Author Topic: Best "WELFARE" engine managment system.  (Read 21071 times)
AstroVannin
« on: April 27, 2009, 02:04:33 PM »
Vehicle - 1991 Toyota Corolla, 4AFE.
Options
1) FMU + cold start injestors and psi switches.
2) SAFC + 626 Turbo injectors
3) 2bar map + 626 Turbo Injectors
This thing is a feild car (was going to be my navex car but I decided to focus on the Accord instead)... it was just decided it needed some more power for spinning "too big" farm tires in the mud.
All the items listed are things I already have, so I would prefer if I could use that shit. I know that NONE of the listed setups is "good" but Im only shooting for "good enough".
Cheap and dirty is the name of the game on this shit box. Max boost its going to see might be 10psi. (Mitsu TE04H turbo).
« Last Edit: April 27, 2009, 02:12:29 PM by AstroVannin »
Re: Best "WELFARE" engine managment system.
« Reply #1 on: April 27, 2009, 02:06:22 PM »
fmu and msd btm.
well with my tercel  i did a fmu and msd dis-2
« Reply #2 on: April 27, 2009, 02:06:53 PM »
Dude, pics?
« Reply #3 on: April 27, 2009, 06:25:13 PM »
VICE GRIPS.  O0
AstroVannin
« Reply #4 on: April 28, 2009, 09:50:21 AM »
VICE GRIPS.  O0
Ah ha ha ha ,,, SHIT... I forgot about that one..... What kinda boost were you running with the ....uh ..... "budget FMU". ??
« Reply #5 on: April 28, 2009, 07:50:56 PM »
VICE GRIPS.  O0
7-9psi, with iirc a  .42 T3
birdley42008
« Reply #6 on: April 28, 2009, 07:55:00 PM »
S-AFC plus BTM plus 2 Bar map sensor for the boost and the injectors.
AstroVannin
« Reply #7 on: April 29, 2009, 01:14:33 PM »
I assume you're refering to the "grey wire" mod on the SAFC?
Dweezil
    • Michigan Civics
« Reply #8 on: April 29, 2009, 01:39:22 PM »
You can always go with some work and CROME:
http://forum.pgmfi.org/viewtopic.php?f=35&t=13414
birdley42008
« Reply #9 on: April 29, 2009, 02:02:29 PM »
Grey wire mod? huh?
AstroVannin
« Reply #10 on: April 30, 2009, 09:05:43 AM »
Grey wire mod? huh?
Using the TPS wire on a 2bar MAP sensor.
Idealy you set LO at atmosphere (so key on, car not running) then set HI at the TPS% shown at whatever you decided the max boost to be. Idealy, you have LO set across the board with the -% to compensate for the injectors (in my case it was -50%) then set the HI to whatever you determine the fuel needs to be at the highest boost level (yeah, its crude as fuck). As the TPS% increases with boost (since its hooked to the MAP right) it scales up the injectors accordingly.
I just assumed thats what you were refering to.
I did this for a while on the turbo Tercel ... it worked pretty good.
« Reply #11 on: May 02, 2009, 10:46:03 AM »
jagojon3 always swore by peniswhistle.
