Pages: 1 [2] 3 4   Go Down
Author Topic: J series ecu  (Read 155652 times)
Re: J series ecu
« Reply #30 on: February 13, 2012, 10:44:27 AM »
Damn that is so badass! BUT this is beyond my level of geek :'(
fe3tcourier
Re: J series ecu
« Reply #31 on: February 15, 2012, 06:33:09 PM »
Yeah, I don't like his setup either, but he does, and that's what counts! :-)
I'm a BIG fan of the borg warner design as used on various BMW and Ford diesels. I still want to build one of those one day.
Do you reckon I could sell a few J series plug'n'play setups if I had one drawn up? I could likely get him to test it for me :-)
Would be later in the year, though, before it was fully viable, so might be too late for the niche?
Fred.
Re: J series ecu
« Reply #32 on: February 15, 2012, 06:35:35 PM »
you might not make a killing, but i bet it would be well worth your time. J swaps are still new.
Re: J series ecu
« Reply #33 on: February 15, 2012, 09:10:13 PM »
Fred.
I recall there being one EMS being developed, then there's MS & AEM, but MS is not plug & play and AEM = $$. If it can be tuned fairly easily with a turbo on it, it should be worth your time. Especially if you're still a broke-ass Assie. JD would give you a better idea, but he's MIA.
Re: J series ecu
« Reply #34 on: February 15, 2012, 10:07:52 PM »
Fred.
I thought Fred was a Kiwi.  :noel:
J-series FreeEMS P-n-P would be sweet I can have 4 sold right now as long as they do not cost as much as AEM or the RPS's ecu (PnP MegaSquirt with a base tune already)
I have access to a local who is starting do a bit of J-swaps, just wish we had a chassis Dyno local to me.  :'(
fe3tcourier
Re: J series ecu
« Reply #35 on: February 16, 2012, 10:42:42 AM »
I guess we'll see how the market looks later when the system is mature enough to market like that. Good to know, though :-)
Re: J series ecu
« Reply #36 on: February 16, 2012, 03:56:26 PM »
Lookup Ried and Andy at Kaizenspeed .com... Andy has a boosted J series to S2K tranny going in his s2k. Its being done very nicely and is quite a slick setup
http://htarchive.net/showthread.php?t=3017287
Re: J series ecu
« Reply #37 on: February 16, 2012, 04:51:57 PM »
I have been wondering the last few days what tranny could be used with a J for rwd and had the starter on the tranny side. I'll keep that in mind. That's pricey though.
Re: J series ecu
« Reply #38 on: February 17, 2012, 10:19:19 AM »
That S2k looks great, but the alum spacer on the crank worries me a bit. It could bite them in the ass if they track the car.
Damn, you're right. Hope you aren't insulted Fred. :P
Re: J series ecu
« Reply #39 on: February 17, 2012, 01:11:24 PM »
That does sound sketchy. That's a lot of stress on some long ass bolts
Re: J series ecu
« Reply #40 on: February 17, 2012, 01:43:39 PM »
Seriously wrap your brain around it....
Then type why its fine.
Re: J series ecu
« Reply #41 on: February 17, 2012, 02:40:13 PM »
Im dumb
« Last Edit: February 17, 2012, 03:04:17 PM by jabberwock »
Re: J series ecu
« Reply #42 on: February 17, 2012, 04:25:13 PM »
Tell me why they don't use aluminum for gun parts that see lots of sheer forces, vibration, and heat. THen type why it's not fine how you're a dumbass.
Re: J series ecu
« Reply #43 on: February 17, 2012, 04:32:12 PM »
The bolts arent aluminum..
Would spacer expansion cause a problem?  I mean there are aluminum flywheels and they seem to hold up with a larger radius.
« Last Edit: February 17, 2012, 04:35:36 PM by jabberwock »
Re: J series ecu
« Reply #44 on: February 17, 2012, 04:49:22 PM »
And once again, you have proven your inability to understand the obvious. Enjoy being queer, and more of a retard than... well... ME.    :-*
Re: J series ecu
« Reply #45 on: February 17, 2012, 06:33:35 PM »
Stock flywheels dont have alignment pins so the bolts take all the sheer forces, if the spacer expanded it would just make the bolts tighter i presume. I will admit those are some long ass bolts to hold a heavy spinning disk but the flywheel should take a majority of the shock loads otherwise it wouldnt be a flywheel by definition
Re: J series ecu
« Reply #46 on: February 17, 2012, 06:36:21 PM »
i wouldnt trust those bolts to hold that kind of force much above stock hp levels
fe3tcourier
Re: J series ecu
« Reply #47 on: February 17, 2012, 09:15:34 PM »
Fuck that :-/
Re: J series ecu
« Reply #48 on: February 17, 2012, 10:02:41 PM »
Pussies
Re: J series ecu
« Reply #49 on: February 18, 2012, 01:35:26 AM »
I wouldnt worry once its spinning the gyroscopic effect you know it as tq is keeping that disk right where its at.
Re: J series ecu
« Reply #50 on: February 18, 2012, 01:54:01 AM »
The aluminum can deform if a clutch grabs too hard, giving the bolts space/play to bend. An alum flywheel is thin where the bolts attach and a large radius around them, so the clamping force keeps the holes from deforming. That spacer has hardly a quarter inch beyond the holes on the TO bearing side where nothing braces it.
It's also between 2 parts that create lots of vibration - one can chatter, the other creates harmonic vibrations. Those WILL make it worse. Aluminum doens't work-harden either, it fatigues.
Re: J series ecu
« Reply #51 on: February 18, 2012, 11:14:24 PM »
fe3tcourier
Re: J series ecu
« Reply #52 on: February 20, 2012, 06:38:35 PM »
Re: J series ecu
« Reply #53 on: February 21, 2012, 01:54:49 PM »
Re: J series ecu
« Reply #54 on: February 21, 2012, 03:20:08 PM »
fe3tcourier
Re: J series ecu
« Reply #55 on: September 07, 2012, 04:47:26 AM »
FYI, FreeEMS has tested J series native decoding now. Works nicely. Only limitations are the rest of the system :-)
Re: J series ecu
« Reply #56 on: September 07, 2012, 10:06:03 AM »
Awesome to here, so the kid (engine #10) in Wyoming w/ twin turbo v-6 accord got everything working well?
fe3tcourier
Re: J series ecu
« Reply #57 on: September 07, 2012, 01:09:26 PM »
Yeah, he sent me a datalog that looked good :-)
Later we'll knock out a fast-start version that uses both cams, but it only affects starting, and it's already pretty quick to start, so not a priority.
Re: J series ecu
« Reply #58 on: September 07, 2012, 02:01:43 PM »
May need to get a hold of him, if I keep getting tuning J-series for boost inquiries.  :noel:
fe3tcourier
Re: J series ecu
« Reply #59 on: September 07, 2012, 08:56:55 PM »
You could, or you could get hold of me! :-p
Pages: 1 [2] 3 4   Go Up
