Author Topic: 96 accord f22b1 no spark, im totaly fucking stumped?  (Read 47585 times)
« on: September 18, 2010, 08:04:47 PM »
So I'm working on a 96 accord w/ f22b1 with a automatic transmission and it has no spark at all. Replaced dizzy and all internal, and the tdc sensor harness at the crank. Fuel pump primes, I pulled the cap and hooked a spark plug wire to the coil and it throws spark but a light Orange ish color one. But once I put the new cap or old cap no spark through it. So off to the auto parts store for a new rotor. Other than that I'm at a loss. Car was just driving down the road and died. I don't know if I'm over looking something, but I'm thinking new ecu maybe.
Re: 96 accord f22b1 no spark, im totaly fucking stumped?
« Reply #1 on: September 18, 2010, 09:28:15 PM »
Its telling you that the crank pulley bolt and key belong on the SLUT.   :noel:
« Reply #2 on: September 18, 2010, 09:31:20 PM »
I will pull your parts off b4 I set it on fire  :yes:
michigan_soler
« Reply #3 on: September 18, 2010, 09:57:22 PM »
Shitty ground?
« Reply #4 on: September 18, 2010, 10:30:44 PM »
Im done for the night, but I checked the one off of the valve cover, I dont know it there is one on the thermo housing. I couldnt see one but I didnt look super hard eather. So where is the ground for the ecu on the accord? Is it on the thermo housing?
DasPoop
« Reply #5 on: September 18, 2010, 10:40:58 PM »
ohm out the thin blue wire on the coil back to the shocktower plug same thing my friends b20 had turns out the wire was corroded and not giving the coil a good ground therefore shitty spark but enough to produce the orange spark u say
« Reply #6 on: September 18, 2010, 10:55:10 PM »
Well I just checked and cleaned the grounds on the end of the intake, (thats where the ecu ground goes) Front batt ground on the rad/headlight support, and the one on the valve cover/motor mount one too. Still no go. And there is no blue wire that goes from the coil.
« Reply #7 on: September 18, 2010, 10:56:14 PM »
ECU ground is on the thermo.
« Reply #8 on: September 18, 2010, 11:46:08 PM »
On the f22b1 it was on the driverside end of the intake. I looked and felt all around the thermo and there was nothing.
« Reply #9 on: September 19, 2010, 12:06:29 AM »
Is this a chinesse autoparts dist. that your using?
« Reply #10 on: September 19, 2010, 12:14:18 AM »
Yes/no
First dizzy was a oem, then a napa auto parts one. It has all oem internals, just a china coil. But with the old coil it had no spark also.
DasPoop
« Reply #11 on: September 19, 2010, 12:34:57 AM »
i say since its obd2 does it throw a code? if not clear the ecu and crank it till it does?? then jump it or scan it to see what the ecu found
« Reply #12 on: September 19, 2010, 12:40:58 AM »
No cel at all. No mater how much you crank it no cel. Had batt diconected for 3 months, Would that clear in locked in codes?....lol
DasPoop
« Reply #13 on: September 19, 2010, 12:50:06 AM »
dumb question but did ya check all the fuses?
« Reply #14 on: September 19, 2010, 12:55:02 AM »
Yep.
DasPoop
« Reply #15 on: September 19, 2010, 01:13:02 AM »
ok so something is causing the weak spark its not a no spark condition its a weakend spark let me dig through accord wiring diagrams tonight to track down and see where all the dizzy wires go to eventually and i will post my findings and suggestions tomm morning. you said when you hooked up a plug wire to the coil directly it would give you a dull orange spark when you would tap it to ground correct?
« Reply #16 on: September 19, 2010, 01:21:41 AM »
Yep
« Reply #17 on: September 19, 2010, 01:56:03 PM »
coil getting bat voltage?
DasPoop
« Reply #18 on: September 19, 2010, 02:13:06 PM »
Was just going to ask that. mitchell is being a bitch and locking up.
I suggest pinning out the dizzy wires and see if something is "strange" such as high resistance for one of the coil wires. if its not throwing a code its not an internal dizzy fault but rather a coil power situation. I would also check the little spring on the coil sometimes they dont make good contact. there is a little spring in there right?
« Reply #19 on: September 19, 2010, 02:16:19 PM »
Wiring to dizzy fucked?
DasPoop
« Reply #20 on: September 19, 2010, 02:22:20 PM »
did you not read my post??? or any of them for that matter
« Reply #21 on: September 19, 2010, 02:29:00 PM »
haha of course I did. I guarantee that is what the problem is. Start tracing wires
« Reply #22 on: September 19, 2010, 03:23:44 PM »
Coil is getting 12+ish volts.
DasPoop
« Reply #23 on: September 19, 2010, 03:28:29 PM »
ok and there is a little spring in it right? there should be a thin blue wite coming off the coil maybe its a different color on an accord but its what fires the coil and it the wire in fucked up or has a lot of resistance it wont get a good spark. also give the dizzy and mating surface on the head a good cleaning as the coil grounds itsself to the head
« Reply #24 on: September 19, 2010, 05:26:42 PM »
R u talking about the little spring inside the dizzy cap? Im gona go and check the resitans on the 2 wires that run from the coil to the harnes on the dizzy.
« Reply #25 on: September 19, 2010, 09:01:40 PM »
ok, so here it is. The little blue wire you were talking about? On the pass fender? Is that the tach test port? It has 12 volts if thats what you were asking.
« Reply #26 on: September 19, 2010, 09:34:35 PM »
Somthing kinda weird, When I kick the key to the run position it the pump primes, the cel turns on, The car showes its in park, and D4, when the cell goes out so does the drive light, and then it just shows that its in park. It my brother-in-laws girlfriends car. So I have no idea if this is normal or not.
DasPoop
« Reply #27 on: September 19, 2010, 09:57:50 PM »
hmm dont think thats normal. never owned a auto honda.
« Reply #28 on: September 19, 2010, 10:06:05 PM »
Me either.
DasPoop
« Reply #29 on: September 19, 2010, 10:31:11 PM »
see i am just trying to think if you crank the car via jumping the starter with a wire will it put a spark directly out of a cap terminal like stick a wire in it like speaker wire and set it near a ground see if a 0 ohm wire will spark to groungd at reg intervals then its cap coil rotor or combination
