Author Topic: Fuel lines  (Read 137596 times)
Fuel lines
« on: November 18, 2011, 11:59:23 AM »
Thinking about upgrading my fuel lines on my crx to either -6 or -8 from the gas tank to the fuel rail. Any one have a good write up. Hard line or braided?
Re: Fuel lines
« Reply #1 on: November 18, 2011, 12:22:38 PM »
3/8" hard line from tank to firewall, AN braided line from firewall to rail.
Gold DA9
  • OG LURKER
Re: Fuel lines
« Reply #2 on: November 18, 2011, 05:27:46 PM »
My setup on my hatch -6 from stock fuel filter to 044 to -6 to rail. Will be a -6 from regulator to stock return.
If i get this car in two weeks, im not sure what I will do. But I do want to redo the whole feed line as a -6.
theidealone
Re: Fuel lines
« Reply #3 on: November 18, 2011, 06:34:09 PM »
Get the NPT to -6 90* adapter to remove the banjo fitting at the tank. Then run AN all the way to the rail. There is also a -6 fitting to go into the stock rail. You can remove every banjo bolt fitting in the car. Thats how I did it. I think I spent about 300, but that also included fittings, hose ends, and filter to put my 255 inline as well.
theidealone
Re: Fuel lines
« Reply #4 on: November 18, 2011, 06:46:10 PM »
Heres my part numbers from my invoice with Jegs. I also had a few parts that I ordered from Earl's, because Jegs didnt have them, or stock them.
4   4   555-110001   #6  STR HOSE END BLACK   4.99   19.96
2   2   799-670470    ADAPTER 6AN MALE TO M10 X   11.99   23.98
1   1   555-110912   #6  LTWT BLACK HOSE 10-FT    59.99    59.99
1   1   555-82035    CUSHION CLAMPS 6AN (10)    9.49    9.49
1   1   799-650133    FUEL FILTER COMP #6 BLACK     24.99    24.99
1   1   799-651670    ELEMENT FOR 5010/13/14   6.99   6.99
1   1   555-80551    WRENCH -6 AN    9.99    9.99
I think I had this for the fitting from the pump (to get rid of the banjo)
AT949091    -6   12mmx1.25    90Deg. METRIC. Male to Male A.N Swivel. Black.       14.56
And then something like this for my fuel rail. Cant remember what the thread pitch was.
Re: Fuel lines
« Reply #5 on: November 18, 2011, 06:53:12 PM »
Awesome, thanks for the part numbers.  :noel:
theidealone
Re: Fuel lines
« Reply #6 on: November 18, 2011, 07:41:53 PM »
I think this was the one for the fuel rail
991945    12mmx1.25   -6    Carburetor Adapter Solex, Dellorto, Mikuni       7.45
theidealone
Re: Fuel lines
« Reply #7 on: November 18, 2011, 07:48:59 PM »
Oh, and I ordered one of these too.
AT935106    -6    90Deg. Tube Bent, AN Female to AN Female       13.15
Ran that from the fuel rail fitting, to the filter, and then hose back to the inline pump, from the inline pump to the fitting into the tank.
Hold on. Lemme spoon feed you some pictures too. :)
Fuel pump hanger.
Hose end with braided line hooked up.
Fitting in the rail.
Rail. Adapter. Female 90* Adapter. Fuel Filter. Hose End. Braided Line.
255 Inline.
And some pics before I put it in the car.
Stock filter and lines removed.
« Last Edit: January 01, 2013, 10:25:09 PM by theidealone »
Re: Fuel lines
« Reply #8 on: November 18, 2011, 10:12:43 PM »
theidealone your the man!
Re: Fuel lines
« Reply #9 on: November 18, 2011, 10:25:32 PM »
I like to tap the rail for npt rather than rely on an o-ring. Sure they work, but why not eliminate a potential leak.
Gold DA9
  • OG LURKER
Re: Fuel lines
« Reply #10 on: November 19, 2011, 02:00:06 PM »
check out votionspeed.com  they got some cheap prices.
theidealone
Re: Fuel lines
« Reply #11 on: November 19, 2011, 02:20:17 PM »
Yea, I guess. Its got an aluminum crush washer thats lined with rubber on the inner diameter/hole. No issues with a leak. So I dunno why you would waste your time tapping the rail. But I guess you could do that.
And yea, VotionSpeed.com is local to me. But I dont like their fittings or hose. I have that stuff on my catch can setup, and I cant wait to change it out.
Gold DA9
  • OG LURKER
Re: Fuel lines
« Reply #12 on: November 19, 2011, 02:40:13 PM »
What dont you like about them. Please tell us. I was thinking about ordering some stuff from them. I got most of my fuel stuff from BR Fittings. Injectors from Tom. Want to redo the whole setup. Thinking about selling the 044 with bracket and fittings, and the TRE 255hp fuel pump(xenocrons). Then do a twin intank 300, 340, or 400.
theidealone
Re: Fuel lines
« Reply #13 on: November 20, 2011, 03:45:29 AM »
I dunno. Im not very familiar with a whole lot of fittings and hose ends. But the VotionSpeed ones have compression fittings in them, which I didnt think was common when it came to AN hose ends. The 90* has a pretty big radius, which on my valve cover hits the hood. The black hose is just the steel braided line coated or painted black. And Im not sold on the teflon lines yet. I really liked the Jegs hose ends and line that I ordered.
I cant say that the VotionSpeed ones wont work for a fuel setup. But I dont think I would put them in my own car. Not to mention, the Jegs "brand" fittings are pretty cheap anyways. A lot of people say Aeroquip makes the fittings for Jegs, and theyre just stamped with the Jegs logo. The quality was very nice. I would definitely recommend them (Jegs).
gringotegra
  • Smoking Bisimoto's Builds, 1 Car At A Time
  • BISIMOTO KILLER!!!!!!!
Re: Fuel lines
« Reply #14 on: December 19, 2011, 02:58:54 AM »
I would stay away form the 340's, i have already killed one in my car and we have seen 1 die in a customers car for NO apparent reason at all... Twin 255's in parallel setup get pretty damn far and are cheaper than everything else...
Re: Fuel lines
« Reply #15 on: December 19, 2011, 11:11:22 AM »
Friend installed 2 340's to replace 2 255 then relized his car was going super lean, rewired the 2 340's and car still went lean. Rip out the 340's and through the 255's back in, issue gone.
255>340....... :?:
Re: Fuel lines
« Reply #16 on: December 19, 2011, 01:29:13 PM »
255>340....... :?:
Comparing the charts:
Never used the 340 yet but I have 2 cdm 255lph HP sames as the ones Xeno sells and have good flow.
So good that the stock fprs get ruined and my fuel pressure goes past 200psi.  :noel:
But I also have a boost-a-pump digital box to keep the voltage to my pump 15v all the time and bump up to 22v under boost if I want.
Re: Fuel lines
« Reply #17 on: December 19, 2011, 01:44:02 PM »
Damn russ you have enough fuel for you and bdv
Re: Fuel lines
« Reply #18 on: December 19, 2011, 01:51:09 PM »
Yeah now I just need to update the fuel lines, with larger lines and filter, to the engine.
And build a new killer D, w/ vitaras, Cunningham rods, ported y8 head, ported z6 mani, pristine A6 crank and A6 block.  :noel:
Re: Fuel lines
« Reply #19 on: December 19, 2011, 02:43:23 PM »
Dont you have a few vitara blocks?
SDRAWKCAB
  • D series BALLA!
  • Rhino
Re: Fuel lines
« Reply #20 on: December 19, 2011, 03:26:32 PM »
Re: Fuel lines
« Reply #21 on: December 19, 2011, 03:29:21 PM »
Just one, and it has a stripped bolt for s/c mounting.
It also has cyl. wall finish I do not like, and oil pan rail surface that has too much damage.
I really want to build a6 block b/c I need to use a fresh set of rods and minty so I can a better peice of mind.
Re: Fuel lines
« Reply #22 on: December 19, 2011, 04:41:50 PM »
Whats wrong with the rods in that block?
Re: Fuel lines
« Reply #23 on: December 19, 2011, 04:51:49 PM »
The B.E. are still in good shape, but two of the rods have a bit of blue to them.  :noel:
And I needed an excuse for using the Cunningham rods.  ;DDD
NoPistons!
Re: Fuel lines
« Reply #24 on: January 28, 2012, 08:51:45 AM »
Title says "fuel lines" but i'd like to put my question here.  Just in case.
You guys running in tank and external inlines.....    Is it bad to run a stock pump in the tank to feed an inline without a surge tank?   Meaning, will the larger flowing pump fuck with the stock pump that can only pump so much TO the larger pump?
Esplain plz.
Re: Fuel lines
« Reply #25 on: January 28, 2012, 01:09:02 PM »
I think the larger pump will actually draw through the smaller pump, making it easier for it to feed it. Since the smaller pump is being "sucked" on rather than pushing against the reg to make pressure it is ok.
NoPistons!
Re: Fuel lines
« Reply #26 on: January 28, 2012, 05:22:11 PM »
That's what i was thinking.  Thanks.
Didn't know whether or not you guys were upgrading both or what.
« Last Edit: January 28, 2012, 05:24:32 PM by NoPistons! »
theidealone
Re: Fuel lines
« Reply #27 on: January 29, 2012, 08:29:32 PM »
Walbros are <90 bucks. Why not just upgrade it for peace of mind? Or make a homemade surge tank...
Re: Fuel lines
« Reply #28 on: January 30, 2012, 11:10:51 AM »
You just gave me a idea, home made surge tank with a walbro 400 either feeding into or pulling from.
Re: Fuel lines
« Reply #29 on: January 30, 2012, 12:01:45 PM »
In for a build thread on this.  :noel:
