Author Topic: Alternative valve cover venting?  (Read 16130 times)
MantisX
« on: April 16, 2009, 11:39:23 AM »
Found this whilst browsing through some D series forums.
http://vibrantperformance.com/catalog/product_info.php?cPath=1020_1208&products_id=1061
Apparently it screws into your oil filler hole and then you route it to a catchcan. Seems to be less work than welding bungs and baffling on a valvecover. What do you guys think? Im thinking about using one in conjunction with the ports on the back of my block.
MantisX
Ghetto_D
Re: Alternative valve cover venting?
« Reply #1 on: April 16, 2009, 12:25:27 PM »
why dont you just drill a hole in the cap, tap it and screw in 90° elbow and run a barb fitting and save yourself 58 bucks.
« Last Edit: April 16, 2009, 12:48:26 PM by Ghetto_D »
MantisX
« Reply #2 on: April 16, 2009, 12:36:45 PM »
I love this place. Im gonna HMT this after work. Tapping the cap like that though, wont I have issues due to no baffling? It might fill up my catchcan pretty quick. Then again I guess the 90 bend would act as a baffle?
« Reply #3 on: April 16, 2009, 01:07:25 PM »
« Reply #5 on: April 16, 2009, 07:54:08 PM »
If I can drill and tap an IM for vac lines anyone with a quarter of a brain should be able to drill and tap a VC.
widebody might need some help
BoostForLife
« Reply #6 on: April 17, 2009, 04:04:10 AM »
http://d-series.org/forums/forced-induction/109011-how-better-vent-your-valve-cover-out-welding-bungs.html
there ya go
dude tapped the 710 cap but put a breater onto original VC port?
At least the fucker used a monster energy can for a catch can.
