Author Topic: cheap sources for reliable threaded hall sensors  (Read 9057 times)
TTC
« on: June 26, 2012, 09:27:43 PM »
I am ditching my megasquirt and popping for  some sort of other standalone. Possibly a haltech, vipec or link and i want to ditch the ford VR sensor on the crank.
I plan to use a 36-1 toothed crank with a hall sensor and a single magnet hall config on the cam gear for the home signal.  Should I just hit up digikey and pick any hall sensor i want? Do certain hall sensors only read magnets and others teeth? I did some reading but havent found anything to straight forward.
Thinkng something like these.
http://www.motec.com/sensors/crankcamspeed/
http://www.digikey.com/product-highlights/us/en/hamlin-hall-effect-sensors/280
Apparently the hamlin needs a pullup, I duno if that applies no not MS units. Also looks like the hamlin doesnt work for high rpms on a 36-1 wheel.
Word.
« Last Edit: June 26, 2012, 09:40:18 PM by TTC »
Re: cheap sources for reliable threaded hall sensors
« Reply #1 on: July 03, 2012, 01:54:21 PM »
DIYautotune sells threaded Hall sensors for pretty cheap.
http://www.amazon.com/Hall-Threaded-Crankshaft-Position-Sensor/dp/B007QU0W0K
« Reply #2 on: July 04, 2012, 08:54:55 AM »
Hall sensors are like 2 dollars. Can you not put them in some sort of threaded tube and epoxy the ends?
Emperor
« Reply #4 on: July 04, 2012, 10:23:36 AM »
yes you can ;DDD
i did it and works great. just tray to get a straight one (ford)
drill out a bolt or something like your anal plug and secure the sensor with abit JBweld or loctite
much cheaper and faster since you can steal everything at the local junkyard :mexi:
RHMT Boost everything
-Cars
-Bikes
Minor Threat
« Reply #5 on: July 05, 2012, 05:11:40 PM »
Tom is a fag and will not do any of this.
kgx
  • MR2fag
« Reply #6 on: July 08, 2012, 04:31:18 AM »
Cherry switch does free samples. I requested 1 years ago and they sent me 2.
TTC
« Reply #7 on: July 16, 2012, 07:33:49 PM »
Pulling the trigger on an ems this week.
