by just leaving the cluster hooked up like factory, and tucking it behind the dash, out of sight... Then I wouldnt have to wire anything, swap VSS, etc.
Im not sure how the cable VSS works, but Im assuming its like a mechanical guage, and then the ECU gets its info from the gauge cluster itself...
I also thought about fuel, and if I can find a way for the stock sending unit to output 0-5v, I could use an input on the ECU. Or just run a separate gauge for that alone, like an Auto Meter. But the whole point behind the TunerView (for me) is to get rid of my gauges all together.
Any other issues or ideas? Throw em out there.
Thanks
Re: Replace OEM Cluster with TunerView RD-1. Cable VSS ?s
« Reply #1 on: September 01, 2010, 10:03:53 PM »
You'll need a 96-00 OBD-2 VSS to clear the rear tranny bracket. The hardest part is getting the old drive out of the tranny. Most of the time you have to split the tranny and drive out from the inside.
« Reply #2 on: September 01, 2010, 10:09:50 PM »
That's pretty slick, too bad it's so Atari looking. I'd be interested to see this replace all the cluster gauges and then some.
I wonder what the response time is like, how well would it react to bouncing off the rev limiter in 1st and 2nd....
theidealone
« Reply #3 on: September 02, 2010, 12:51:07 AM »
Well, Im going for the D2B, and I already have the B16 (cable) VSS out of the tranny. Its split, needing a rebuild for winter anyways. What VSS should I use for that set up? EF2B?
And yea, I havent heard of any complaints from users that have the Tuner View I or II. So I dont think there should be much of an issue in response with the RD-1. I know a few people will be replacing their clusters with it.
Here is one guys layout of gauges:
Quote from: ahobbs;43230921
here are more layouts ive designed.
Quote from: ahobbs;43423715
dash is dusty sorry.
Pretty slick so far. I really want it. LOL.
So do you guys think the VSS is my only draw back from ditching my original gauge cluster???
And should i swap the VSS or just keep the stock cluster hooked up, and place it somewhere in the dash, just pushed away (I have no heater core, vents, etc).
« Reply #4 on: September 02, 2010, 11:31:10 AM »
it is pretty atari era there..
i like how the first tunerview is and how people mount them in the cluster where all of the warning lights are.  that looks tits.
theidealone
« Reply #5 on: September 02, 2010, 12:18:23 PM »
Yea, but for 250 bucks, it can be as Atari as it wants to be, as long as it functions well, I could give a fuck less really. Looks better than the first 2 Tuner Views.
I do like that one mounted in the ED cluster you posted, but the RD-1 has some pretty sick features. For about the same price as a TunerView II, I could have a bigger display, better fonts, and way more inputs.
« Reply #6 on: September 02, 2010, 02:05:54 PM »
Wow.. thats super clean...  looks OEM...  Do want
Jordy53
« Reply #7 on: September 07, 2010, 11:26:13 AM »
I just bought the RD1. Well pre ordered. I will let you guys know how it works out.
You cannot help the poor by destroying the rich. You cannot strengthen the weak by weakening the strong. You cannot build character and courage by taking away men'#39#39s initiative and independence. You cannot help men permanently by doing for them what they could and should do for themselves.
« Reply #8 on: September 07, 2010, 06:24:28 PM »
Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap Fap
« Reply #9 on: September 08, 2010, 10:08:47 AM »
That would be the perfect spot for oil temp & pressure gauges, and probably more.
« Reply #10 on: September 08, 2010, 08:24:47 PM »
I aswell am purchasing this little beauty. I needed to replace my cluster anyway and its like an extra 100 bucks for this thing. Get rid of some of my gauges at least
2slow
« Reply #11 on: September 11, 2010, 10:07:11 AM »
Look up how to do a cable vss to an integra cluster they show how to wire up the electronic vss like bone was mentioning. There is a few write ups on how to do it. I dont have any links though.
