Author Topic: Eagle rod notching  (Read 21374 times)
That Guy
  • Fast and danger
Eagle rod notching
« on: April 15, 2009, 09:29:45 PM »
Did i fuck up this block or have i not ground deep enough, its about 3/4" wide and 1/4" deep and 1/4" over
Thanks again guys, build thread coming soon if my damn pistons would hurry up and get here
Re: Eagle rod notching
« Reply #1 on: April 15, 2009, 09:54:26 PM »
Looks good to me.  8)
That Guy
  • Fast and danger
« Reply #2 on: April 16, 2009, 12:59:23 AM »
Sweet, thanks for the tip with the ringless piston, never would have thought of that. I thought it should be enough, and im thinking now its the machine shops problem if its not enough. Thanks
caged
« Reply #3 on: April 16, 2009, 02:07:50 AM »
I did mine today and it looks the same as yours. Dont forget if you use the ARP 2000 rod bolts you need to notch the girdle.
That Guy
  • Fast and danger
« Reply #4 on: April 16, 2009, 02:33:29 AM »
oh shit i totally forgot about the girdle Thanks man damn that would have been no good, like when you wake up and the fat girl next to you is not only fat but ugly too
« Reply #5 on: April 16, 2009, 03:54:03 AM »
and sleeping on your arm.
That Guy
  • Fast and danger
« Reply #6 on: April 16, 2009, 03:55:36 AM »
...at your own place :'(
« Reply #7 on: April 16, 2009, 12:03:34 PM »
I didn't have to do that to mine. And I had it out once after building it, and still no hitting. Maybe the newer 94+ blocks had thicker girdles, mine was a 92 and had enough clearance. If your girdle or crank stretches 1/16-1/32" to close that gap, you have OTHER issues. Pistons expand less than 1/128" from heat, and thats when they have >1500*F gasses pressing on them.
BTW make sure you debur the edges. You don't want any cracks starting from those points.
imburne
    • TurboByHOLSET
« Reply #8 on: April 16, 2009, 05:20:02 PM »
you can sit a crank on some junk bearings and a ringless piston to know for sure if youre that worried about it
that is the absolute best way.
turboblack2door
« Reply #9 on: April 16, 2009, 07:15:58 PM »
on my jdm d15b i didn't have to notch the girdle with my fjt rods and ARP 2000 rod bolts O0
93 Honda Civic Del Sol -F22A6, H22 trans, Bisi rods, Aris pistons, Hondata S300, 1200cc RC injectors, e85, Koni Yellows, Ground Controls, fuck my expensive hobby
« Reply #10 on: April 16, 2009, 10:18:58 PM »
OMGZ!!!!11s
why would you mess up a perfectly good block liek that. this is what your suposed to do.
« Reply #11 on: April 16, 2009, 10:28:51 PM »
I built a 95 Z6 (in my car now) and didn't have to notch the girdle.
You don't always have to. On one Z6 built when I used TT rods and ARP 8740 bolts I didn't need to notch the girdle. On another build I used scat rods with ARP 2000 bolts and had to notch it.
Ravage70
« Reply #12 on: April 16, 2009, 10:34:12 PM »
OMGZ!!!!11s
hahahahahahahahahahaha
« Reply #13 on: April 16, 2009, 11:18:38 PM »
flt i beams, arp 2000 bolts, 93 z6 block, no girdle notching here.  it was close but had probably .050" clearance or more.  never tried with the filler gauge and it spun freely
That Guy
  • Fast and danger
« Reply #14 on: April 17, 2009, 12:12:16 PM »
I wonder if that guy cut those equally between all 4 to keep the weight balanced  :P I wonder even more if he used them...
« Reply #15 on: April 18, 2009, 01:35:13 AM »
OMGZ!!!!11s
haha that is pretty sweet  :yes:
« Reply #16 on: April 18, 2009, 09:05:08 PM »
lol, i should post them up for sale on HT under a fake name and see if any retards actually say they want them. i wonder what the fuck the guy was thinking while doing it lol. hahaha, was probly thinking hes onto some new shit, "wait till they see that i found an easir way to get them to fit in my D, suckers. im an innovator"
« Reply #17 on: April 18, 2009, 10:00:27 PM »
They will still be stronger then stock D rods...  :P
