Pages: 1 2 3 [4] 5   Go Down
Author Topic: 2000 silverado 2500 LD (sloppy mechanics)  (Read 119493 times)
Re: 2000 silverado 2500 LD (sloppy mechanics)
« Reply #90 on: April 09, 2013, 10:27:05 AM »
this is 12-13 psi from the other day still
4-8-13 quick rip 40-95 mph from a rolll
Maybe more boost will change my mind (though I suspect that hotside is almost done already), but watching that video really makes me think that 80mm needs a twin.  :noel:
Christo19
« Reply #91 on: April 09, 2013, 10:44:22 AM »
Fucking awesome build man, love the turbo popping out of the hood!
Now go race all the big diesels with an exhaust and a tune and show them how to actually make a truck fast  ;DDD
denmah
« Reply #92 on: April 09, 2013, 10:12:03 PM »
well put her on the dyno and i put a trash can under it just in case
« Reply #93 on: April 09, 2013, 10:15:40 PM »
What boost?
denmah
« Reply #95 on: April 09, 2013, 10:30:54 PM »
Pretty similar to the twins then, minus like 200 ftlb down low.
What's next?
« Reply #96 on: April 10, 2013, 10:11:58 AM »
Man does that sound good!
« Reply #97 on: April 10, 2013, 12:24:20 PM »
Do you monitor drive pressure?
denmah
« Reply #98 on: April 10, 2013, 04:06:51 PM »
What's next?
burnouts,
decent tires
track pass
denmah
« Reply #99 on: April 10, 2013, 04:07:27 PM »
not currently, i think i would like to build a rig with a 1 way valve and test a bunch of our setups
« Reply #101 on: April 11, 2013, 10:02:41 AM »
Why the one way valve?
Just put a 1/8th npt port somewhere pre turbo, and run a foot or so of either thin copper line or brake line, or what ever you have around, and then attach normal boost line, or rubber hose again whatever you have around, and then a cheap liquid filled gauge. If the whole thing costs more then $15, you did it wrong, or went fancy.
denmah
« Reply #102 on: April 11, 2013, 02:25:20 PM »
i want something i can just hook up outside the car, do datalogging, check my peak boost in the datalog, and then see my peak drive pressure, and reset it, like a tire pressure gauge with a release.
thats all
« Reply #103 on: April 11, 2013, 02:41:27 PM »
Map sensor and a multimeter with a peak hold function? Or just use a Tire gauge hahha
« Reply #104 on: April 14, 2013, 03:32:09 PM »
Moar please.
k, thx, bye.
« Reply #105 on: April 14, 2013, 06:35:21 PM »
yeeeeeep. compression tester if you're runnin mad psi dog.
denmah
« Reply #106 on: April 14, 2013, 10:35:53 PM »
11.9 @ 121 on street tires LOL
5060 lbs with me in it
« Reply #107 on: April 14, 2013, 10:45:24 PM »
Awesome!!
« Reply #108 on: April 15, 2013, 06:42:40 AM »
Nice!
« Reply #109 on: April 15, 2013, 11:57:08 AM »
Fuck that thing is moving!
denmah
« Reply #110 on: April 15, 2013, 12:26:22 PM »
i didnt even get all the way into the pedal till about 200-250ft out to make sure it wouldnt spin.
still went 96 in the 8th she is a runner
« Reply #111 on: April 15, 2013, 01:32:00 PM »
Low 11s if you could get your 60fts times down  :noel:
Christo19
« Reply #112 on: April 15, 2013, 03:56:43 PM »
need some slicks
denmah
« Reply #113 on: April 15, 2013, 09:27:00 PM »
« Reply #114 on: April 15, 2013, 11:48:59 PM »
Some cheap rods and pistons and a second one of those cdm 80mm's.  :noel:
denmah
« Reply #115 on: April 20, 2013, 10:37:13 PM »
EG-MIKE
« Reply #116 on: May 09, 2013, 08:38:25 PM »
holy shit!!!!! this thing is so beast, you need a set of slicks and you'll be golden on the 1/4 probably could pull a low 11 or even high 10 with some traction and no breaking drivline parts
watching your rippers gives me a perma grin, makes me think of the potential my girls 5.3 4x4 has with a little boost and a solid trans.
denmah
« Reply #118 on: May 20, 2013, 02:25:51 PM »
Badass!
« Reply #119 on: May 20, 2013, 06:14:33 PM »
FUcking hell!!
Pages: 1 2 3 [4] 5   Go Up
