Pages: 1 ... 22 23 [24] 25 26 ... 47   Go Down
Author Topic: UI's 703hp Purple beast - She is injured  (Read 832473 times)
Re: UI's 703hp Purple beast - DE NEGRO RIGGING pg 19
« Reply #690 on: March 23, 2010, 06:32:39 PM »
I fucking hate the turbo and I sell it. No big deal, at the end of the day what am I here for? Controversy.
Prince - Controversy
« Reply #691 on: March 23, 2010, 06:37:23 PM »
Now JD, Weve covered this before. Fuck your mother, shes free, the dumb whore isnt even smart enoughto realize she could make money for the Cock she slobbers on that belongs to old decreppid quadrapalegic black maen that reek of sweaty balls, poop and mad dog 20/20
 I could give a fuck... But its sure fun stating the obvious.
« Reply #692 on: March 23, 2010, 07:21:28 PM »
one thing is for sure. the cleared cast looks good on the LCAs
« Reply #693 on: March 23, 2010, 07:30:56 PM »
GERP
« Reply #694 on: March 24, 2010, 11:21:04 PM »
I need to make some things clear. I DID NOT "build" Levi's car. I built the engine, and turbo system, thats it, thats all. I did not install the engine, or any other parts on the car, the majority of the engine and chassis parts were not my decision. Levi is a friend of mine and I am just helping him out.
You guys can make fun of his IC, we went over this in another thread but his cooling system issues are wound around his complete lack of a fan shroud for his radiator, as soon as he puts a shroud on his rad the cooling issues will go away.
I never wanted Levi's car to leave without a cage, luckily he is bringing the car down here in a few weeks so I can put one in for him.
« Reply #695 on: March 24, 2010, 11:55:14 PM »
My point is and continues to be that dime a dozen turbo B-series Civics with normal sized ICs and no shrouding have no problem with either IATs or with overheating.  You can spend more money on such a large core and you can spend more money on fabricating shrouding; at the end of the day you've spent more money and nothing else.
I've been through some 650-800 whp drag Civics that struggle to get up to temperature between passes.  That better be some voodoo shrouding because heat has a direct effect on engine life at those power levels.
« Reply #696 on: March 25, 2010, 01:44:54 AM »
The problem with that still remains that this engine ONLY has an overheating issue when not moving, when the car moves it has no problem staying cool. Hence the ic not being the root issue. All he needs is a basic shroud so that when the car is not moving there is still some air passing across the core. I'm not saying there couldn't be other cooling system issues, and as stated I am not very familiar with these specific engines. But to say the ic is the cause of his overheating issues is silly.
« Reply #697 on: March 25, 2010, 02:40:58 AM »
I see your point on that.
« Reply #698 on: March 25, 2010, 03:00:26 AM »
hgowever that IC is the aids and completely unneccesary
« Reply #699 on: March 25, 2010, 03:08:02 AM »
Motor ready for some cast alum. style paint
« Reply #700 on: March 25, 2010, 09:19:44 PM »
I'm not sure what Levi has told you guys but Dave didn't build this car. He built the turbo setup for a charger that Levi supplied, and assembled a motor that Laskey fucked up on. Levi is the one that decided not to cage it. The engine was installed and wired by Levi. The only thing that can be held against Dave is the gigantic endtanks that seem to work but wouldn't have been my choice had it been my car.
« Reply #701 on: March 26, 2010, 12:45:59 AM »
So are 4 valve heads, tubular manifolds, fuel injection...
« Reply #702 on: March 26, 2010, 09:23:12 PM »
you need to do something about the rust on the cam adjustment bolts
« Reply #703 on: March 26, 2010, 09:34:05 PM »
No those ar eneccessary... That fucking fmic is not.  You guys should paint it blue
« Reply #704 on: March 26, 2010, 11:41:33 PM »
Necessary for what? To quickly sum the purpose of 4 valve heads, tubular manifolds and electronic fuel injection is simple, its all about efficiency. You absolutely can use an old push rod heap of shit with you Holley 4 barrel to "make power" but your turbo Honda is capable of making as much or more power with less displacement, because it is a more efficient system. The aftercooler I built for Levi is more efficient than a heat exchanger with some box tube welded on the ends and a hole saw cut inlet.
« Reply #705 on: March 27, 2010, 12:43:50 AM »
Is that proven or plain theory?
« Reply #706 on: March 27, 2010, 01:22:46 AM »
I've tested it, I did a bunch of turbo system development work for a couple teams running the baja 1000 and pikes peak, aftercooler design was apart of the program. I spent a lot of time on the dyno and than data logging this kind of stuff.
« Reply #707 on: March 27, 2010, 12:58:09 PM »
or duplicolor maroon
« Reply #708 on: March 29, 2010, 01:42:48 AM »
Rust on the cam bolts has nothing to do with how easy BDLs strip out.  That's the problem with them.
Climb your happy ass onto yellowbullet.com and say that if you think I've got a mouth.  You may be blissfully unaware of a large, and extraordinarily affluent, portion of the automotive world but there are several of us who are not.
« Reply #709 on: March 29, 2010, 01:56:07 AM »
You completely missed the point, I recognize the ability to make power with old technology, but my point was that it is not as efficient. Like most things in life, there are many ways to go about accomplishing things, to get a final result, and some happen to be more efficient than others.
bouncinofftherevlimiter
« Reply #710 on: March 29, 2010, 08:03:26 AM »
YB would have fun with that one, those boys are hard on the honda guys, its mildly amusing....
No longer own a turbo car...
HX35 18lb 486hp/391tq
« Reply #711 on: March 29, 2010, 10:39:35 AM »
I find this mildly amusing as Dave is not a honda guy. I don't think other the drunken welding Tmathis's fuel rail (so really it was just welding, and he never touched the car), and helping Levi with his car, Dave has ever worked on another honda. In fact he makes his living selling performance parts to a crowd that look at small blocks "old technology" like amazing motors of the future.
« Reply #712 on: March 29, 2010, 02:48:27 PM »
From
To
« Reply #713 on: March 29, 2010, 02:50:48 PM »
looks good levi!
« Reply #714 on: March 29, 2010, 02:54:18 PM »
Looks good niglett. Shit the bay is gonn be looking sweet... Painted anytime soon???
« Reply #715 on: March 29, 2010, 02:57:57 PM »
Looks good man. So do you guys think you figured out the bucking, fucking, spitting and farting part of your car? So after its all done you gona follow in your HT style and do a wire tuck?  :P
« Last Edit: March 29, 2010, 02:59:29 PM by ratcityrex »
« Reply #716 on: March 29, 2010, 03:00:28 PM »
zolatone the engine bay nigglet
« Reply #717 on: March 29, 2010, 03:04:43 PM »
HT clowns dont run Holsluts...
LOL..
« Reply #718 on: March 29, 2010, 03:20:05 PM »
LOL..
Do HT clowns use these?
Levi I still dont understand why you are using these tow hooks......lol
But your still a good guy in my book.... :P
« Reply #719 on: March 29, 2010, 03:36:13 PM »
Indian's are like raccoons, they love shiny shit, and would rather die then let it go.  :P
Pages: 1 ... 22 23 [24] 25 26 ... 47   Go Up
