Author Topic: Rat Rod  (Read 34613 times)
Rat Rod
« on: April 25, 2012, 02:13:17 AM »
Sorry don't have any build up pics, in fact I just snapped these tonight after doing some tuning. Other then the body shell this was 100% hand built in his garage over the last couple years. He just got it on the road about a month ago and we have been doing a little tuning. It is probably about 450hp /900ft-lbs right now and weighs about 3000lbs. On our quick little test run after putting injectors in tonight it made 60psi of boost (was still climbing fast) with a quick stab of the throttle, the head lights are pretty iffy, and it is scary enough when you can see. Runs a Jag IRS rear end, and a 94 cummins 5.9 12v, with a 47RH transmission.
Re: Rat Rod
« Reply #1 on: April 25, 2012, 02:51:42 AM »
That is as RHMT and rat rod as possible. Solid work. Can we get better engine pics? Maybe a ripper vid?
Re: Rat Rod
« Reply #2 on: April 25, 2012, 08:21:41 AM »
Nice  :noel:
They really let you drive with that thing on public roads? Did you have to pass inspection or something?
Re: Rat Rod
« Reply #3 on: April 25, 2012, 08:27:46 AM »
More info on setup, rippers, and clearer pictures.......... please  ;DDD
superdaveosbourne
Re: Rat Rod
« Reply #4 on: April 25, 2012, 09:02:45 AM »
Holy fucking badass...
Re: Rat Rod
« Reply #5 on: April 25, 2012, 09:16:43 AM »
Looks like every other cummins 12v out there.  :P Yeah I will try to get some clearer engine pics this weekend.
Same with vids, we are supposed to do some early morning tuning on Saturday. So I will try to get a ripper vid then.
Re: Rat Rod
« Reply #6 on: April 25, 2012, 09:21:20 AM »
Nice  :noel:
Yes, in fact commercial vehicle inspection officers, and real police so far just give you thumps up.
Yes it did have to pass an inspection, but because the body and "vin" are from a Ford (can't remember if it is a model A or T or what) it only needs to conform to those standards. At that time there were no turn signals or seat belts or... Basically if the brakes and steering are safe it is good to go.
It does have turn signals and seat belts (albeit just lap belts)
Re: Rat Rod
« Reply #7 on: April 25, 2012, 09:23:28 AM »
What else do you want to know?
Clearer pictures probably aren't going to happen, the only camera I own is my cell phone. I will take some ripper vids next time I am out in it.
Re: Rat Rod
« Reply #8 on: April 25, 2012, 09:28:12 AM »
I approve of this build!
Re: Rat Rod
« Reply #9 on: April 25, 2012, 09:30:41 AM »
Didnt i see this in HotRod last week or something?
Re: Rat Rod
« Reply #10 on: April 25, 2012, 09:43:38 AM »
Not a chance. It has only been complete enough to be on the road for about a week.
Re: Rat Rod
« Reply #11 on: April 25, 2012, 10:24:29 AM »
The ones in hotrod were far from ratrods. They were high dollar cars that just looked like junk.
Re: Rat Rod
« Reply #12 on: April 25, 2012, 10:59:34 AM »
Iirc he has right around $5k in the whole build.
Re: Rat Rod
« Reply #13 on: April 25, 2012, 11:30:23 AM »
I wan to do a modern take on a rate rod, using a newer chassis.  :noel:
My car at one time look like it had a bit rat to it. Now you have to open the hood to see a little.  :noel:
Re: Rat Rod
« Reply #14 on: April 25, 2012, 12:15:43 PM »
My car at one time look like it had a bit rat to it. Now you have to open the hood to see  A LOT :noel:
Re: Rat Rod
« Reply #15 on: April 25, 2012, 03:09:51 PM »
Oh my fuck...
Re: Rat Rod
« Reply #16 on: April 25, 2012, 04:55:38 PM »
Oh my fuck...
Best part is, once the transmission gets built this winter, we will turn up the power till it will run with your accord on a hiway roll.  O0 The turbo setup on it should be good for ~750whp or so.
Re: Rat Rod
« Reply #17 on: April 25, 2012, 09:17:30 PM »
Kinda like the ratiness of the bfg's but that thing calls for some ET streets.
Re: Rat Rod
« Reply #18 on: April 26, 2012, 12:12:56 AM »
I think the diesel makes it that much more "rat". The only thing that screams junk (to the average joe) more than rusty panels is a stack of thick, black soot.
Re: Rat Rod
« Reply #19 on: April 26, 2012, 01:39:38 AM »
I was over there again tonight we were bumping the line pressure on the transmission, hoping to get it to live for the summer. I couldn't remember the year when I made the OP, but it is a 1927 coupe. Here are a couple more pics for people that asked for more. Didn't do any test drives tonight so no ripper vids yet.
tekno
Re: Rat Rod
« Reply #20 on: April 26, 2012, 11:09:25 AM »
looks like a deathtrap hope that thing is gonna get some harnesses :o might have gone a lil overboard with the random ass trinkets/junk though that said i'd drive the shit out of it.
Re: Rat Rod
« Reply #21 on: April 26, 2012, 11:40:01 AM »
It is surprisingly stable, but nope just staying with lap belts.
Re: Rat Rod
« Reply #22 on: April 26, 2012, 03:28:13 PM »
slappynuts
Re: Rat Rod
« Reply #23 on: April 26, 2012, 09:20:33 PM »
Love the barb wire grill.
Re: Rat Rod
« Reply #25 on: April 27, 2012, 12:29:54 AM »
There's a fucking tree that grown up into it.
your going to need more clr
bouncinofftherevlimiter
Re: Rat Rod
« Reply #26 on: April 27, 2012, 12:36:18 AM »
I didn't realize it was compounds in the first pics, now seeing that makes it so much better! was wondering how it made 60# so easily...
Specs of turbo/injectors/ect?
No longer own a turbo car...
HX35 18lb 486hp/391tq
Re: Rat Rod
« Reply #27 on: April 27, 2012, 12:54:27 AM »
T4 HX40 secondary, HT3B primary, 7x0.010 SDX sticks, Mack rack plug (just put it in haven't run it yet since) no plate, 4kgsk, and about 20 degrees of timing, on a 160 pump. The owner monkey'd around with the afc some as well, but it hasn't been modded or setup yet.
Re: Rat Rod
« Reply #28 on: April 27, 2012, 01:01:18 AM »
Here are a couple earlier pics when it was still under construction (forgot I had these) Shows the turbo's a little more clearly. The owner was throwing around the idea of building an a/w intercooler into that blower case, and using the pulley on the case to drive a water pump for the setup. Ultimately he decided it was already hard to see out of it, and with that big blower case right in his field of vision it was better left as it is now.
Re: Rat Rod
« Reply #29 on: April 27, 2012, 07:55:56 AM »
I loled, but no! It's a rat rod man  :noel:
