Pages: 1 2 [3] 4   Go Down
Author Topic: d15b7 blow up to D16z6 build  (Read 91626 times)
Re: d15b7 blow up to D16z6 build
« Reply #60 on: December 03, 2013, 02:12:07 PM »
Looks, good what part of Montana are you at?
Thanks, I'm in Bozeman, dumped 6+ inches yesterday and is 6* F right now....
Kool, expecting almost 10 straight days of snow here, got 1" so far  :noel:
Where are you at? haha snow is coming, its about to get really cold here too with a low of -17 tomorrow.... Up at the ski hill they have gotten 15" in last 24 hrs  ;DDD
Casper Wyoming, center of the state.  :noel:
« Reply #61 on: December 03, 2013, 06:31:27 PM »
Love the fake tail pipe!
Christo19
« Reply #62 on: January 09, 2014, 12:20:33 PM »
Thanks, I think its one of my favorite parts of the car, it messes with people haha
Car is just hanging out for the winter so far since I picked up a '94 S4 cheap, I am setting up my shop right now and will be bringing it in there in a little bit to tear into the suspension, brakes and some other stuff to have it ready for spring. Also I picked up this little baby for $100 the other day  :noel:
Thing is brand new, never used! Just has that small dent on the bottom you can see in the picture, the quality is great and damn is it heavy. Its the Spearco 650hp model 28x10.5x3.5, I will see if I can fit it on the civic well and keep it sleeper and if not it'll just have to go to another project.
« Reply #63 on: January 13, 2014, 11:09:03 AM »
nice score on the intercooler  :Jew:  sounds like the same core i use in the Galant.
Christo19
« Reply #64 on: March 08, 2014, 03:59:27 AM »
Well roads were finally good again and I took the honda out for a drive!
Now I have redone the rear brakes completely, drums/shoes/wheel cylinders and bled them as well as the clutch.
Gapped the plugs down to  .022" and went and tuned it!
I got a decent tune on it now running 15psi and its stupid fun. The car is fast, but I may turn it up a little more  :noel:.  My tranny is about to blow up though and it making all kinds of noises but I don't care since I have a spare waiting for it but I really want to find an EX tranny for it.
More plans coming up or the car soon, that I think you guys will really like
Sedrostyle
  • Turbine Noob
« Reply #65 on: March 08, 2014, 01:29:21 PM »
very good stuff.. Wish you actually had dyno numbers.. I'm very curious to where your at... Keep up the good work
Sleeper for the win
Christo19
« Reply #66 on: March 08, 2014, 02:22:53 PM »
I wish I had dyno numbers too! I will be getting on one in a month or so and will post up results
Christo19
« Reply #67 on: March 21, 2014, 11:19:03 AM »
Clutch is slipping  :-\. Time for an upgrade, and much more that you guys will love....stay tuned.
« Reply #68 on: March 21, 2014, 03:05:03 PM »
Time for a clutch and more boost!
« Reply #69 on: March 21, 2014, 05:39:00 PM »
mike at lsd motorsports for the clutch. In my integra i had his drager clutch with a street disk and i loved it. Wish i had one in my accord. Stock clutches feel like garbage
Christo19
« Reply #70 on: March 22, 2014, 12:48:07 AM »
pretty much!
As for a clutch, I may talk to him but I think I got a good deal set up for a CC stage 4
Christo19
« Reply #71 on: April 08, 2014, 10:58:00 AM »
Update:
-New Competion clutch stage 4 installed
-new stock flywheel installed
-LX tranny with 90k installed
-put in a poly filled tranny mount
-new rear main
-ES full bushing kit installed
-ES rear trailing arm bushings installed
-New inner tie rods and outer
-new brake pads
-SS braided brake lines
-Fresh DOT 4 brake fluid
-elderbrock performer X intake manifold installed
-gapped plugs down to .018"
-got an alignment
-put on my 15x7" wheels with some 205/50/r15 tires on them
Been tuning a lot and getting it smooth at 16 psi and it rips! Still no traction in 2nd and it sometimes spins a little in 3rd and torque steer is there pretty solid. I will be doing more tuning this week and the boost just may get turned up to 20 psi  O0  The suspension and brake work helped a ton, the car feels much better and safer haha. Just need some traction bars now, wheel hop can be pretty bad.
Only have a few pics but ill snap some more later
« Reply #72 on: April 08, 2014, 11:17:05 AM »
Doin' work  :noel:
« Reply #73 on: April 08, 2014, 11:28:48 AM »
GANGSTER! I love it. Keep us posted. Well since your in a eg.... Pick up some of those ebay traction bars. They are pretty inexpensive and work for a dc/eg. I WOULD NOT USE THEM IN A 88-91 CIVIC OR 90-93 INTEGRA. But you'll be fine because if the lower control arm design.
Christo19
« Reply #74 on: April 08, 2014, 11:36:19 AM »
I will do! I have thought about doing that but I think I am just going to build my own set up, I just need to get around to ordering the heim joints and I'll get to work on it.
« Reply #75 on: April 08, 2014, 12:52:16 PM »
Speedway motors. That's where I got my swedge tubes and heims when I built mine.
Christo19
« Reply #76 on: May 30, 2014, 01:26:35 PM »
So it wasn't planned but this happened.
Tuning it on a dyno later today for a little bit and then more on Monday
« Reply #77 on: May 30, 2014, 04:33:23 PM »
Fuck yea!
Christo19
« Reply #78 on: May 31, 2014, 01:27:31 AM »
Got it tuned pretty well tonight at 20 psi and it was scary, I loved it. The sound of that turbo is tooo good  :noel:
« Reply #79 on: May 31, 2014, 12:18:52 PM »
Any numbers?
« Reply #80 on: May 31, 2014, 01:10:57 PM »
Sexy injectors, they're so modern! ;)
Christo19
« Reply #81 on: May 31, 2014, 04:45:35 PM »
Numbers coming Monday! I think they will be pretty impressive, the car has a lot of lag but pulls sooooo hard on the top end and doesn't die off at all. The way this turbo spools, slow to 6psi but 6-20 happens in a blink of an eye, I plan tune the mid range a lot more and get the spool time down a bit.
I am loving these injectors, they are having zero problems fueling this set up, I am approaching 80% dc and boost will go up some more so I plan to find their limit  O0
I had been meaning to do this for a bit since I did not have proper crank case venting and I made my catch can have 3 fittings for a reason. I didn't have time to paint it or wait for AL fitting so I made this form over function style. works awesome, no more smoking
« Last Edit: May 31, 2014, 05:10:39 PM by Christo19 »
« Reply #82 on: May 31, 2014, 10:47:37 PM »
A good wack on the FPR around the vac nipple will net another 2-5% more fuel (5-10 psi). :evil:
Christo19
« Reply #83 on: June 02, 2014, 02:17:22 PM »
 O0 22 psi
« Reply #84 on: June 02, 2014, 02:22:08 PM »
« Reply #85 on: June 02, 2014, 04:34:04 PM »
Solid, now go to the RHMT meet next weekend  :noel:
« Reply #86 on: June 04, 2014, 10:12:07 AM »
That's a lot of power for vitara D16Z6, most people don't get half this far in twice the time. Judging by where it hits 200whp, it spools quicker than most D16's. You're making more than most stock b-series peak power by 4500 and more than most stock K's peaks by 5k, so I'd say you've done well.
BTW I love the rusty sleeper exhaust tip!
« Reply #87 on: June 04, 2014, 12:13:19 PM »
 O0 22 psi
Solid!
lol. soon as I seen the graph I said "solid!"...   :noel:
Christo19
« Reply #88 on: June 04, 2014, 01:54:39 PM »
Here is a video of a dyno pull at I think 20-21 psi
https://www.youtube.com/watch?v=zP_bhzXKF0k&feature=youtu.be
Thanks man! I think the spool could come down a little bit more through more tuning and definitively with a better EL turbo manifold. Also the amount of money I have spent to get it here isn't much at all, the $ to hp ratio is insane!
Thanks, I love telling people to go take a close look at the tail pipe and they look so confused till they figure it out then they love it haha.
Now I really want to do some head work: springs, 3 angle, light pnp and a mild cam, then rev the motor out to 7500 and see if I can make 400 on less boost and have better spool! But I think another project on it will have to happen first..........
Compound turbo!
« Last Edit: June 04, 2014, 01:56:23 PM by Christo19 »
« Reply #89 on: June 04, 2014, 05:06:08 PM »
If you do a compound turbo run a larger turbo than the one sitting in the above picture unbolted.  :noel:
Pages: 1 2 [3] 4   Go Up
