Author Topic: F23 into a 93 prelude vtec  (Read 19592 times)
SDRAWKCAB
  • D series BALLA!
  • Rhino
« on: April 21, 2009, 08:09:06 PM »
Heres the deal. I got a 93 prelude vtec with everything but the h22.
I bought a 2001 automatic f23 for 200 bones today and I have a couple of questions.
I sized up all the mounts and everything thing looks like it will swap over, but the driver side motor mount, the bracket on the motor is completely different.
Do I have to run a bracket off a h22/h23 to get the prelude one to work or do I have to do some welding?
Will the half shaft off the h22 work with the prelude s axels Im going to buy or do I have to get the s half shaft too?
Will a h22 dizzy fit on the f23 or do I have to source a f23/f22 one?
H22/f22/f23 flywheels are the same?
Car $150
motor $200
tow $50
total as of the moment $400  O0
Zeniceguycrx
Re: F23 into a 93 prelude vtec
« Reply #1 on: April 21, 2009, 09:21:32 PM »
My buddy has a 93 Lude with a H23
He smoked the engine and I swaped in a JDM F22 no problems or mods needed
The 30psi king of rice
« Reply #2 on: April 22, 2009, 02:26:17 AM »
That helped so much
« Reply #3 on: April 22, 2009, 04:07:49 AM »
Car $150
motor $200
tow $50
um on the bracket you just need to bolt up the stock one from the car originaly. the timing cover won't fit right but just make it happen.
  h22 and f23 dstributors are shaped why differantly the h22's are like and offset triangle and f23's have a typical triangular shape.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #4 on: April 22, 2009, 09:15:59 AM »
You answered my main concern. Thank you.  :-*
Obd2 dizzys can be used with obd1 you just have to change the plugs on the harness correct?
« Reply #5 on: April 22, 2009, 10:39:24 AM »
That is correct.
« Reply #6 on: April 22, 2009, 11:22:31 PM »
have f23 dizzy. 45 shipped
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #7 on: April 23, 2009, 08:16:44 AM »
I allready sourced one but if it dosent pull through Ill get that one off you.
Chris, will a d16z6 vtec solenoid work on the f23?
If not you got one that will fit for a good price?
« Reply #8 on: April 23, 2009, 01:59:21 PM »
No it will not. 35 shipped for solenoid with both sensors off f23
Vtec solenoids really are just for the head they came off etc. The d16z6 does fit dohc vtec b series heads but besides that noting interchanges between different series motors.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #9 on: April 23, 2009, 04:09:55 PM »
Well you wouldn't happen to have a driver side motor mount bracket for a 93 prelude on your hands?
That would make me happier then a pig in shit.
And I could get you the money tomorrow for both.
« Reply #10 on: April 23, 2009, 04:17:30 PM »
I did like 3 weeks ago sorry. Ill have another h22 im parting out in like a month but Im sure you want to get this thing on the road
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #11 on: April 23, 2009, 04:26:49 PM »
Ok, why didn't you say so then?
I can wait, the civic still running strong, Ill just have to title the prelude so code can't say anything.
I need
f23 vtak solenoid
flywheel and bolts
f23 valve cover bolts and rubber grommets
DS motor mount bracket
If you have all for this you are the man!
If you need anything In trade I have
z6 head complete
y8 valve cover
HF mani with heat shield
h22 cat
tons of other random shit
CASH! O0
« Reply #12 on: April 24, 2009, 09:35:15 PM »
I run a business/2 websites/engineer new part development things like the 1000 sq ft of used parts in my shop kinda skip my mind
Only thing I need is d16z6 intake manifolds and oem honda cat converters
90LSPimpin
    • RCAutoworks
« Reply #13 on: April 24, 2009, 10:03:25 PM »
we're doin pretty much the same swap right now at the shop except ours is non-vtec. Like stated use the prelude bracket and cut the area that doesnt fit the cover, it also protrudes at the timing belt, all the mounts are the same. I might have the solenoid I'll look tomorrow.
