Author Topic: holset h1c or hy35  (Read 45714 times)
maleek
holset h1c or hy35
« on: February 06, 2013, 12:45:42 PM »
I'm looking to build a fun cheap street setup that has good useable power! I had a ching chong turbo but it's time to ditch it. Anybody here with a STOCK b18a/b, run a holset unit (either a hy35, or h1c) that can shed some light on their experience? I'm looking to make around ~300whp, and have a decent power band for street uses. Also, was anybody able to keep their ac/ps? I know holset units are known for being notoriously large.
Re: holset h1c or hy35
« Reply #1 on: February 06, 2013, 12:50:32 PM »
Hy35  :noel:
Are ya going to post a build tread and have you read the Noob of the year thread yet?
We have a tradition, so please follow, especially today. (it is Wednesday)
« Reply #2 on: February 06, 2013, 01:01:09 PM »
Post porn, or kill yourself! Then I will feed you all the info you want.
« Reply #3 on: February 06, 2013, 01:22:32 PM »
There is more holset info here than probably any other site. Follow the rules and be rewarded. I just tuned a car with one of those turbos.
« Reply #4 on: February 06, 2013, 01:24:48 PM »
H1cC generally all have too large a turbine housing to be much fun for a street car. HY35 would be good on a stock LS motor for sure. HX35 would be ideal.
Speed Phreak
  • I'm an OG because I say so.
« Reply #5 on: February 06, 2013, 01:33:17 PM »
What he said, HX35... be aware they are heavy turbos though. The HX35 I had weighted nearly 3x as much as the 60-1 I replaced it with.
Also, welcome and go fuck yourself.
1988 CRX HF - Turbo deathtrap
maleek
« Reply #6 on: February 06, 2013, 01:42:05 PM »
Wasn't aware i had to post porn. my apologies.
« Reply #7 on: February 06, 2013, 01:58:46 PM »
Good start, need more now....
« Reply #8 on: February 06, 2013, 01:59:41 PM »
The hy35 makes a great street car turbo. I just tuned a b16 with one. The spool with a log manifold was awesome and the power was intense. Probably the fastest b16 I have ever tuned.
maleek
« Reply #9 on: February 06, 2013, 02:14:27 PM »
I heard it is a popular choice with the b16 motors. but because im using a non vtec head, i'm losing alot of flow capabilities. Like i said, i'd hate to start spooling this turbo at  5500, and only be able to rev my motor to 7k!
« Reply #10 on: February 06, 2013, 02:46:47 PM »
Jeff, (jdmhatchracer94) did a ls with 8.0:1 compression pistons, delta 272/260 cams stock head I believe with a holset h1c, 12cm housing, and made 337whp and like 290tq. If I were you I would defiantly run the hy35. If you want a quick spool. It will carry your power to 7k easy. Once you get up in the power level(+350whp) it will start to level off on power. Assuming the motor is stock. What car is this in? I will then tell u if you can keep ps, and ac. Full size rad or half sized? What size injectors? and what ems system?
maleek
« Reply #11 on: February 06, 2013, 02:57:44 PM »
It's in a 1997 Integra. Currently using a ebay cast log manifold. Full rad (probably convert to an SI rad from the 99-00 civic) and dsm 440 injectors. Using crome pro for ems
« Reply #12 on: February 06, 2013, 03:04:41 PM »
I don't think you will fit an hy35 with eBay manifold. The b16 I tuned was in an 00si and had a t3/t4 with eBay cast manifold. We had to make a log to fit the holset in there. He has no a/c or p/s parts at all.
« Reply #13 on: February 06, 2013, 05:14:21 PM »
I have a lsv, rull sized stock rad and a hx35 in my 94 integra. It fits, but its fucking tight, and I have ps but no ac. But then again Im using a splog manifold, I had made. Not a cast ebay unit.
« Reply #14 on: February 06, 2013, 05:42:09 PM »
Yea, the placement with the cast mani is horrible for holsets.
Speed Phreak
« Reply #15 on: February 06, 2013, 08:20:53 PM »
I ended up hanging my HX35 off of an SSAC manifold a few years back...only worked for about 1000miles. Then the turbo pulled the welds apart on the cheap mani and the turbo literally fell off the engine in traffic...Good times.
« Reply #16 on: February 07, 2013, 12:46:16 AM »
I used a cast mani with an HY35 on a D-series in an ED chassis, fit ok with the half rad. The turbo faced the wrong way (inlet on pass side) so the downpipe was gay.
I used an HY and HX35 on an Ebay B-series ramhorn as well, fit great, braced both, no issues, ran 11s.
« Reply #17 on: February 07, 2013, 12:58:23 AM »
Either is fine. Hy will spool quicker and be a fun street car. The large comp h1c has the same compressor as the hx 35. I will be finding the limits of the h1c soon
maleek
« Reply #18 on: February 07, 2013, 09:12:12 PM »
Thanks for the replies.
Whats the difference between a hx35 and hy35 in spool time? The hx35 seems plentiful on ebay but the hy35, not so much..
Speed Phreak
« Reply #19 on: February 07, 2013, 10:16:43 PM »
Depends on displacement, stock LS with stock redline an HY35 will probably suit your need and wants better. If you have any plans to go bigger bore or V-TACH at any point, then i'd opt for the HX35.
« Reply #20 on: February 07, 2013, 11:00:09 PM »
In less you plan on some big cams, and a lot of boost, I would stick with the hy. The hx won't probably won't hit full boost untill the 5k mark. At which point the hy would have been at full boost for probably 1kby that time. Untill your revving your ls to 8k, I would try and go hy.
maleek
« Reply #21 on: February 07, 2013, 11:25:06 PM »
Thanks guys. Anybody an hy for sale? Im looking to start my build asap
« Reply #22 on: February 07, 2013, 11:34:30 PM »
Goldfarb
« Reply #23 on: February 07, 2013, 11:41:34 PM »
Or check saulg on ebay. Best bet is to call him.
Or check with carkrazed here. He had one a while back that I think he was talking about getting rid of.
« Last Edit: February 07, 2013, 11:43:36 PM by ratcityrex »
« Reply #24 on: February 08, 2013, 12:20:48 AM »
Saulg = goldfarb
« Reply #25 on: February 08, 2013, 12:50:21 AM »
My h1c at 20psi by 4200 the a 12cm housing
« Reply #26 on: February 08, 2013, 01:05:59 AM »
Yours also has cams, and a huge intake manifold and throttle body.
« Reply #27 on: February 08, 2013, 02:23:55 PM »
boosted 00 black si on here made close to 350hp on a bone stock ls with arp head studs using a h1c. Motor still running stong and doing dirty 3rds :noel:
« Reply #28 on: February 08, 2013, 03:09:48 PM »
But for a street car it ould be a lot of fun with a h1c. Power on tap with little lag time. I just remember the days of stock d16 with rhb5's and being at full boost by 2k.
maleek
« Reply #29 on: February 08, 2013, 04:43:05 PM »
Does anybody know what centimeter housing the h1c is available in? Planning to stick with the hy, but if i can find a housing close to the hy35, wouldn't that be a viable option as well?
While we're on the subject.. does anybody make flanges to position these massive things away from the block? I'll be running an oem half rad to make room in case we run into clearance issues with the engine.
