Author Topic: Turbo Mounting Idea  (Read 30226 times)
Turbo Mounting Idea
« on: April 26, 2012, 01:36:22 AM »
I'm working on getting the He351ve in the mix on my car.
So if I do this
I have to move radiator and cut a lot in the new radiator support .
If I do this
I do not have to move the radiator, and I have almost direct line to the exhaust.
Problem I see is may have weird oil drainage angle.
What do you Nogs think?
Re: Turbo Mounting Idea
« Reply #1 on: April 26, 2012, 01:40:48 AM »
I think the thrust bearings will last about 2 minutes and then you will have a garbage turbo like that.
« Reply #2 on: April 26, 2012, 01:44:26 AM »
So what is the min. angle I should use?  :noel:
« Reply #3 on: April 26, 2012, 01:47:09 AM »
No more then about 15-20 degrees from horizontal in any direction.
weirtech
    • Weir Technologies Inc.
« Reply #4 on: April 27, 2012, 09:26:45 AM »
i believe garrett suggests no more than 15 degrees.
the twin charge setup i did a few years back was 10 degrees.
« Reply #5 on: April 27, 2012, 12:58:48 PM »
Russ
For an "engineer"....
You are a TOTAL nigger.
That is all
PS: My goal today is to incorporate nigger in context in every post on rHMT today.  Its been easy so far
 O0
« Reply #6 on: April 27, 2012, 04:16:10 PM »
I was going to add a thought here but Brian covered it.
« Reply #7 on: April 27, 2012, 04:34:14 PM »
Troll post?
« Reply #8 on: May 01, 2012, 01:42:04 AM »
What about changing the radiator to the VW one that fits under the front t bar?
« Reply #9 on: May 01, 2012, 08:16:10 AM »
Thought about this until I got the turbo in and a lot of it tucks under the support.
« Reply #10 on: May 01, 2012, 08:36:55 AM »
Radiator supports are overrated anyway
« Reply #11 on: May 01, 2012, 08:40:41 AM »
It was brand new, free for me.  :noel:
« Reply #12 on: May 01, 2012, 09:51:10 AM »
Please tell me you are going to support that silly turbo from something other then just the flange on the manifold.
« Reply #13 on: May 01, 2012, 11:11:13 AM »
Yeap the compressor housing is up against the supercharger all nice and snug.
« Reply #14 on: May 01, 2012, 11:23:42 AM »
This thread smells like anus
« Reply #15 on: May 01, 2012, 12:30:21 PM »
i dont know why you want to over complicate the boost process so much.
NoPistons!
« Reply #16 on: May 03, 2012, 09:17:03 PM »
Wait, you can  weld yet haven't moved your core support?
$17 front end.   fuck value depreciation.
You dont need to hack your tubs all to shit either.   Visualize where you need stuff to go and destroy whatever is in the way.
7808
« Reply #17 on: May 04, 2012, 02:34:22 AM »
thats what i would do.  probly stronger then those flimsy rad supports anyways. pussy
« Reply #18 on: May 04, 2012, 11:06:29 AM »
This also works in life
« Reply #19 on: May 04, 2012, 03:31:31 PM »
And you mom's anus.
« Reply #20 on: May 04, 2012, 05:14:29 PM »
and your own
« Reply #21 on: May 04, 2012, 05:14:44 PM »
And you mom's anus.
Target: colon.  Engage!
I knew it was only a matter of time..
« Reply #22 on: May 05, 2012, 09:57:51 PM »
With it located like that in the pic, what about looking for a radiator that can fit under the front rad support.  Im sure theres something out there.
With all the turbo builds on the internet, your avoiding the only two routes:  Blow too much money for a simple fix, OR cut and weld like rhmt pipe hitting mother fuckers do to make room O0 :mexi: :noel:
NoPistons!
« Reply #23 on: May 06, 2012, 06:09:17 PM »
Seriously mind blown this thread exists.  Obvious troll.  I'm sure.
Hell, if you wanted to you could probably sit that son of a bitch sideways and tuck it under the support.   Maybe just jb weld the rad cap shut and get one of those tube things with the cap on em to put up high somewhere.  I dont fucking know.  It's your car but i highly suggest going full retard and thinking outside the box a little so we can fap to compound boost rippers.
Edit:     Those rear mount (anus affiliated?) turdblow setups get their oil pulled with a scavenge pump (wha?).   The core support isn't doing shit.  it's just.....there.   A fine looking technological marvel of recycled Japanese toaster oven shaped into a thin strip.  Relax.    I'm sure more people have died from driving stupid or getting broke off by a shark hitting full boost than no radiator core support.     Get a tucked radiator or buy a small bar and plate and have someone mod the tanks.  I dunno.  Do something.  that whole thing about single cams being more aerodynamic is bullshit.
« Last Edit: May 06, 2012, 07:27:49 PM by NoPistons! »
