Author Topic: My slacking is comming to an end, at least on this project. Check it out.  (Read 8051 times)
This is product I had an idea for a few years back,  A few of us got it got 90% finished, and now is finally in the finishing stages.     Some of you know what it is, and the rest of you should be able to figure out what it is or does.   Its universal, but the first target market is Honda.
It should be in engine management but Im excited so deal with it.
Re: My slacking is comming to an end, at least on this project. Check it out.
« Reply #1 on: February 12, 2012, 08:21:17 AM »
I didn't know you were actively working on it. Cool deal. I like
DSharp
« Reply #2 on: February 12, 2012, 12:20:41 PM »
Cool.  please tell more!  Cost?
« Reply #3 on: February 12, 2012, 12:44:01 PM »
You could market this to tell how awesome your drifting is. :P
Are you using the ABS sensors for the rear wheel speed? What would be cool is if it could output a signal at a certain % difference, then have the EMS retard timing or reduce boost. Now that I think about it, you could wire in a boost retard box, but have the wheelspin activate it when needed. I know a lot of OEM's have very abrupt timing changes already.
« Reply #4 on: February 12, 2012, 03:38:29 PM »
Jesus christ. Took you long enough.
Now hurry up before May
« Reply #5 on: February 12, 2012, 04:29:34 PM »
Fucking titties!
DSharp
« Reply #6 on: February 12, 2012, 07:55:57 PM »
It would be even cooler if the end user could set the slip ratio it starts at and the rate at witch it drops cylinders/ timing however your going to do it.
« Last Edit: February 12, 2012, 08:11:09 PM by DSharp »
« Reply #7 on: February 12, 2012, 08:07:28 PM »
Finish your porsche
« Reply #9 on: February 12, 2012, 08:34:15 PM »
theidealone
« Reply #10 on: February 13, 2012, 01:04:55 AM »
Is it just for datalogging, or do you have plans on incorporating a traction control system into it????
« Reply #11 on: February 13, 2012, 01:07:47 AM »
 There is front and rear abs input,  F&R 0-5v out, and 0-5v slip(delta) output. Currently we/re working with Neptune to use this as boost per speed using rear wheel speed, and then actual traction control.
The cool thing is that will will work with almost any tunable ecu.  If even it doesnt have specific application for this, that you can use the 0-5v outputs to log the wheel speeds, and/or slip allowing the user to make manual changes to correct the traction loss.
The slip output voltage increase as the rate of change(slip/tires spinning/traction loss) between the front and rear wheels changes.   Its all about having the data, and this will allow you to be able to see it.
Hopefully will be for sale in a couple months,  maybe sooner.  Still working on price.
« Last Edit: February 13, 2012, 01:10:50 AM by sewell94 »
« Reply #12 on: February 13, 2012, 01:46:25 AM »
one burrito grande?
 :mexi:
« Reply #13 on: February 14, 2012, 04:50:18 AM »
goddamn your lazy
bouncinofftherevlimiter
No longer own a turbo car...
HX35 18lb 486hp/391tq
« Reply #15 on: February 14, 2012, 06:36:33 PM »
Sounds like you've got your ducks in a row already. 0-5v output will make things very easy to deal with.
I can see making a stand-alone setup by controlling a timing retard box with a microcontroller, or even directly if the output is configured right. You could also configure a microcontroller to interface between the boost solenoid to cut duty cycle, and therefore boost.
