Author Topic: K20EH2's Build Thread  (Read 37267 times)
Re: K20EH2's Build Thread
« Reply #30 on: July 29, 2012, 09:38:03 PM »
Hx35 will be fine for your power goal and they only come one size. Hx40 comes in multiple sizes
« Reply #31 on: August 06, 2012, 04:29:55 PM »
HX35 there is the 7 blade or 8 blade. And the majority of sizing options is in the exhaust housing ar mine is a 12cm. But (AJ) <--- thats me made 434whp on pump on my ls with the hype r head and gsr cams with -12cc comp wiseco pistons (8.5:1 comp) @ 28lbs of boost. Seems like alot but that was on 92 pump. And mine is the 7 blade.
RHMT 434 hp 329 tq LSV 26psi on pump gas [url=http://www.realhomemadeturbo.com]www.realhomemadeturbo.com[/url]
« Reply #32 on: August 06, 2012, 04:31:35 PM »
And that was on a smoothed out basemap by the NOG. Still daily driving this beast like that too.
« Reply #33 on: August 08, 2012, 10:59:05 AM »
Hx35 is a bad mother fucker! 500hp sohc at 30psi!
Gold DA9
  • OG LURKER
« Reply #34 on: August 09, 2012, 10:58:54 AM »
seen this in action and hope to see it again soon.
« Reply #35 on: August 09, 2012, 12:55:05 PM »
Need spray!
K20EH2
« Reply #36 on: October 17, 2012, 06:00:09 AM »
Haven't been here in awhile I actually started working on this POS.
So, I finally took my swap to a friends garage. I removed the stock flywheel, and put my competition ultra lightweight flywheel on with competition stage 4 6 puck. I also replaced the pilot ring and throw out bearing. I put the new OEM Honda Water Pump I had on and adjusted my Hybrid Racing Timing Belt Tensioner. I connected the wiring harness to every sensor available. I put the RBC on for the last time with the Hondata IMG and my Maxbore Throttle Body. Once I go pick up the bolts I need from Honda tomorrow I will be able to finish what I started today and have the swap ready to drop in the car.
I also got rid of the RDX 410s and picked up some Brand New Injector Dynamic 1000cc injectors.
« Reply #37 on: October 17, 2012, 09:32:44 AM »
DO WORK!
« Reply #38 on: October 17, 2012, 09:56:53 AM »
DO WORK!
you should have got hiprofile 900s.... support the community (unless you got the id's from sewell?)
K20EH2
« Reply #39 on: October 18, 2012, 12:28:58 AM »
DO WORK!
I have no idea what those are, and I have no idea who that is either. lol
« Reply #40 on: October 18, 2012, 11:41:36 AM »
You obviously haven't looked at my classifieds threads in this forum.
« Reply #41 on: October 18, 2012, 01:00:09 PM »
Mad Jewish dealz!! If you still have them in 2 years Ill probably need 8 for a LSx Project....
« Reply #42 on: October 20, 2012, 06:08:15 AM »
I have a couple sizes that will work for LSx, not just 900cc. LSx's usually use a 4bar fuel pressure, so add 15% to an injector's normal flow rating.
« Reply #43 on: October 20, 2012, 01:02:05 PM »
No turbo... WHJat in the fuck. GO kill yourself. Oh, and fuck your mother. yoou twinkle toed cock twirling faggot
