Author Topic: B16 VS 4g61 IM's  (Read 29548 times)
mrgreengenes
B16 VS 4g61 IM's
« on: September 10, 2010, 01:34:20 AM »
i wanted to do some fucking around, so i came up with this mess
B16a obd1 intake manifold, cut the flanges off, weld on 4G61T head flange and a 2G talon throttle body flange, DO WORK
decided to give the throttle body a bit of an angle to direct the incoming air towards the back of the plenum for better distribution...
the ports were only out by 1/8" on 1 and 4, added weld and will smooth out.
EAT YOUR HEART OUT AARON!!
hahaha
Phil
Re: B16 VS 4g61 IM's
« Reply #1 on: September 10, 2010, 05:40:10 AM »
If the ports are so close I would of just made an adapter
« Reply #2 on: September 10, 2010, 09:02:39 AM »
In for results of this. :yes:
« Reply #3 on: September 10, 2010, 09:09:02 AM »
That reminds me of my b16 plenum d series mani i made years ago. No idea if it made power but it sure was louder. LOL
« Reply #4 on: September 10, 2010, 09:35:33 AM »
Do you still have that laying around?  ;D
Aero
    • Turbotalk.org
« Reply #5 on: September 10, 2010, 10:33:36 AM »
Interesting that the ports are that close as far as spacing.
What are you mounting that in chassis wise?  With all that extra length I don't see it fitting in a DSM.
mrgreengenes
« Reply #6 on: September 10, 2010, 10:43:17 AM »
going in a turbo colt.  It should fit up, it's not that much longer.
i thought of that, i just wanted to minimize length, plus the b16 injectorator bungs weren't needed.  The H22 ports lined up perfectly, but that manifold is lame.
As well, Chris, i'm looking to port out the runners the entire length.  is there a particular method to this?  i was thinking of using a flexible adapter for a die grinder, if such a thing exist.
phil
« Last Edit: September 10, 2010, 10:46:31 AM by mrgreengenes »
« Reply #7 on: September 10, 2010, 01:05:19 PM »
Is this a small port 4g61 or large port?
« Reply #8 on: September 10, 2010, 01:23:43 PM »
That's an interesting contraption.
slappynuts
« Reply #9 on: September 10, 2010, 05:36:29 PM »
You have to cover up the weld with some JB weld and then it will be perfect!
mrgreengenes
« Reply #10 on: September 10, 2010, 07:18:05 PM »
small
h2a
« Reply #11 on: September 10, 2010, 08:38:15 PM »
         i  smell dsm , oh shit ,excuse me my dsm doggy crank wants to take a walk,,, :noel:
h2a
« Reply #12 on: September 10, 2010, 08:48:30 PM »
For real you tell weir to eat his heart out ok you , gringo mexicano :mexi:
2slow
« Reply #13 on: September 11, 2010, 10:29:38 AM »
H2gay shut the fuck up
TTC
« Reply #14 on: September 11, 2010, 11:50:04 AM »
Whats that small port on the side for?
« Reply #15 on: September 11, 2010, 12:08:32 PM »
Looks like EGR^^.
Also, how high do you plan on revving? Those are some mighty long runners and a small plenum. Considering the H runners can make 300whp NA and isn't much of a restriction(without the IAB plate) up until 500whp being boosted...it would have been a better choice.
« Reply #16 on: September 11, 2010, 01:48:13 PM »
4g61 dont crank walk. Idiot. Its a completely different crank and thrust-bearing design.
mrgreengenes
« Reply #17 on: September 11, 2010, 03:30:24 PM »
Looks like EGR^^.
8000 to 8500, depending on how the cams allow the engine to breathe.  I know that the h22 may have been a better choice, but they are bulky and i don't like h22's anymore.  The runner length is far less than the stockers, which were around 13".  I may add some more volume to the plenum... but i may not care...
Aero
    • Turbotalk.org
« Reply #18 on: September 12, 2010, 12:21:04 AM »
Very interested in how this works for you.
« Reply #19 on: September 12, 2010, 03:58:24 AM »
No but i could make another.  :noel:
slappynuts
« Reply #20 on: September 12, 2010, 10:08:19 AM »
So why was this being done? Is there a problem with the DSM manifold?
« Reply #21 on: September 12, 2010, 01:12:13 PM »
Did it seem to make a big difference in power?
« Reply #22 on: September 13, 2010, 04:01:33 AM »
If you want to do some more I have a couple oem b16a manifolds left laying around. Trying to clear everything up since Im closing down the shop soon.
« Reply #23 on: September 13, 2010, 06:08:38 AM »
You don't happen to have a complete obd-0 one do you? I have one that i was saving for my rhd crx but if you have one that not painted with good flange surfaces i would pick one up.
Also whats a 2003 s2000 t-body worth to you? i have one sitting here from my blown engine.
« Reply #24 on: September 13, 2010, 11:01:50 AM »
I understand the plenum/runner swap, but your decision to retain the DSM TB confuses me greatly.
Yeah, just look at it.
« Reply #25 on: September 13, 2010, 11:54:12 AM »
DSM tb super small, should have used one of Chris M 74mm babys :noel:
