Author Topic: air temp sensors?  (Read 29136 times)
air temp sensors?
« on: January 28, 2013, 01:07:31 AM »
so every time i see someone add an air temp sensor to convert a car to speed density or custom setup i see GM threaded IAT sensors. cheap and available i know.
but how reliable are they? how accurate are they?
i have Honda IAT sensors and plugs. those rarely go bad. they make threaded ones, or you can just cut the brass off a coolant sensor....
what spawns this question would be putting SD AEM EMS in the GVR4 that doesnt have an IAT sensor, and would need one added. i know that AEM has a Honda IAT programmed in it already, cuz well my Honda runs it lol.
learn me? lol
Re: air temp sensors?
« Reply #1 on: January 28, 2013, 02:41:12 AM »
I can't recall ever replacing a faulty GM IAT sensor.
« Reply #2 on: January 28, 2013, 08:06:13 AM »
I'd just use the Honda sensor. Drilling 3 holes and tapping 2 of them isn't difficult. Although, I have never replaced any iat sensor on any brand. They just work
« Reply #3 on: January 28, 2013, 09:01:38 AM »
It doesn't matter, AEM's air temperature correction is horribly broken.  Use whatever.
FYI, the open element or even non-Honda IATs shouldn't be used with an OBD1 Honda ECU.  They double as a MAT by design, and position, so they shouldn't be put in the charge piping/intake arm either.
« Reply #4 on: January 28, 2013, 10:50:40 AM »
well my question would be specific to a Galant VR-4, and a K-swapped vehicle.
on the current  homo 'engine management' that is in the Galant there isnt an IAT sensor and the voltage is clamped at 74° or someshit... and i have seen setups that run them free air in the engine bay... so i would assume it can be tuned around or not at all.
« Reply #5 on: January 28, 2013, 10:54:35 AM »
You asked an AEM specific question, my answer applies.
Your VR4 has an IAT in the MAF.  Sliderbarzzz clamps it because it has sliderbars that you can slide, yo!
« Reply #6 on: January 28, 2013, 11:05:10 AM »
you made a comment about obd1 honda.
its got a maf-translator 2.06...  :-X  and hopefully it will be gone before the new motor starts up, or shortly after, and i probably wont drive far on it...
« Reply #7 on: January 28, 2013, 12:08:51 PM »
JD:
Thoughts on cutting the plastic off the IAT Honduh SLow ass sensor... Located in the plenum... Using teh Mefth?
« Reply #8 on: January 28, 2013, 03:37:01 PM »
I made a FYI in a Honda-centric forum after I told you AEM's IAT comp is worth one stale - but not too stale - dog turd.
JD:
No.  Not only is that a bad idea, but the Honda sensor is not slow.  The temp changes neatly from MAT to IAT at the first sign of appreciable airmass.  Nothing wrong, don't fix it.
« Last Edit: January 28, 2013, 05:44:17 PM by Joseph Davis »
« Reply #9 on: January 28, 2013, 03:49:49 PM »
Interdasting.
« Reply #10 on: January 31, 2013, 10:42:52 PM »
legit?
« Reply #11 on: February 01, 2013, 01:41:12 AM »
Find out the thermocouple type and just use some damn tc wire.
How accurate is it? Probably +/- 5 deg f. Tc wire can be more accurate but i doubt the ecus ability to compensate for icepoint.
Most temp shit is off.
« Reply #12 on: February 01, 2013, 01:49:35 AM »
btw that pic i posted is of a ECT sensor, with the brass piece cut off the end.
« Reply #13 on: February 01, 2013, 08:10:14 AM »
JD:
No.  Not only is that a bad idea, but the Honda sensor is not slow. I love dongs.  The temp changes neatly from MAT to IAT at the first sign of appreciable airmass.  Nothing wrong, don't fix i
The mass around the tc wire will also create a smoothing effect and cause the wire to be less spastic
« Reply #14 on: February 01, 2013, 12:09:20 PM »
Unless I am missing something here, ECT, and IAT sensors are typically thermistors not thermocouples.  Not to mention they operate totally differently since a thermistor changes resistance with temp and thermocouples generate voltages with varying temps.
Dealing with cold junction compensation on a thermocouple adds even more bullshit that isn't needed.
« Reply #15 on: February 01, 2013, 01:40:39 PM »
Almosr every tc reader ive used compensates for cold junction comp. If not thry can be pretty wrong if you plug one into a dmm and check it. Jd told me most cars run k type tcs. Rtd is more accurate typically, but i rarely see anyone use rtd to monitor any process. I only use rtd to cal a2la ovens, dry wells, baths etc. Shrug. Send me an iat and ill tell you what it is and chart the values.
DmC
« Reply #16 on: February 01, 2013, 09:50:27 PM »
Evo8 ecu maf a jumper harness?
« Reply #17 on: February 01, 2013, 11:20:33 PM »
or...ill just run AEM. ive been fucking with it and running it in the CRX and i like it. i will be running it in my EKK, i can get it for same price/cheaper than the other options...
« Reply #18 on: February 02, 2013, 12:59:52 AM »
Pulled this off Alldata for a 1994 GSR.
I just can't see a thermocouple as a good solution for most automotive applications when it comes to inlet air and coolant temp.
Shrugs.
Unfortunately I don't have a spare IAT or ECT to pull apart.
« Reply #19 on: February 02, 2013, 04:35:42 AM »
Thats actually suprising to me. Tc can be accurate to like .5 deg c in real world conditions. I havent noticed aby real difference between the two as far as traversivity goes except on the higher end 4 wire comp rtd shiz. Submerged in coolant, the reading is almost instant.  I guess it doesnt matter too much, its interesting to think about, but irrelivant at the same time.
« Reply #20 on: February 03, 2013, 12:51:08 AM »
Probably because it doesn't pay to be dead accurate in most applications. If your MAP is off 5psi, yeah it's a prob, but with a sensor that's 5F off nothing bad is going to happen. More than likely your injectors are mismatched to a greater percentage than your IAT is off, and I mean air density.
« Reply #21 on: February 03, 2013, 12:17:40 PM »
LOL, no.
Most F-series and CRV motors have a screw in type IAT.
98-99 DSM or Evo8 ECU is a better option, IMO.
« Reply #22 on: February 03, 2013, 12:18:38 PM »
And for the EKK, you should convert to DBW and run a '06-11 Si ECU.  That's the most affordable way to run any K-series, if a bit labor intensive.
« Reply #23 on: February 03, 2013, 12:44:45 PM »
Bish please
« Reply #24 on: February 03, 2013, 01:28:52 PM »
Fuck.  Should have hosted that image myself.
