Author Topic: HINDU BINDU rigging fuel pump  (Read 13383 times)
jay
« on: September 15, 2010, 01:09:04 PM »
need to nigger rig my fuel pump to get it running
theres 4 wires
2 bunched together are green with black stripe and green with red stripe
and the other 2 bunched together are red with pink stripe (possibly just red who knows) and red with black stripe
any idea on what to connect to what or if i run a 12v wire from fuse box nigger rig it to which wires
« Last Edit: September 15, 2010, 03:35:52 PM by ApexSilver06MR »
I want you to die
Re: nigger rigging fuel pump
« Reply #1 on: September 15, 2010, 01:22:12 PM »
Hook them all up to power, and put out the fire with water
 :mexi:
jay
« Reply #2 on: September 15, 2010, 01:24:16 PM »
 :mexi:
THANKS!!!! ILL GO DO THAT RIGHT NOW!!!!
I want you to die
« Reply #3 on: September 15, 2010, 01:34:29 PM »
Weld them.
jay
« Reply #4 on: September 15, 2010, 01:35:52 PM »
ok so i tried connecting them a whole bunch of different combinations and got nothing
so do i need to connect one of them to a 12v source
I want you to die
« Reply #5 on: September 15, 2010, 01:40:13 PM »
jay
« Reply #6 on: September 15, 2010, 01:43:28 PM »
Weld them.
cmon faggot your a tow truck driver i know you know how to nigger rig a fuel pump
I want you to die
« Reply #7 on: September 15, 2010, 01:45:57 PM »
What car is it in??????????????????????
Go to the12volt.com
/thread
/yourlife
jay
« Reply #8 on: September 15, 2010, 01:46:37 PM »
Go to the12volt.com
/thread
/yourlife
sorry
1999 ford taurus
i tried looking for a manual or anything but FAILED
I want you to die
jay
« Reply #9 on: September 15, 2010, 01:48:24 PM »
negatory on 12volt.com
doesnt have the wiring diagram i need
I want you to die
Hotrodlincoln
« Reply #10 on: September 15, 2010, 01:50:53 PM »
Reds ALWAYS power blacks ALWAYS ground. Hook red up to 12v and see what happens :mexi:
kill yourself piss face
« Reply #11 on: September 15, 2010, 01:52:56 PM »
Guess ill help you out then nignog
Use a light tester put on said wires (make sure you use the alligator clip on a negative source) turn key on, and test each wire. When the key is on the wire will be hot, when the key is off the wire will be cold.
jay
« Reply #12 on: September 15, 2010, 01:56:32 PM »
theres a red with pink and a red with black...
i wish i had a tester but it was at a friends house and hes dead now...
idk what the problem is but its intermittent... but since nothing happend when i touched the wires im assuming ill have to introduce a 12v source to the mix but which wire do i connect it to :/
I want you to die
Hotrodlincoln
« Reply #13 on: September 15, 2010, 02:05:10 PM »
Just add 12v randomly, never stopped you before.
« Reply #14 on: September 15, 2010, 02:40:28 PM »
You need a power and a ground for the fuel pump. The other 2 wire are probly a 5volt ref. And a sending wire for the gas gauge
« Reply #15 on: September 15, 2010, 02:45:30 PM »
 :yes:
HAHAHA
jay
« Reply #16 on: September 15, 2010, 02:58:16 PM »
haha turns out those 4 wires werent even for the fuel pump
a true fuck my life moment right thurrrr
I want you to die
jay
« Reply #17 on: September 15, 2010, 03:01:50 PM »
those 4 wires ran down in the trunk area for no god damn reason at all
I want you to die
« Reply #18 on: September 15, 2010, 03:05:44 PM »
Welding them would have fixed everything
« Reply #19 on: September 15, 2010, 03:36:34 PM »
 :mexi:
« Reply #20 on: September 15, 2010, 03:48:49 PM »
http://www.fixya.com/cars/t5935921-reset_switch
Re: HINDU BINDU rigging fuel pump
« Reply #21 on: September 15, 2010, 03:50:37 PM »
hindu bindu huh?
« Reply #22 on: September 15, 2010, 04:14:59 PM »
My exact thought when I  notice it was a Tore-Ass.  ;D
jay
« Reply #23 on: September 15, 2010, 04:52:14 PM »
naaa i know where the inertia switch is and it was the first thing i checked i really have no idea why those wires were going into the trunk like that... it doesnt make sense...
I want you to die
jay
« Reply #24 on: September 15, 2010, 04:54:48 PM »
what the fuck is hindu bindu
I want you to die
jay
« Reply #26 on: September 15, 2010, 05:04:58 PM »
I want you to die
« Reply #27 on: September 15, 2010, 05:05:20 PM »
Lol, I believe the fuel pump is inside the fuel tank in the tore ass
